Help with pitch extraction
Started by bouyang April 1, 2005
I have looked at some literature on using autocorrelation or AMDF for picth
detection/extraction.
If I understand correctly, all these methods have two parts -- first
construct the functional that can be used to extrac the period/pitch
(AMDF, autocorrelation etc.), second, find peak/null and the associated
lag index to obtain the pitch.
What I need help is how the extraction part is generally implemented (i.e.
how to pick the peak/null).
Thanks in advance.
This message was sent using the Comp.DSP web interface on
www.DSPRelated.com
in article tridndhBF-K9GdDfRVn-gQ@giganews.com, bouyang at
bing_research@yahoo.com wrote on 04/01/2005 12:25:
> I have looked at some literature on using autocorrelation or AMDF for picth > detection/extraction. > > If I understand correctly, all these methods have two parts -- first > construct the functional that can be used to extrac the period/pitch > (AMDF, autocorrelation etc.), second, find peak/null and the associated > lag index to obtain the pitch. > > What I need help is how the extraction part is generally implemented (i.e. > how to pick the peak/null).
i guess, think about how you would pick those peaks manually, try to describe explicitly every decision you make in pick the peak, and then code it.
> Thanks in advance.
FWIW. -- r b-j rbj@audioimagination.com "Imagination is more important than knowledge."
