Hi, I have a TI C54CST eval board and I do not have any JTAG emulators. I just wanted to know if there was a way to communicate with the board via the COM port on my PC. Is having a JTAG emulator the only way to do this? Thanks - Vamsi This message was sent using the Comp.DSP web interface on www.DSPRelated.com
Communicating with C54CST board without JTAG emulation?
Started by ●March 23, 2005
Reply by ●March 24, 20052005-03-24
hi!! ....if ur board has a sci(asynchronous) module and the memory supports bootrom....then u can communicate with dsp via com1(using rs232)....or..if ur board supports spi module(synchronous).then also u can run ur program from a eprom...which will be interfaced through spi ..... well.i dont know xact configuration of ur board...but these things work for tms320lf2407 board... bye "vamsikodavanty" <vamsikodavanty@gmail.com> wrote in message news:<fMqdnRjO8qjs09zfRVn-uw@giganews.com>...> Hi, > I have a TI C54CST eval board and I do not have any JTAG emulators. I > just wanted to know if there was a way to communicate with the board via > the COM port on my PC. > Is having a JTAG emulator the only way to do this? > > Thanks > - Vamsi > > > > This message was sent using the Comp.DSP web interface on > www.DSPRelated.com
Reply by ●March 28, 20052005-03-28
Hi Vamsi I suppose JTAG is optional for ti DSP, so you can do that, what you want. Dibyendu Mondal "vamsikodavanty" <vamsikodavanty@gmail.com> wrote in message news:<fMqdnRjO8qjs09zfRVn-uw@giganews.com>...> Hi, > I have a TI C54CST eval board and I do not have any JTAG emulators. I > just wanted to know if there was a way to communicate with the board via > the COM port on my PC. > Is having a JTAG emulator the only way to do this? > > Thanks > - Vamsi > > > > This message was sent using the Comp.DSP web interface on > www.DSPRelated.com
