Bob Cain wrote: ...> Among the numerous capsules the self noise of each would be > independant and uncorrelated. The signals, on the other > hand, would be highly correlated. There will be some time > of arrival differences in the sound pickup but little > magnitude differences.My first take on this problem would be to "standardize" each sensor output (ie. compensate known differences of the frequency response, phase, delay, etc. between the sensors). For each sensor you get a response h_k (k in 1 .. N, where N is the number of sensors). You basically just need to find the relative response with respect to any one reference sensor that you can define arbitrarily. If you know the placement, the direction and frequency response of the sensors, this should theoretically pose no problem (I can imagine that this could lead to problems in practice). If s_k is the output of the k-th sensor, and s_k' = h_k * s_k (* denotes convolution with the compensation filter h_k) the compensated output of each sensor, then a first estimate of the "true" signal (that is the signal "seen" through the reference sensor) is the average r = 1/N (s_1'+...+s_N'). An estimate for the denoised signal would be s_k'' = (h_k)^-1 * r, the deconvolution of the average. You could refine the estimate r by weighting each s_k with an additional weighting filter w_k which could define the amount of information that sensor k contributes to the average signal. Some non-linear weighting function could lead to a more robust estimate (for examle if a sensor is defect). This would be my first naive approach. Howerver, I should think the problem of estimating a signal from many sensor outputs is a well studied problem. I don't know the technical term though. Regards, Andor
Cross Correlation and Noise Reduction in Mic Arrays
Started by ●April 2, 2005
Reply by ●April 11, 20052005-04-11
Reply by ●April 16, 20052005-04-16
On Sat, 09 Apr 2005 20:01:39 -0700, Bob Cain <arcane@arcanemethods.com> wrote:> Look at: > > http://www.atvs.diac.upm.es/publicaciones/docs/Bot00a.pdfOK, I've looked, and, as usual, it's mostly over my head, but doesn't this apply to external "noise", meaning anything unwanted, rather than internal noise, meaning something subject to the Second Law? If so, it would seem to be within the murky purview of room de-convolving that you (*don't*) hint at so often. Large area receivers imply directionality. More is more, etc. Something the size of a human head has good directionality above one and a half kiloHertz or so... Add time-sensitive selective sensing around the surface... Sounds like a very interesting project. Good fortune, Chris Hornbeck 6x9=42 April 29
