I want to record more than two channels audio signal at the same time. Can anybody suggest one instrument, which is readily available in the market? For example say I have 8 microphones and I want to record all the outputs of the microphone at the same time at 8KHz sampling rate. Thanks Reju This message was sent using the Comp.DSP web interface on www.DSPRelated.com
Instrument for multi-channel audio recording
Started by ●April 7, 2005
Reply by ●April 7, 20052005-04-07
reju_vg wrote:> I want to record more than two channels audio signal at the same time. Can > anybody suggest one instrument, which is readily available in the market? > For example say I have 8 microphones and I want to record all the outputs > of the microphone at the same time at 8KHz sampling rate.Reju, Google on the following product names: MIO 2882 Presonus FirePod MOTU Traveler Mackie Onyx 800R Or, better yet, subscribe to the rec.audio.pro usenet group and look for a recent thread started with the subject: "8 Channel Preamp with Firewire..." I don't think, however, that anything on the market currently will go down to 8 kHz. 44.1 kHz is about as low as it goes for such recording front ends. Most all of these will require a computer. A laptop with Firewire is the best bet and it doesn't have to be much of a system to record 8 channels. Bob -- "Things should be described as simply as possible, but no simpler." A. Einstein
"reju_vg" <reju_vg@yahoo.com> wrote in news:_uudnWdcieMIMMnfRVn-pA@giganews.com:> > I want to record more than two channels audio signal at the same time. > Can anybody suggest one instrument, which is readily available in the > market? For example say I have 8 microphones and I want to record all > the outputs of the microphone at the same time at 8KHz sampling rate. > Thanks > Reju > > > This message was sent using the Comp.DSP web interface on > www.DSPRelated.comIf you want to do signal processing, we have systems that have 8 channels in and 8 channels out. -- Al Clark Danville Signal Processing, Inc. -------------------------------------------------------------------- Purveyors of Fine DSP Hardware and other Cool Stuff Available at http://www.danvillesignal.com
