"tarangdadia@gmail.com" wrote:> > Jim, > > HPF that I am using is [1 -2 1]. I need to have that in place because > systems engineer asked me to ;-). It may not be the best HPF but I > believe systems engineers word for it that will be good enough for our > system.Your original question was and apparently still is how can I optimize the process of filtering with a high pass filter, then a low pass filter, then decimate? My suggestion ignores your question and introduces a fresh idea - why don't you try your proccess in an unoptimized form first to see if its really does what you want. Or, better yet why don't you just consider what happens when you first apply a high pass filter and then a low pass filter. The fact that you have anything left at all will be because the filters are not very good. That seems to me to be more of an accident rather than a matter of design. -jim ----== Posted via Newsfeeds.Com - Unlimited-Uncensored-Secure Usenet News==---- http://www.newsfeeds.com The #1 Newsgroup Service in the World! 120,000+ Newsgroups ----= East and West-Coast Server Farms - Total Privacy via Encryption =----
Interchanging FIR and Decimation operation
Started by ●April 9, 2005
Reply by ●April 11, 20052005-04-11
Bhaskar, I had used that phrase that it is given by system designer cos that is kind of fixed part in the circuit. As I had earlier mentioned that the input samples are all singel bit long and filter is [1 -2 1]. It is just used to readjust the level of the signal and more specifically for error correction. I am talking about multi stage sigma-delta modulator. The output has to be error corrected using [1 -2 1] filter ( or in other word a HPF). My specific band of interest is 0 -> Fs/24. This filter will essentially remove the noise from my pass band and I will have less noise and hence higher SNR in my required bandwidth. I actually was calling AAF as low pass filter, but I did not quite understand why it is not common to call LPF as AAF. Are there any other function other than anti-aliasing? I would appreciate little more insight into this notation. Thanks a lot. Tarang
Reply by ●April 12, 20052005-04-12
Jim, I wanted to optimize the operation such that I can complete the operation with minimum number of computation. I wanted to know whether I can decimate first and then pass it thru filter. But from the responses I have got so far I think this is what I have to do now. My Input is still 64K long. I will have 2 FIR filters, I will convolve them and get another filter. Finally I will get my output samples by computing the taps only which I need at output. I wanted to do something mentioned in this article, using noble identity, but I think with the HPF filter of [1 -2 1] I will not be able to do that. figure 2 in http://cnx.rice.edu/content/m10432/latest/ My aim is not to optimize the filter structure itself but to optimize the whole operation for minimum number of computation. Thanks for ur inputs. Tarang
My 2 cents on the discussion: The high pass filter has a sine-square shape, peaking at omega== pi. This is indeed a high pass filter. according to my calculation its 3-db point is at 2-radians or 114 degrees approximately. You need a lowpass filter which cuts off anything above pi/8. So combining the two filter is a peculiar thing, as you are not even reaching the pass-band of your HPF. Anyway, assuming that your application does need sine-square frequency shaped data, you CAN combine the two filters in any order you like. As both the filters are LTI systems, ---hpf---lpf---> is equivalent to ---lpf---hpf---> And they are as equivalent as anything can be (except for the finite precision effects). However, you can not commute the downsampling operation anywhere, as it is not a LTI system (sigh). So you can try 3 cases: two as mentioned above, and third: convolve the two filters. You will have to watch out for finite precision effects. Regards Manish "tarangdadia@gmail.com" <tarangdadia@gmail.com> wrote in message news:<1113267384.021960.171490@l41g2000cwc.googlegroups.com>...> Bhaskar, > > I had used that phrase that it is given by system designer cos that is > kind of fixed part in the circuit. As I had earlier mentioned that the > input samples are all singel bit long and filter is [1 -2 1]. It is > just used to readjust the level of the signal and more specifically for > error correction. I am talking about multi stage sigma-delta modulator. > The output has to be error corrected using [1 -2 1] filter ( or in > other word a HPF). My specific band of interest is 0 -> Fs/24. This > filter will essentially remove the noise from my pass band and I will > have less noise and hence higher SNR in my required bandwidth. > > I actually was calling AAF as low pass filter, but I did not quite > understand why it is not common to call LPF as AAF. Are there any other > function other than anti-aliasing? I would appreciate little more > insight into this notation. > > Thanks a lot. > Tarang
