hello, i would like to know if i'm doing this right. my program creates a vector of vectors which it then FFTs using the FFTW library. its written in C++. my full code is shown below. if this is right, the next step would be to correlate this vector with another. anyway, heres my code: ... #include "fftw3.h" using namespace std; typedef vector<int> convert; typedef vector<int> row; int main() { ifstream inFile; inFile.open("data2.txt"); if (inFile.fail()) { cout <<"\nThe file was not successfully opened" << endl; exit(1); } //vector of vectors which holds each line in the data file as a vector string one_line; double probability; while (getline(inFile, one_line, '\n')) { vector<convert> BinaryVector; //vector which holds data file //in binary format vector<int> Element; cout << "Line: " << one_line << endl; vector<double> Line; // holds a single line of the data file istringstream lineStream( one_line ); while( lineStream >> probability ) { Line.push_back( probability ); //stores prob in Line vector. int data; if (probability == 0) { data = 0; } else { data = 1; } Element.push_back( data ); } SourceData.push_back( Line ); BinaryVector.push_back( Element ); double *in, *out; fftw_plan p; int nx = Element.size(); int i; in = (double*)fftw_malloc(sizeof(double) * nx ); out = (double*)fftw_malloc(sizeof(double) * nx); p = fftw_plan_r2r(nx, in, out, const fftw_r2r_kind FFTW_R2HC, FFTW_ESTIMATE, FFTW_FORWARD); //fill input array int *array = new int[Element.size()]; for(int i = 0; i < Element.size(); i++) { array[i] = Element[i]; } // execute plan fftw_execute(p); // destroy plan fftw_destroy_plan(p); fftw_free(in); fftw_free(out); } system("PAUSE"); return 0; } oh yeah...i also keep getting the following error message which i'm not sure how to fix: "expected primary expression before const" for line p = fftw_plan_r2r(nx, in, out, const fftw_r2r_kind FFTW_R2HC, FFTW_ESTIMATE, FFTW_FORWARD); any help would be greatly appreciated. thanx in advance, katz This message was sent using the Comp.DSP web interface on www.DSPRelated.com
FFTW Library - am i using it right??
Started by ●April 3, 2005
Reply by ●April 3, 20052005-04-03
katz wrote:> ... > #include "fftw3.h" > using namespace std; > > typedef vector<int> convert; > typedef vector<int> row;Why bother with two different names for the same thing?> int main() > { > ifstream inFile; > inFile.open("data2.txt"); > > if (inFile.fail()) > { > cout <<"\nThe file was not successfully opened" << endl; > exit(1); > } > > //vector of vectors which holds each line in the data file as a > vector > > string one_line; > double probability; > > while (getline(inFile, one_line, '\n'))Why not inFile.getline(...) ?> { > vector<convert> BinaryVector; //vector which holds datafile> //in binary formatSo BinaryVector is a vector of vector of int?> vector<int> Element;Why not use the typedef's you made above?> cout << "Line: " << one_line << endl; > vector<double> Line; // holds a single line of the datafile What's the difference between "one_line" and "Line" then?> istringstream lineStream( one_line ); > > while( lineStream >> probability ) > { > Line.push_back( probability ); //stores prob in Line > vector. > > int data; > if (probability == 0) > { data = 0; } > > else > { data = 1; } > > Element.push_back( data ); > } > > SourceData.push_back( Line );Why have you just push_back-ed a variable that you've done nothing with?> BinaryVector.push_back( Element );Element is just ones and zeros?> double *in, *out; > fftw_plan p; > int nx = Element.size(); > int i; > > in = (double*)fftw_malloc(sizeof(double) * nx ); > out = (double*)fftw_malloc(sizeof(double) * nx); > > p = fftw_plan_r2r(nx, in, out, const fftw_r2r_kindFFTW_R2HC,> FFTW_ESTIMATE, FFTW_FORWARD);Is FFTW_R2HC of the correct type?> //fill input array > int *array = new int[Element.size()]; > for(int i = 0; i < Element.size(); i++) > { array[i] = Element[i]; }What does that do?> // execute plan > fftw_execute(p);Don't you have to load data into "in"?? That seems odd. How does fftw_execute know that array contains the data?> // destroy plan > fftw_destroy_plan(p); > fftw_free(in); > fftw_free(out); > } > > system("PAUSE"); > return 0; > > } > > oh yeah...i also keep getting the following error message which > i'm not sure how to fix: > "expected primary expression before const" for line > > p = fftw_plan_r2r(nx, in, out, const fftw_r2r_kind FFTW_R2HC, > FFTW_ESTIMATE, FFTW_FORWARD); > > any help would be greatly appreciated. > > thanx in advance, > katz > > This message was sent using the Comp.DSP web interface on > www.DSPRelated.comThis message was sent using the comp.dsp web interface on groups-beta.google.comn.
Reply by ●April 4, 20052005-04-04
katz wrote:><snip>> oh yeah...i also keep getting the following error message which i'm not > sure how to fix: > "expected primary expression before const" for line > > p = fftw_plan_r2r(nx, in, out, const fftw_r2r_kind FFTW_R2HC,I think you need to remove the "const fftw_r2r_kind" from the line above.> This message was sent using the Comp.DSP web interface on > www.DSPRelated.comYou should also learn how to use Usenet the way it is intended. Erik -- +-----------------------------------------------------------+ Erik de Castro Lopo nospam@mega-nerd.com (Yes it's valid) +-----------------------------------------------------------+ "Using Java as a general purpose application development language is like going big game hunting armed with Nerf weapons." -- Author Unknown
