How did...?
Started by bhooshaniyer April 4, 2005
How did Fourier know in the first place that periodic vibrations were
comprised sine waves?
--Bhooshan
This message was sent using the Comp.DSP web interface on
www.DSPRelated.com
The same way that Walsh knew they were made of square waves.
cheers, Syms.
"bhooshaniyer" <bhooshaniyer@gmail.com> wrote in message
news:crSdnfsbmNIf4czfRVn-3g@giganews.com...
> > How did Fourier know in the first place that periodic vibrations were > comprised sine waves? > > --Bhooshan > > This message was sent using the Comp.DSP web interface on > www.DSPRelated.com
Hi--
>The same way that Walsh knew they were made of square waves. >cheers, Syms.
Gee,Thanks! But let me confess that I was looking forward to a more historical perspective to this stream of thought... --Bhooshan This message was sent using the Comp.DSP web interface on www.DSPRelated.com
x" = -w^2 x Ciao, Peter K.
in article 1112638173.176761.54290@l41g2000cwc.googlegroups.com, Peter K. at
p.kootsookos@iolfree.ie wrote on 04/04/2005 14:09:
>> How did Fourier know in the first place that periodic vibrations were >> comprised sine waves? > > x" = -w^2 x
yeah, i think that's the answer. sinusoids and exponentials have this nice property that all the derivatives are sinusoids or exponentials. that's also why they are related to each other via Euler. -- r b-j rbj@audioimagination.com "Imagination is more important than knowledge."
see http://www-groups.dcs.st-and.ac.uk/~history/Mathematicians/Fourier.html as well as other links from http://www.google.com/search?hl=en&lr=&q=%22Fourier++series%22+history+heat
Symon wrote:
> The same way that Walsh knew they were made of square waves. > cheers, Syms.
And that Daubechie knew they were made of... Well, whatever those recursive things are that bear her name. :-) BTW, wasn't it Harr that did the step function decomposition? This is actually a rather important thing because many people actually do believe that signals are comprised of lots of sin waves. Really hard these days to get past that misconception. I believe that the fact that all of the discrete forms of these decompositions have a unifying theory belies Robert's belief that the Fourier one is special in somehow extending the knowledge of the argument beyond the bounds of the calculation. I think it is the operations that he talks about, abbreviated convolution and the shift theorem, for example, which superimpose a periodic view. Doesn't the shift theorem arise simply from a basis transformation which assumes periodicity of the basis? It must be qualified with the conditional, "If the signal is periodic then..." That periodicity is assumed nowhere in the calculation of the DFT itself. Bob -- "Things should be described as simply as possible, but no simpler." A. Einstein
The periodicity is not assumed. It turns up on its own in any decomposition to continuous, non-time-limited functions. Jerry -- Engineering is the art of making what you want from things you can get. &#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;
Bob Cain wrote:
> I believe that the fact that all of the discrete forms of > these decompositions have a unifying theory belies Robert's > belief that the Fourier one is special in somehow extending > the knowledge of the argument beyond the bounds of the > calculation.
Except that the exponential/sinusoidal basis are the solution to unforced LCCDEs (linear, constant coefficient difference [differential] equations)... which is the basis for all filter theory. The others are not. I do agree that the other bases are just as valid (and certainly have sensible uses). Ciao, Peter K.
in article d31qvh02k41@enews3.newsguy.com, Bob Cain at
arcane@arcanemethods.com wrote on 04/06/2005 19:22:
i'm glad you too are reverting to the crutch of anthopomorhizing this mindless mathematical operators. one data is truncated and thrown away, no mortal knows what it was or could have been with any certainty. i'm not saying that the DFT "knew" the data was periodically extended outside the data set given it. i'm just saying it "assumes" that it is. that might be wrong for the DFT to do that, but that's what it does. and to forget that might get you into trouble. this is not because if any issue regarding decompositions in general, it is one of a specific decomposition to a bunch of periodic basis functions. that example i gave Andor about the linear mapping that maps the N samples to N coefficients of an (N-1)th order polynomial does not share this property of periodically extension. perhaps it would have a "polynomial extension". i dunno. if it did, it would have to make use of that when operations such as shifting are applied, but i haven't lookd into it. i agree with Peter K. and whoever he was agreeing with that "... the other bases are just as valid (and certainly have sensible uses).
> I think it is the operations that he talks about, > abbreviated convolution and the shift theorem, for example, > which superimpose a periodic view. Doesn't the shift > theorem arise simply from a basis transformation which > assumes periodicity of the basis?
i think so (if i understand your meaning). it wouldn't be true, as stated, if the basis were not periodic. perhaps, with another transform (like above) there is a shifting theorem that utilizes the extension of the basis beyond the original domain of the input data, but again i dunno.
> It must be qualified with the conditional, "If the signal is periodic > then..."
No, Bob! that's the point! even if the original signal was not periodic with period N, the DFT made it that way when you passed it those N samples and you better get used to it! it's kinda like a window function has made all the data outside the window equal to zero, even if it wasn't before the window was applied.
and that is where we most fundamentally disagree. when, in the context of the DFT, we say that the spectrum X[k] and Y[k] are related by a factor of exp(j*2*pi*d*k/N) (whether "d" as an integer or not), the DFT *is* assuming that periodicity. if "d" happens to be an integer, it is saying that y[n] = x[n+d], but if you don't also understand that the DFT has made that assumption, you have to say the clumsier y[n] = x[mod(n+d,N)] which i say is tantamount to periodically extending x[n]. -- r b-j rbj@audioimagination.com "Imagination is more important than knowledge."
