How to design Decimator with the extra filter A(z) at the output and Interpolator with the extra filter A(z) at the input. .. x(n) is the input Fs = 24 in the input sampling rate M= 6 is the number of subfilter In case decimator A(z) is operated at output sample rate . as Fs/M ..where M is 6 .Fs is the input sampling rate. In case Interpolator A(z) is placed at the input and operates at input sampling rate ie 24khz. specification: Bandwidth =1khz transition bandwidth =0.25khz inband ripple is 0.1 outband attenuation is 80db filter length =348 . i have doubt in designing the A(z). is there any specific formula to design kernel filter A(z) Thank you in advance --------------------------------------- Posted through http://www.DSPRelated.com
Efficient Polyphase FIR Decimators and Interpolators
Started by ●October 29, 2015
