ringing: minimum vs linear phase
Started by toobs ●March 27, 2005
In my experience, if a minimum phase FIR filter does (doesn't) ring
then the linear phase equivalent of that filter also will (won't) ring.
Anybody have any counterexamples or else a proof that the above is
always true?
John
On 27 Mar 2005 04:31:09 -0800, "toobs" <johndhancock@gmail.com> wrote:
>In my experience, if a minimum phase FIR filter does (doesn't) ring >then the linear phase equivalent of that filter also will (won't) ring. > >Anybody have any counterexamples or else a proof that the above is >always true? > >John
If the frequency selectivity of the filters are the same then the ringing behavior should be expected to be very similar. The deletion of the high-frequency terms results in the ringing (as in, "Gibb's Phenomena"), so it won't matter much whether it's minimum phase or not. Eric Jacobsen Minister of Algorithms, Intel Corp. My opinions may not be Intel's opinions. http://www.ericjacobsen.org
"toobs" <johndhancock@gmail.com> wrote in message
news:1111926669.968049.298090@o13g2000cwo.googlegroups.com...
> In my experience, if a minimum phase FIR filter does (doesn't) ring > then the linear phase equivalent of that filter also will (won't) ring. > > Anybody have any counterexamples or else a proof that the above is > always true? > > John
Well, certainly in linear phase filters the ringing is a function of the shape of the transition region. Sharp transitions lead to ringing. Smooth transitions less. Of course this is a great simplification of all the factors that go into it. One might also observe that the position of zeros (and poles if present) affects ringing for really the same reasons. I've not thought much about how changing from linear phase to minimum phase or maximum phase might affect the ringing. I guess I've always just assumed or understood that it wouldn't matter and that the transient response is a reflection of the "Q" of the system - which tends to be large around the transitions. High Q - long time. I suppose there could be a counter-example but I kinda doubt it. I guess you should define exactly what you mean by "the linear phase equivalent" Fred
in article 1111926669.968049.298090@o13g2000cwo.googlegroups.com, toobs at
johndhancock@gmail.com wrote on 03/27/2005 07:31:
can you define exactly what you mean by "ringing"? -- r b-j rbj@audioimagination.com "Imagination is more important than knowledge."
Fred Marshall wrote:
> "toobs" <johndhancock@gmail.com> wrote in message > news:1111926669.968049.298090@o13g2000cwo.googlegroups.com... > > In my experience, if a minimum phase FIR filter does (doesn't) ring > > then the linear phase equivalent of that filter also will (won't)
ring.
> > > > Anybody have any counterexamples or else a proof that the above is > > always true? > > > > John > > Well, certainly in linear phase filters the ringing is a function of
the
Smooth
> transitions less.
Agreed.
> Of course this is a great simplification of all the > factors that go into it.
Uh... is it? I can't really see what more than the width of transition regions (and possibly the width of the pass/stop bands of the filters, if they are very narrow) go into the question of ringing. I can't see how the phase response would have anything to do with ringing. But then, I'm more than groggy after 10 days with the flu(?), so I might very well be wrong... Rune
"Rune Allnor" <allnor@tele.ntnu.no> wrote in message
news:1111949034.814482.201270@o13g2000cwo.googlegroups.com...
> > Fred Marshall wrote: >> "toobs" <johndhancock@gmail.com> wrote in message >> news:1111926669.968049.298090@o13g2000cwo.googlegroups.com... >> > In my experience, if a minimum phase FIR filter does (doesn't) ring >> > then the linear phase equivalent of that filter also will (won't) > ring. >> > >> > Anybody have any counterexamples or else a proof that the above is >> > always true? >> > >> > John >> >> Well, certainly in linear phase filters the ringing is a function of > the >> shape of the transition region. Sharp transitions lead to ringing. > Smooth >> transitions less. > > Agreed. > >> Of course this is a great simplification of all the >> factors that go into it. > > Uh... is it? I can't really see what more than the width of transition > regions (and possibly the width of the pass/stop bands of the filters, > if they are very narrow) go into the question of ringing. I can't see > how the phase response would have anything to do with ringing.
Thanks Rune. Maybe the simplification wasn't so "great". The factors I was thinking of have to do with the 2nd order things like the derivatives of the transition. One can find a lowpass filter with a temporal transition to a step input such that the temporal transition has minimum width while being monotonic (no ringing). That's the sort of thing that I had in mind. But these are really details! Fred
Eric,
I agree with your statement and I have a question of more detail.  I
agree that a linear phase filter  and a min phase filter both can
suffer from ringing due to Gibbs Phenomena (assumming they bith are
similar otherwise, i.e. magnitude response)  .  My question is this....
  Is it true that the difference will be that  in the linear phase
filter case, that the ringing will equally come both before and after
the "step" in time, while in the min phase filter case, the ringing
will all be after the step in time.  To be specific, I'm thinking of
low pass filters with step functions passing through them.
thanks
Mark
On 27 Mar 2005 18:00:59 -0800, "Mark" <makolber@yahoo.com> wrote:
>Eric, > >I agree with your statement and I have a question of more detail. I >agree that a linear phase filter and a min phase filter both can >suffer from ringing due to Gibbs Phenomena (assumming they bith are >similar otherwise, i.e. magnitude response) . My question is this.... > Is it true that the difference will be that in the linear phase >filter case, that the ringing will equally come both before and after >the "step" in time, while in the min phase filter case, the ringing >will all be after the step in time. To be specific, I'm thinking of >low pass filters with step functions passing through them. > >thanks > >Mark
Yup, and you only need to look at the impulse response to understand why. A symmetric LPF with a sinx/x impulse response exhibits ringing before and after and edge since the convolution will encounter the tails of the sinx/x before and after the main lobe. Just imagine the convolution integrating as the edge of the square wave passes throught he impulse response: first it encounters the leading tails of the sinx/x and the output (the dot product of coefficient with the input as the edge passes through) will wiggle up and down as the undulation in the tails affects the output sum. When the edge passes the main lobe the output edge will transition at a rate (i.e., slope) determined by the width of the main lobe. (A wise mentor in my early DSP days said that the edge rate, and therefore the frequency response, of a FIR is controlled by the width of the main lobe. This is why.) As the edge passes the trailing lobes of the sinx/x the ringing continues as they affect the output sum accordingly. So the magnitude of the ringing will be proportional to the amplitudes of the sinx/x sidelobes, and the slope of the edge is a function of the width of the main lobe. For a minimum phase filter there are typically few or no leading sidelobes in the impulse response, so, just as you described, there won't be any ringing preceding the edge in the output. The rate of the edge is still controlled by the width of the main lob and the amplitude of the ringing is still going to be proportional to the amplitudes of the trailing sidelobes in the impulse response. The difference, just as you indicated, is that the lack of leading sidelobes in the impulse response eliminates the leading ringing in the step response output. Eric Jacobsen Minister of Algorithms, Intel Corp. My opinions may not be Intel's opinions. http://www.ericjacobsen.org
Eric,
OK thanks.
Now lets put this into an audio context.
It would seem (and this is subjective now)  that the ringing due to min
phase filter would be less objectionable because it is all post edge
and would sound similar to reverberation.  The linear phase filter has
pre ringing and I suspect that would sound very objectionable.
In any case they both probably sound pretty bad so the key to good
transient response (as I have believed for a while) is not linear phase
filters  or min phase filters, but rather using a more gradual rolloff
to avoid  the Gibbs phenomenon ringing in the first place.
In more general terms, any rapid change in the frequency response
(magnitude response) causes ringing problems and thus gradual filtering
may often be preferable to "brickwall" filtering.  This applies to both
low pass and high pass.  (Again this discussion is limited to an audio
context)
To add one more level to the discussion.... digital audio systems that
operate at  44.1 ksps typically employ  sharp anti-aliasing and
reconstruction low pass filters at about 20 kHz.  It seems from the
previous discussion that this filter (because it is typically designed
to have a sharp cutoff) typically will  create ringing no matter if it
is designed as min phase or linear phase.    Now this may sound like I
think these system sound bad due to this, but I also believe that the
saving grace is the fact that the rest of the system (mics, tweeters,
ears etc) is seldom flat to 20 kHz.  I know my ears aren't.  So even in
the worst case where the mics and tweeters and everything else were
flat to 20 kHz, the anti alias and reconstruction filters may create
ringing at 20 kHz, I'm not going to hear it anyway.    And in the more
typical case, the mics and speakers are not flat to 20 kHz but rather
will create a more gradual rolloff and since the Gibbs phenomenon
depends on the entire system having a sharp roll off, in this typical
case the ringing won't even occur due to the gradual rolloff created in
other parts of the system.   Comments?
thanks
Mark
Eric Jacobsen wrote:
> For a minimum phase filter there are typically few or no leading > sidelobes in the impulse response, so, just as you described, there > won't be any ringing preceding the edge in the output. The rate of > the edge is still controlled by the width of the main lob and the > amplitude of the ringing is still going to be proportional to the > amplitudes of the trailing sidelobes in the impulse response. The > difference, just as you indicated, is that the lack of leading > sidelobes in the impulse response eliminates the leading ringing in > the step response output.
This doesn't directly bear on Mark's question, but I think it ties in. With the minimum-phase filter, some frequencies will be delayed more than others. Consider a signal of finite length that resides in a file both before and after being filtered. If the samples in the file are rear backwards in time -- last first, and so on -- the delayed frequencies will be seen as advanced, leading edges will be seen as trailing edges, and their associated ringing will happen before them. If the time-reversed signal is filtered again with the same filter, the frequencies most advanced will be most retarded, and ringing will follow the trailing edges, matching that which preceded them. There are two major effects: the impulse response of the combined forward/backward filter will have symmetry, and the time delay of all frequencies will be the same. In fact, either condition implies the other. I'm content to let this scenario be the demonstration of that. Jerry -- Engineering is the art of making what you want from things you can get. &#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;
