Phase Noise
Started by ckiancho ●March 23, 2005
Hi.
The simulink block Phase Noise uses noise with a spectrum characterized by a
1/f slope. I presume that means if the frequency offset is specified at F
Hz, the noise spectrum is 1/f for frequency offset >= F. Then what about the
noise spectrum for frequency offset < F? Is it also 1/f or simply flat? If
it is 1/f, then it should not make any different to set the frequency offset
at F1 Hz with a phase noise level -P1 dBc/Hz than to set the frequency
offset at 10*F1 Hz with a phase noise level -(P1-20) dBc/Hz. However, I
think the Phase Noise block does not give the same level of phase noise with
these 2 settings. Hence, is it correct to say that the noise spectrum if
flat for frequency offset < F?
Thanks.
Regards,
Kian Chong
I would assume (I'm not sure) the phrase 1/F refers to the slope being
-6 dB per octave.  It does not define the actual value, only the slope.
 I am guesing the simulink block is letting you define the actual value
at one offset namely F.  The slope is 1/F both above F and below F and
the value at F is as you define it.
Mark
I agree that 1/F refers to the slope being -6dB per octave. However, if the
slope is 1/F above and below F, then won't it be the same to specify, for
example, -60dB at 100Hz or -80dB at 1000Hz?
"Mark" <makolber@yahoo.com> wrote in message
news:1111627621.031681.108840@l41g2000cwc.googlegroups.com...
>I would assume (I'm not sure) the phrase 1/F refers to the slope being > -6 dB per octave. It does not define the actual value, only the slope. > I am guesing the simulink block is letting you define the actual value > at one offset namely F. The slope is 1/F both above F and below F and > the value at F is as you define it. > > Mark >
yes,
I see the point of your question now,
my bad
I don't know if this is an issue in simulation, but in real test
equipment it sometimes is....the measurement bandwidth may change over
different frequency ranges.   If the result is always normalized to dBc
/___ Hz___  then it should be the same.   Are your numbers -60 and -80
both dBc/Hz  or are they  dBc in the measurment bandwidth?
Mark
news:1111675196.432749.236190@l41g2000cwc.googlegroups.com...
> yes, > > I see the point of your question now, > > my bad > > I don't know if this is an issue in simulation, but in real test > equipment it sometimes is....the measurement bandwidth may change over > different frequency ranges. If the result is always normalized to dBc > /___ Hz___ then it should be the same. Are your numbers -60 and -80 > both dBc/Hz or are they dBc in the measurment bandwidth? > > > Mark >
Hi ! I suspect that the phase noise density is intended to go up as 1/f^2 for frequencies less than the breakpoint ( but I don't have simulink , don't use it , never have, so this is just a guess). Why not test it and see? It's often worth having a look so you can find out what the model element actually does rather than what you think it is supposed to do. You might also want to see what happens if you put in values like a -12 dB breakpoint at 20kHz offset just to be sure that the integrated phase noise out of the model element behaves the way that you think it should. Best of Luck - Mike
You'd better test that assumption, or double-check your terminology. Noise density vs. frequency slopes are almost universally stated as noise _power_ per root hertz, so nearly all communications or electrical engineers will interpret "1/f" noise to mean a slope of -3dB/octave, _not_ -6dB/octave. And yes, 1/f noise is an important contributor to noise in real systems. It's known as "flicker" noise when applied to physical amplifying devices, it has had engineers tearing their hair out since the advent of semiconductors (as I understand it's not nearly as prevalent in vacuum tubes), it _still_ has engineers tearing their hair out, and unless I've missed something it's still not fully understood. -- Tim Wescott Wescott Design Services http://www.wescottdesign.com
Tim,
yep,  you're right...
I was thinking 1/F^2.
1/F is a slope of 3 dB per octave or 10 dB per decade.
So that may explain the OP's problem as well.
Also typical 1/F noise becomes significant BELOW a certain frequency
point  so perhaps the simulink tool is providing a break point BELOW
which the 1/F noise begins to rise at 3 dB per octave.
thanks
Mark
Tim is right. 1/F is a slope of 3dB per octave. I simulated with the
phase noise simulink block and indeed specifying -60dBc/Hz at 100Hz is
the same as -70dBc/Hz at 1000Hz and also the same as -100dBc/Hz at
1MHz.
Now I have another question. At 0Hz offset, that is, the desired tone,
the level is 0dBc/Hz, am I correct? If so, there should be a
breakpoint where the slope rises to this 0dBc/Hz point at 0Hz. If this
breakpoint occurs at the specified frequency offset in the simulink
block, then again -60dBc/Hz at 100Hz should not be the same as
-70dBc/Hz at 1000Hz.
"Mark" <makolber@yahoo.com> wrote in message news:<1111686191.836431.294410@g14g2000cwa.googlegroups.com>...
> Tim, > > yep, you're right... > > I was thinking 1/F^2. > > 1/F is a slope of 3 dB per octave or 10 dB per decade. > > So that may explain the OP's problem as well. > > Also typical 1/F noise becomes significant BELOW a certain frequency > point so perhaps the simulink tool is providing a break point BELOW > which the 1/F noise begins to rise at 3 dB per octave. > > thanks > Mark
The units of phase noise, dBc/Hz, specify a noise DENSITY at a given
offset.  The desired carrier tone itself is not a density but is a
discrete carrier value (it has infinite density if you want to think of
it that way, all the power of the tone is concentrated at one
frequency, ideally)
The phase noise units dBc/Hz compare the density of the noise (the
power of the noise in a 1 Hz BW)  at a given offset,   to the power of
the carrier tone.
I think what you may be thinking about is the fact that the density of
the 1/F noise (not the tone) also (ideally) approaches infinity at 0 Hz
offset.  This is similar to an ideal integrator that has infinite gain
at DC.  (Black hole of noise???)   In practice, there is a break point
at a very low frequency below which the gain or noise density no longer
rise as the frequency is reduced.   I don't think that is what the
break point in the Simulink model is for. Again I think the Simulink
model is specifying  the 1/F noise slope as  3 dB per octave and the F
parameter allows you to "offset" this line up or down as needed.
Mark
ckiancho wrote:
> Tim is right. 1/F is a slope of 3dB per octave. I simulated with the > phase noise simulink block and indeed specifying -60dBc/Hz at 100Hz is > the same as -70dBc/Hz at 1000Hz and also the same as -100dBc/Hz at > 1MHz. > > Now I have another question. At 0Hz offset, that is, the desired tone, > the level is 0dBc/Hz, am I correct? If so, there should be a > breakpoint where the slope rises to this 0dBc/Hz point at 0Hz. If this > breakpoint occurs at the specified frequency offset in the simulink > block, then again -60dBc/Hz at 100Hz should not be the same as > -70dBc/Hz at 1000Hz. > > "Mark" <makolber@yahoo.com> wrote in message news:<1111686191.836431.294410@g14g2000cwa.googlegroups.com>... > >>Tim, >> >>yep, you're right... >> >>I was thinking 1/F^2. >> >>1/F is a slope of 3 dB per octave or 10 dB per decade. >> >>So that may explain the OP's problem as well. >> >>Also typical 1/F noise becomes significant BELOW a certain frequency >>point so perhaps the simulink tool is providing a break point BELOW >>which the 1/F noise begins to rise at 3 dB per octave. >> >>thanks >>Mark
"Phase-locked loop circuit design" by Dan H Wolaver, Prentice-Hall, 1991, ISBN 0-13-662743-9, chapter 6, "Noise". There are other good books on PLL design which I won't disrecommend, but I took the class from Dr. Wolaver when the book was in proofs. -- Tim Wescott Wescott Design Services http://www.wescottdesign.com
