Hi, I would like to ask your opinion about a new recursive oscillator that I came up wiith: http://vicanek.de/articles/QuadOsc.pdf One should think that everything has been said and done in this area, however I am not aware of any existing (recursive) oscillator which comprises all of the following features: (1) (hyper)stable (i.e. no exponential runaway) (2) quadrature output (3) equal amplitudes (4) low-frequency accurate (5) reasonable CPU load (3 adds and 3 multiplies per sample) I have done a thorough research to check that this hasn't been published before but of course I might have missed something. Thanks for your feedback! Martin --------------------------------------- Posted through http://www.DSPRelated.com
A new recursive quadrature oscillator
Started by ●October 15, 2015
Reply by ●October 15, 20152015-10-15
Martin Nice paper, very well explained. I've used recursive oscillators in the past and always had trouble with amplitude changes during on-the-fly coefficient updates (doing a linear or log frequency sweep, for example). I couldn't quite tell if your oscillator was free of this problem or just a little better compared to other forms. I always wondered if you could re-time the parameter changes so they coincide with the phase angle that corresponds to the initial reset condition. Since you can't expect that the phase angle will ever return exactly to the initial condition, you could perhaps keep track of the phase error when the coefficient update occurs and noise-shape this error by adjusting the timing of the update. On the other hand this is complicated enough that most people would just use an interpolated lookup table instead. Bob
Hi, This is very cool indeed. It would be interesting to add a section about fixed-point behavior. Are extra bits needed if a result of N bits is desired on the outputs? --------------------------------------- Posted through http://www.DSPRelated.com
On 10/15/15 11:16 AM, radams2000@gmail.com wrote:> Nice paper, very well explained. I've used recursive oscillators in the past and always had trouble with amplitude changes during on-the-fly coefficient updates (doing a linear or log frequency sweep, for example). I couldn't quite tell if your oscillator was free of this problem or just a little better compared to other forms. > > I always wondered if you could re-time the parameter changes so they coincide with the phase angle that corresponds to the initial reset condition. Since you can't expect that the phase angle will ever return exactly to the initial condition, you could perhaps keep track of the phase error when the coefficient update occurs and noise-shape this error by adjusting the timing of the update. On the other hand this is complicated enough that most people would just use an interpolated lookup table instead. >On 10/15/15 11:54 AM, gretzteam wrote:> This is very cool indeed. It would be interesting to add a section about > fixed-point behavior. Are extra bits needed if a result of N bits is > desired on the outputs?lessee... tmp = u[n] - k1*v[n]; v[n+1] = v[n] + k2*tmp; u[n+1] = tmp - k1*v[n+1]; so v[n+1] = v[n] + k2*(u[n] - k1*v[n]) = k2*u[n] + (1-k1*k2)*v[n] and u[n+1] = u[n] - k1*v[n] - k1*v[n+1] = u[n] - k1*v[n] - k1*(k2*u[n] + (1-k1*k2)*v[n]) = (1-k1*k2)*u[n] - k1*(2-k1*k2)*v[n] and i seem to remember that u[n+1] = cos(w)*u[n] - sin(w)*v[n] and v[n+1] = sin(w)*u[n] + cos(w)*v[n] so 1-k1*k2 = cos(w) and k2 = k1*(2-k1*k2) = sin(w) is that the case? i haven't cranked it out but the latter looks suspect to me. -- r b-j rbj@audioimagination.com "Imagination is more important than knowledge."
Reply by ●October 16, 20152015-10-16
Guys, thanks for your comments. [...]>(5) reasonable CPU load (3 adds and 3 multiplies per sample)Actually only 2 multiplies if you save the product k1*v[n+1] and use it in the next iteration step ;-)>Nice paper, very well explained. I've used recursive oscillators in the >past and always had trouble with amplitude changes during on-the-fly >coefficient updates (doing a linear or log frequency sweep, for example).I>couldn't quite tell if your oscillator was free of this problem or just alittle>better compared to other forms. >[...]BobThat's one of the advantages of an equal-amplitude quadrature oscillator: updating coefficient on-the-fly does not change the amplitudes nor the phase relation, the whole thing simply rotates at another speed from there on. It's like a rock solid wheel. :-) Obviously I forgot to state this in my write-up, need to include that.>[...] It would be interesting to add a section about >fixed-point behavior. Are extra bits needed if a result of N bits is >desired on the outputs?Whoa, I have always worked with floating-point so haven't thought about fixed-point. But yes, I can see the relevance, thanks for the suggestion.>[...] > so 1-k1*k2 = cos(w) > and k2 = k1*(2-k1*k2) = sin(w) > >is that the case? i haven't cranked it out but the latter looks suspect>to me. > >r b-jYup, all correct! (I admit the second equality is not immediately obvious.) However, if you eliminate tmp like you did you end up with a coupled form oscillator, which has 4 multiplies and is unstable. So for the actual iteration it is better to leave tmp in. --------------------------------------- Posted through http://www.DSPRelated.com
>>[...] It would be interesting to add a section about >>fixed-point behavior. Are extra bits needed if a result of N bits is >>desired on the outputs? > >Whoa, I have always worked with floating-point so haven't thought about >fixed-point. But yes, I can see the relevance, thanks for thesuggestion.>Here is another question: say you want to use this to generate sin/cos as part of a demodulator where the carrier frequency (fc) is an INTEGER multiple of the sampling rate, say fc = fs/32. You really are only repeating 32 samples over and over. By quantizing the coefficients to B bits, we are essentially losing that 'ideal' relationship, and are generating a frequency 'close' to the desired one, but not dead on. Can you think of some transformation that would allow exact quantization of coefficients for frequencies at integer multiple of the sampling rate? --------------------------------------- Posted through http://www.DSPRelated.com
>Here is another question: say you want to use this to generate sin/cosas>part of a demodulator where the carrier frequency (fc) is an INTEGER >multiple of the sampling rate, say fc = fs/32. You really are only >repeating 32 samples over and over. > >By quantizing the coefficients to B bits, we are essentially losing that >'ideal' relationship, and are generating a frequency 'close' to the >desired one, but not dead on. Can you think of some transformation that >would allow exact quantization of coefficients for frequencies atinteger>multiple of the sampling rate?Okay, in that case you'd probably want to store the 32 sine/cosine values in a table and just cycle your pointer. I can't think of an easier way. --------------------------------------- Posted through http://www.DSPRelated.com
>>Here is another question: say you want to use this to generate sin/cos >as >>part of a demodulator where the carrier frequency (fc) is an INTEGER >>multiple of the sampling rate, say fc = fs/32. You really are only >>repeating 32 samples over and over. >> >>By quantizing the coefficients to B bits, we are essentially losingthat>>'ideal' relationship, and are generating a frequency 'close' to the >>desired one, but not dead on. Can you think of some transformation that >>would allow exact quantization of coefficients for frequencies at >integer >>multiple of the sampling rate? > >Okay, in that case you'd probably want to store the 32 sine/cosinevalues>in a table and just cycle your pointer. I can't think of an easier way. >--------------------------------------- >Posted through http://www.DSPRelated.comSure, and that was it typically done. However, that table might grow quite a bit the day you need to support 16 different 'carriers' etc. I was wondering if this could be used as an extremely clever way to compress all those tables, but it seems like the coefficients will never nicely quantize for those cases. --------------------------------------- Posted through http://www.DSPRelated.com
Reply by ●October 18, 20152015-10-18
I implemented it in FreeBasic and it worked very well. It could be useful for doing computer graphics.
>I implemented it in FreeBasic and it worked very well. It could beuseful>for doing computer graphics.Cool :) --------------------------------------- Posted through http://www.DSPRelated.com
