In comp.dsp, robert bristow-johnson <rbj@audioimagination.com> wrote:>in article Kxr_d.3203$h22.1424@fe1.columbus.rr.com, Mark Borgerding at >mark@borgerding.net wrote on 03/17/2005 22:03: > >>> The easiest thing I know to do is make your buffer size 2^M. Then updating >>> the index is done by ANDing it with 2^M - 1. >> >> >> I've used a differnt method that is >> a) not assembly >> b) not restricted to powers of 2 >> c) often faster than bitwise and-ing the index >> >> Break up the iteration over the circular buffer into a pair of >> for-loops. One for handling all operations from the current position to >> the end, and the other loop to handle the beginning of the circular buffer. > >this is for doing an FIR, right, Mark? i tried to allude to it, i guess it >was this morning. that "current position" in the buffer is a state that you >have to keep track of (and save and restore) and when you increment (or >decrement, if you like to express delays as a positive displacement) that >current position pointer (only once per sample), you do need to check to see >if wrapping is necessary. but that's only once per sample, not for every >tap of the FIR. >For a FIR I have used another method. The samples go into a normal circular buffer and I have a coefficients array that is twice it's normal length (duplicating the entries). When it's time to calculate the FIR, I calculate the starting point in the coefficient array from the current buffer index and always start at 0 in the sample buffer. This way I can do the filter in a single loop without index checking. The real advantage of this is that you can unroll the loop. This is what I did in the final app. This app was on an ARM7 and I moved the function to assembly. This resulted in only 3 instructions per tap with 32-bit data en coef and 64-bit intermediate results. One reason for moving to assembly was that I could not get the C compiler to emit the smlal instruction which is the perfect instruction for a FIR. -- Stef (remove caps, dashes and .invalid from e-mail address to reply by mail) Love and scandal are the best sweeteners of tea.
circular buffering C code
Started by ●March 16, 2005
Reply by ●March 18, 20052005-03-18
"James Morrison" <spam1@emorrison.ca> wrote in message news:1111117521.8718.78.camel@oxygen.emorrison.ca...> On Thu, 2005-03-17 at 11:34 -0800, Fred Marshall wrote: > http://www.ganssle.com/tem/tem111.pdf > > Hope that helps.Thanks James! FRed
in article 593d$423a9cdf$54f63171$2604@publishnet.news-service.com, Stef at stef33d@yahooI-N-V-A-L-I-D.com.invalid wrote on 03/18/2005 04:18:> For a FIR I have used another method. The samples go into a normal circular > buffer and I have a coefficients array that is twice it's normal length > (duplicating the entries). When it's time to calculate the FIR, I calculate > the starting point in the coefficient array from the current buffer index > and always start at 0 in the sample buffer. This way I can do the filter > in a single loop without index checking.wow, that's a way i hadn't thought about at all. clever, Stef. one thing that the order of evaluation of the FIR summation reminds me about is that it had been useful in single precision floating-point to evaluate the end tail (for a more minimum phase FIR) or tails (for linear phase) first and work your way into the portion of the FIR where the tap values are largest. you get less quantization error that way. if you have a double precision accumulator (be it fixed or floating-point), it shouldn't make any difference what the order of summation is. -- r b-j rbj@audioimagination.com "Imagination is more important than knowledge."
I am using the 67xx series right now. I am familiar with the ADI techniques as RBJ's pointed out, but that is all in assembly as far as I know. I have written a fair amount of fixed-pt ADI assembly code, but writing assembly for the TI processor is a whole different can of worms from my experience (i.e. not very nice). Now I have recently found ways to make the TI chips do very efficient computations using ANSI C and their optimizing compiler - but it does take some getting used to. Sometimes the resulting code doesnt read very well. In the past I wrote all my algs in embedded DSP assembly, and the circular buffering issue in C was always a thorn I have been trying to solve since moving to a C compiled embedded DSP solution... During this exercise I was also attempting to compare C compilers for the TI 67xx series and the TigerSharc. Since I havent used the ADI Visual DSP toolset, I was attempting to gauge the performance differences. My question was and still is: Since the 6713 maxes out at 300Mhz, and a TigerSharc goes upwards of 600-700Mhz, which compiler gives you the better software pipelining/performance? With C code being equal (or equivalent optimizations done), will a 300Mhz TI chip compiled with their C optimizer perform better than a 600Mhz TigerSharc compiled with ADI's C tools? That's the 6 million dollar question. You can read MIP marketing blurbs all day, but when it gets down to brass tax you want to know how typical C code gets optimized. I've witnessed 50x speedups in TI C code by just software pipelining certain loops, but I dont have any reference on how the ADI tools perform without porting over the project and doing a 1:1 analysis...
in article 1111173831.345519.219870@g14g2000cwa.googlegroups.com, JS at jshima@timing.com wrote on 03/18/2005 14:23:> I am using the 67xx series right now. I am familiar with the ADI > techniques as RBJ's pointed out, but that is all in assembly as far as > I know.i thought for sure there was a way to assign a register variable in the ADSP-21000 C language to a particular register in the chip. it was a non-ANSI, implementation specific extension to C. but on my Mac here, i certainly have no ADI code lying around in it. can the ADI jocks pipe in here? Al Clark, Jim Thomas, someone from ADI? -- r b-j rbj@audioimagination.com "Imagination is more important than knowledge."
Reply by ●March 19, 20052005-03-19
JS-- Good that you finally came around to asking pointed questions, I was a little hesitant in the begining to directly give info about c67xx without knowing if thats what you are targetting...Anyways, ill *try* to give you a fair picture here:>I am using the 67xx series right now. I am familiar with the ADI >techniques as RBJ's pointed out, but that is all in assembly as far as >I know.You are right.There are no known circular addressing mode techniques at C level for any processor, atleat none that i know of.I can say with confidence that there is no support for circular addressing in c6000 tools, nor does TI have plans to have this from C due to some difficulties in implementation. Today, the recommended methods would be:1) hand assembly (not desirable). 2) Use modulo addressing on the pointer offsets, which will result in a relatively inexpensive AND instruction, that often comes with no performance penalty. sum += x[i%32] * y[j%64]. This would result in implementation of two buffers (sized 32 and 64 elements respectively), with an AND operation to do the circular addressing. Keep in mind that you must use a power of 2 (as you would using the hardware)Read the application note spra645.pdf at ti's website for recommended methods for implementing circular buffers in c6000. I have written a fair amount of fixed-pt ADI assembly code,>but writing assembly for the TI processor is a whole different can of >worms from my experience (i.e. not very nice).I agree some, disagree some. C6000 is not your regular MAC based CISC DSP,where hand asm coding is the *only* way to eke out performance.C6000 is the most successful VLIW(TI calls it VelociTI) architecture ever there was barring none.It is a very very deeply pipelined (unprotected) processor and it is fool hardy to attempt to implement a project completely in ASM in C6000, It is meant to be programmed in C using the highly optimizing C compiler provided by the manufacturer. If you must,then you can program in Linear Assembly(not the same as ASM), which is very cool and can produce up to 95% of hand coded optimization without having to do register management and software pipelining the code.The bottom line is let the tools do the job.But then you shd know how to get the job done from the tools as well, this involves quite a bit of reading, i presume.> >Now I have recently found ways to make the TI chips do very efficient >computations using ANSI C and their optimizing compiler - but it does >take some getting used to. Sometimes the resulting code doesnt read >very well.Well, thats an odd complaint, why wud u want the resulting code to look good? You would maintain the make file and the source code in C (for future revisions) so bother about the resulting code.Anyways, the explanation is that VLIW ASM code is not an ideal diet for a sunday evening code reading exercise! It is not readable at all in the regular sense, its a highly paralell code, which with suffiecient experience you may be able to read and digest but not so for new adopters.>In the past I wrote all my algs in embedded DSP assembly, and the >circular buffering issue in C was always a thorn I have been trying to >solve since moving to a C compiled embedded DSP solution... >The simple answer is no. I'm not aware of any DSP compiler that allows C to use circular buffering hardware. The problem is that C doesn't understand circular modification of pointers.Most of the solutions that I've seen are in assembly and then call them from C. The easiest solution might be trying to find code that already performs the necessary algorithm. Baring that, you might be able to write a simple assembly function to update a pointer with circular modification and then call it from your C routine. This might be faster than managing the whole process in C>During this exercise I was also attempting to compare C compilers for >the TI 67xx series and the TigerSharc.TI's C6000 compiler is highly efficient for programs that have lots loops and have a certain degree of data-non-dependecy in the algorithm.These two issues are the red herrings for C6000. Anyways if you are doing DSP algorithms they tend to be manifestations of those two herrings...Some think that this and ADS for arm are two best optimizing compilers in the world.And I agree.>My question was and still is: Since the 6713 maxes out at 300Mhz, and >a TigerSharc goes upwards of 600-700Mhz, which compiler gives you the >better software pipelining/performance?C6713 has 8 *independant* functional units: 1] 2 .M -Multiplier units 2] 2 .D- data units(for load and store,can do simple arithmetic as well) 3] 2 .S -bit manip units (can do arithmetic and branch as well) 4] 2 .L -ALU units (C67xx have a whopping 16 stage pipeline!) Now thats, actually 2 multipliers, 6 ALU's and 2 data units! And all of them can be operated paralelly, i.e 8 instructions can be executed every clock cycle! Isnt that great? C6713 runs at 300 mhz, so it is capable of performing 600 Millions of MACs (2 .M units running at 300 mhz!) it can load or store upto 64 bit data values every clock! Finally, all put together C6713 can operate at 300*8= 2400 MIPS! And yes the compiler maximises these units provided you give lots of hints(pragma's) and assistance(intrinsics,aliasing etc.) to the compiler itself and use the right build options(-o3,pm,-mt etc.) With C code being equal (or>equivalent optimizations done), will a 300Mhz TI chip compiled with >their C optimizer perform better than a 600Mhz TigerSharc compiled with >ADI's C tools?Is tigersharc a RISC? if so this comparison is valid, otherwise it is totally meaningless. I will wait for your reply before dwelling deep on "tiger compiler vs C6000 compiler".> >That's the 6 million dollar question. You can read MIP marketing >blurbs all day, but when it gets down to brass tax you want to know how >typical C code gets optimized. I've witnessed 50x speedups in TI C >code by just software pipelining certain loops, but I dont have any >reference on how the ADI tools perform without porting over the project >and doing a 1:1 analysis... > >My money is on TI compiler for efficiency, I have used it for more than 5 years now. --Bhooshan This message was sent using the Comp.DSP web interface on www.DSPRelated.com
robert bristow-johnson wrote:> in article Utt_d.981$rL3.667@fe2.columbus.rr.com, Mark Borgerding at > mark@borgerding.net wrote on 03/18/2005 00:15: > > >>robert bristow-johnson wrote: > > ... > >>>another possible exception is a sparsely tapped long delay line where the >>>taps are at sorta randomly spaced intervals. (like an FIR where nearly all >>>of the taps have zero coefficients, but the non-zero taps are spaced at >>>weird intervals. a sorta reverberator.) then, i think, the power of 2 and >>>masking technique is the simplest reasonably foolproof method. >> >>The technique works best in the first case (FIR), but I've also used it >>in the second (sparse). It is a bit trickier, though. > > > so what do you do? do you have a pointer to your ordered tap list > (containing the tap coefficient and delay for each non-zero tap)Yes.> that > defines (or divides) which taps are one side of the buffer and which are > wrapped around to the other side?no. The dividing point is detected by the conditional of the first loop.> and then test to see when that pointer > has to be moved? how do you know (easily) how far to index into the > circular buffer for the first tap that comes after the wrap-around?Once the index goes past the end of the buffer in the first loop, subtract the buffer length before starting the second loop. Subtraction at the right time keeps the index in the modulus domain.> i think the > tap list would not have the absolute delays (from the input pointer > position) of the taps, but would be the delay relative to the tap preceding > it.Yes, I think offset deltas are better than offsets.> then there is an addition, which seems to me to be on par with an > ANDing operation.I don't think the two-loop approach requires any additional addition operations as compared to the one-loop-with-ANDing approach.
bhooshaniyer <bhooshaniyer@gmail.com> wrote:> If I may ask, why code Circular buffer in C at all? Assuming you are using > a DSP chip for your programming, there is bound to be a hardware circular > buffer which can be programmed only through assembly.From your question I > infer that you are worried about cycles and if you are then you shd be > choosing to code in assembly.Thats your best bet. In fact strictly > speaking circula buffer is precisely one of the reasons for you to choose > assembly over C.But doesn't this assume a lot of things as to what he will be keeping in the buffer?> > --Bhooshan > > This message was sent using the Comp.DSP web interface on > www.DSPRelated.com-- Sander +++ Out of cheese error +++
Mark Borgerding <mark@borgerding.net> wrote:> > Break up the iteration over the circular buffer into a pair of > for-loops. One for handling all operations from the current position to > the end, and the other loop to handle the beginning of the circular buffer. > > The extra overhead of adding a second loop is probably less than the > bitwise AND incurred for each iteration. One possible exception is for > very small circular buffers. In that case, the designer should question > the use of a circular buffer at all.Are these actually more efficent - and that includes the explicit and for update - any more efficent in practice than coding it all with a mod operation in C and having the compiler do the conversion? Compilers have been converting n % m into various non-division invlving operation for constant / known m for many decades...> > > -- Mark Borgerding-- Sander +++ Out of cheese error +++
"Sander Vesik" <sander@haldjas.folklore.ee> wrote in message news:1111285850.795596@haldjas.folklore.ee...> Mark Borgerding <mark@borgerding.net> wrote: > > > > Break up the iteration over the circular buffer into apair of> > for-loops. One for handling all operations from thecurrent position to> > the end, and the other loop to handle the beginning ofthe circular buffer.> > > > The extra overhead of adding a second loop is probablyless than the> > bitwise AND incurred for each iteration. One possibleexception is for> > very small circular buffers. In that case, the designershould question> > the use of a circular buffer at all. > > Are these actually more efficent - and that includes theexplicit and> for update - any more efficent in practice than coding itall with a> mod operation in C and having the compiler do theconversion? Compilers> have been converting n % m into various non-divisioninvlving operation> for constant / known m for many decades... >while (empty != fill) { <do stuff here using empty> if (++empty >= RINGBUFSIZE) empty = 0; } The generated code will require far fewer machine cycles than anything involving modulo computations.
