Sine to square wave conversion
Started by Sharan123 October 14, 2015
On 10/15/15 8:18 AM, Bob Masta wrote:
> On Wed, 14 Oct 2015 19:45:14 -0400, robert bristow-johnson > <rbj@audioimagination.com> wrote: > > <snip> > >> i have a different embarrassing trial (tried it during a rehearsal) >> thinking that we could put a resistor pad on the speaker output of the >> guitar amp instead of micing it. >> >> i thought fer sher it would work. > > OK, I'll bite: What was the problem?
very loud hum. it wasn't transformer isolated. -- r b-j rbj@audioimagination.com "Imagination is more important than knowledge."
Sharan123 <99077@dsprelated> wrote:
(someone wrote)
>>In some cases I do wonder why the term "filter" is applied. "Filter" >>tends to imply that something in the input gets passed while other >>things in the input do not. Is the idea that x(t) = sgn(sin(wt)) >>removes the amplitude information and lets everything else through?
(snip)
> To be frank, I have had the same doubt and I had put this question in this > forum. A filter intuitively means that something is removed and something > is not. But I realized that probably that was a shallow co-relation I was > making about filters. After a bit of thinking, I assume filtering does not > always mean removal of signal components but can also mean removal of > things like noise.
Do filters have to be linear in their removing? A rectifier removes the bottom half of a sine, is that a filter? Note that in doing the removing, it adds man frequency components? There is an interesting field called non-linear optics, where optical frequency signals go through non-linear devices, which includes adding frequency components.
> So, if we use moving average as an example, the noise is reduced, though > the power sort of gets distributed ... in this case, the noise is removed > but the signal associated is not ...
-- glen
On 2015-10-16 00:38, gyansorova@gmail.com wrote:
> That is not a filter. A filter performs some form of convolution in the traditional sense. You can get multiplicative filtering of course for multiplicative noise.
Of course, we can go forever replying each other "it's a filter", "no, it's not". What I'm writing here is that "filter" as "convolution" (as you write) is only a narrow view of the concept. BTW, I'm not even sure an IIR is a convolution in a "traditional" sense (on the other hand, who knows what "traditional" means...). Many people, in different, but close, fields, define "filter" as a much broader tool. As I mentioned, there is a "median filter", which does not convolve anything, strictly. Nevertheless, it's called "filter". bye, -- piergiorgio
>If we were getting drunk at a university bar I'd make a bet with you >that it's filtering, just for the joy of arguing.
Linear filters are boring anyways. To quote my professor, "everything is a filter. This room is a filter. I'm a filter. You're a filter." --------------------------------------- Posted through http://www.DSPRelated.com
>On 2015-10-16 00:38, gyansorova@gmail.com wrote: >[...] >> That is not a filter. A filter performs some form of convolution in
the
>traditional sense. You can get multiplicative filtering of course for >multiplicative noise. > >Of course, we can go forever replying each >other "it's a filter", "no, it's not". > >What I'm writing here is that "filter" as >"convolution" (as you write) is only a >narrow view of the concept. > >BTW, I'm not even sure an IIR is a convolution >in a "traditional" sense (on the other hand, >who knows what "traditional" means...). > >Many people, in different, but close, fields, >define "filter" as a much broader tool. > >As I mentioned, there is a "median filter", >which does not convolve anything, strictly. >Nevertheless, it's called "filter". > >bye, > >-- > >piergiorgio
Just to add to the silly list of filters. A wire causes delay and so is a filter. Bye (Piergiorgio Sartor) Kaz --------------------------------------- Posted through http://www.DSPRelated.com
