Hi all, I am trying to implement this DC blocker in FPGA. http://www.digitalsignallabs.com/dcblock.pdf However, my signal after it is significantly reduced in amplitude. What is the best way to cope with this? Also, do I need to use DSP48 block (xilinx FPGA) for this multiplication with pole? Thank you. --------------------------------------- Posted through http://www.DSPRelated.com
DC Blocker
Started by ●October 22, 2015
Reply by ●October 22, 20152015-10-22
I am trying to implement the second filter on figure 2. So y[n] = x[n]-x[n-1]+p*y[n-1] I am not sure what function should this noise shaping be? Instead of that I am only subtracting e(n-1) from the above equation prior to quantization. --------------------------------------- Posted through http://www.DSPRelated.com
Also I am interested if there is a way to implement this in FPGA if your samples are coming at each clock cycle (i don't know how you refer to this in english, fpga is clocked at sample frequency maybe?) --------------------------------------- Posted through http://www.DSPRelated.com
Unless you are really constrained in terms of gate count I would recommend using full double precision in the recursive section. It's only slightly more expensive than noise-shaping and you won't have troubles with idle tones from the noise-shaping. Idle tones have a nasty way of only being detected by your customers after you are shipping product. Bob
But how is this related to the fact that signal is low? I think it gets low after differentiator part? --------------------------------------- Posted through http://www.DSPRelated.com
The signal after the differentiator is low if the input signal is much lower than Nyquist. But there is no quantization in the differentiation operation so that is not a problem. The problem is in the recursive part, due to the necessary quantization. Bob
Ok, thank you, signal is much better when I increase signal frequency or decrease bandwidth. Does anyone know how to implement this in FPGA when data arrives at every clock cycle? --------------------------------------- Posted through http://www.DSPRelated.com
On 10/22/15 3:15 PM, b2508 wrote:> Ok, thank you, signal is much better when I increase signal frequency or > decrease bandwidth. > > Does anyone know how to implement this in FPGA when data arrives at every > clock cycle? >i imagine there is someone who knows how to do that and exchanges such knowledge for payment of some form. (i'm not one of them.) -- r b-j rbj@audioimagination.com "Imagination is more important than knowledge."
Reply by ●October 23, 20152015-10-23
On Thu, 22 Oct 2015 17:51:27 -0400, robert bristow-johnson wrote:> On 10/22/15 3:15 PM, b2508 wrote: >> Ok, thank you, signal is much better when I increase signal frequency >> or decrease bandwidth. >> >> Does anyone know how to implement this in FPGA when data arrives at >> every clock cycle? >> >> > i imagine there is someone who knows how to do that and exchanges such > knowledge for payment of some form. (i'm not one of them.)I gave the answer away for free in comp.arch.fpga :) The trick is to use shift (which is free in an FPGA) and subtract (which is really quick in an FPGA) instead of using a multiplier (which incurs at least one clock of delay). Regards, Allan
>On Thu, 22 Oct 2015 17:51:27 -0400, robert bristow-johnson wrote: > >> On 10/22/15 3:15 PM, b2508 wrote: >>> Ok, thank you, signal is much better when I increase signal frequency >>> or decrease bandwidth. >>> >>> Does anyone know how to implement this in FPGA when data arrives at >>> every clock cycle? >>> >>> >> i imagine there is someone who knows how to do that and exchanges such >> knowledge for payment of some form. (i'm not one of them.) > > >I gave the answer away for free in comp.arch.fpga :) > >The trick is to use shift (which is free in an FPGA) and subtract (which>is really quick in an FPGA) instead of using a multiplier (which incurs >at least one clock of delay). > >Regards, >AllanI think you can shave off a storage element by some block diagram manipulation if useful. Something like this: |highpassoutput | | +-------+----high precision zone --------+ input | ,-. | +--+ ,-. | -------+-( - --'--+*k+-------- + .......| | | `+' +--+ `+' | | | | | | | | | +--------+ | +-+-+ | | |..|..|.trunc..|....|......| z | | | | +--------+ +---+ | +------+---------------------------------+ | |lowpassoutput --------------------------------------- Posted through http://www.DSPRelated.com
