Hi all ! I'm playing a little with matlab's fdatool and I noticed this : when I design a filter, as a 30th order one, with second order sections, the sections doesn't have the same coefficients. It is not as if I just designed a 2nd order filter and applied it 15 times. What is the difference ? Couldn't I just apply the second method described here ?? Thanks in advance ! Sam
IIR filter and SoS
Started by ●October 28, 2004
Reply by ●October 28, 20042004-10-28
That is to be expected. If you limit yourself to 15 identical second-order sections, you can't generate certain types of filters. For example, to get a filter with a sharp but smooth cut-off, say Butterworth, each SoS will have a different Q value. Taken by themselves, many sections will show overshoot. But in the composite filter, the overshoot from some will be balanced by the roll-off of others generating a smooth, sharp response. In another example, in a high order digital Bessel filter, each section has a different Q _and_ a different cut-off frequency. Stated mathematically, any higher order filter can be broken up into second-order sections*, but they cannot necessarily be broken up into _identical_ second-order sections. So in summary, you certainly can create a 30th order filter with 15 identical sections, but it may not be the kind of filter you are after. Hope that helps. -Jon * and perhaps a single first-order section. "Sam" <totalsam-n.o-s.p.a.m@hotmail.com> wrote in message news:418159f7$0$28014$5402220f@news.sunrise.ch...> Hi all ! > > I'm playing a little with matlab's fdatool and I noticed this : when I > design a filter, as a 30th order one, with second order sections, the > sections doesn't have the same coefficients. It is not as if I just > designed a 2nd order filter and applied it 15 times. > > What is the difference ? Couldn't I just apply the second method > described here ?? > > Thanks in advance ! > > Sam
Sam wrote:> Hi all ! > > I'm playing a little with matlab's fdatool and I noticed this : when I > design a filter, as a 30th order one, with second order sections, the > sections doesn't have the same coefficients. It is not as if I just > designed a 2nd order filter and applied it 15 times. > > What is the difference ? Couldn't I just apply the second method > described here ?? > > Thanks in advance ! > > SamAn nth-order Butterworth low-pass has a magnitude response of 1/|1 + jx^n|, where x = f/f_cutoff). A cascade of two order-n filters is 1/|(1+ jx^n)^2|. An order 2n filter is 1/|1 + jx^2n|. They are not the same. All Butterworth filters are 3 dB down at x = 1. When two are cascaded, the combination is 6 dB down. You could expect an order 30 filter designed as you imagined to be 90 dB down. Hardly the edge of the passband. Jerry -- Engineering is the art of making what you want from things you can get. �����������������������������������������������������������������������
Reply by ●October 31, 20042004-10-31
On Thu, 28 Oct 2004 22:45:36 +0200, Sam <totalsam-n.o-s.p.a.m@hotmail.com> wrote:>Hi all ! > >I'm playing a little with matlab's fdatool and I noticed this : when I >design a filter, as a 30th order one, with second order sections, the >sections doesn't have the same coefficients. It is not as if I just >designed a 2nd order filter and applied it 15 times. > >What is the difference ? Couldn't I just apply the second method >described here ?? > >Thanks in advance ! > >SamSam, I won't repeat what Jon and Jerry have already said. They are correct. I want to add something that is implied very strongly by their comments. Let's say the 30th order filter is butterworth. To implement the filter you use 15 Second Order Sections. As was stated the transfer function of the 15 sections in series has a butterworth response. The response of any of the second order sections will most likely not have the reponse of a 2nd order butterworth filter of similar type (HP,LP,BP etc). The butterworth function generates the poles at regular intervals (determined by the order of the filter) around the unit circle. What the SOS function of matlab does is split up the 30 poles and zeros into pairs. One pair per SOS in a very orderly well defined way. One pair may be at the 2nd order pole position depending on the original filter order. So each SOS will look very different in frequency response when looked at 1 SOS at a time. Perhaps you have already discovered this while investigating you problem. Hope this helps. Mark Allie
In article <418159f7$0$28014$5402220f@news.sunrise.ch>, Sam <totalsam-n.o-s.p.a.m@hotmail.com> wrote:>I'm playing a little with matlab's fdatool and I noticed this : when I >design a filter, as a 30th order one, with second order sections, the >sections doesn't have the same coefficients. It is not as if I just >designed a 2nd order filter and applied it 15 times.On the page http://unicorn.us.com/alex/allpolefilters.html I describe how to break down a 4 pole Bessel filter into two 2-pole stages. It's a derivation for laymen, and it becomes obvious when you see it why the coefficients for each stage will be different. -A
