Several audio related devices exhibit zero-crossing "flat-spots", regions in their transfer curves near zero crossing where the Y axis output is transitionally flat. Poorly designed push-pull amplifiers exhibit "crossover distortion", magnetic storage has poorly characterized related effects, etc. Question: is this electronic "backlash", to use an old machinist's term, conceptually related (at all?) to the well understood issue of quantizing distortion/ error? And, if so, could classical dither be considered to be a possible remedy? Or, to put the question another way, could dither (of any amount) correct a ferinstance problem of a D/A conversion with zero output below some absolute level, but with correct output above that level? Not an error in estimating a quantized level, but rather zero output below some (unsigned) level. I've approached an acquaintance from rec.audio.pro who's the only person I know capable of answering the question. He didn't have an off-the-cuff answer, but suggested that I ask here, and specifically that I ask Randy Yates, as my best bet. Much thanks for any input, thoughts, insights. Anything currently over my head will be studied into submission. Great newsgroup; very impressive in so many ways, (but sadly over my head) Chris Hornbeck 6x9=42
Conceptual problem about transfer flat-spots
Started by ●April 10, 2005
Reply by ●April 10, 20052005-04-10
On Sun, 10 Apr 2005 06:43:37 GMT, Chris Hornbeck <chrishornbeckremovethis@att.net> wrote:> a D/A conversionVery sorry; thought this was fixed. Meant, of course, "an A/D conversion" Chris Hornbeck 6x9=42
"Chris Hornbeck" <chrishornbeckremovethis@att.net> wrote in message news:ishh51lhk6vb86ovir3469i8fuh8aioh3p@4ax.com...> Several audio related devices exhibit zero-crossing > "flat-spots", regions in their transfer curves near > zero crossing where the Y axis output is transitionally > flat. Poorly designed push-pull amplifiers exhibit > "crossover distortion", magnetic storage has poorly > characterized related effects, etc. > > Question: is this electronic "backlash", to use an old > machinist's term, conceptually related (at all?) to the > well understood issue of quantizing distortion/ error? > And, if so, could classical dither be considered to be > a possible remedy?Hysteresis is the electronic analog to gear lash. It is different from quantizing errors in several respects. First, hysteresis is a property that shows up in the dynamics of a process. That is, it shows up when the process is changing and its effect depends on the past and current trajectory of the process. (Gear lash only shows up when the driven gear suddenly changes to become the driving gear.) Quantization error is minimally dynamic; it would exist even if real devices had no dynamics. It exists because a discrete system cannot represent a continuum. Dithering the input is hardly a "remedy" for quantization error. The dynamic effect of adding random dither before quantizing is to blur the step locations. The effect is to cause sampled values to change value in response to input changes that are too small to cause a change by themselves. If the dither is random and unbiased, the digitized data can be averaged to yield a better estimate of the analog value. This effectively adds another bit or two to the low end of the A/D converter at the expense of adding lag (and phase distortion) to the system. There are two better solutions to the problem: add more bits to the A/D converter or add a preamplifier to raise the analog level to take advantage of more of the dynamic range.
Chris Hornbeck wrote:> Several audio related devices exhibit zero-crossing > "flat-spots", regions in their transfer curves near > zero crossing where the Y axis output is transitionally > flat. Poorly designed push-pull amplifiers exhibit > "crossover distortion", magnetic storage has poorly > characterized related effects, etc. > > Question: is this electronic "backlash", to use an old > machinist's term, conceptually related (at all?) to the > well understood issue of quantizing distortion/ error? > And, if so, could classical dither be considered to be > a possible remedy? > > Or, to put the question another way, could dither (of any > amount) correct a ferinstance problem of a D/A conversion > with zero output below some absolute level, but with correct output > above that level? Not an error in estimating a quantized > level, but rather zero output below some (unsigned) level. > > I've approached an acquaintance from rec.audio.pro who's > the only person I know capable of answering the question. > He didn't have an off-the-cuff answer, but suggested that > I ask here, and specifically that I ask Randy Yates, as my > best bet. > > Much thanks for any input, thoughts, insights. Anything currently > over my head will be studied into submission. > > Great newsgroup; very impressive in so many ways, > (but sadly over my head) > > Chris Hornbeck > 6x9=42One manifestation of backlash is failure of a mechanical system's output to immediately follow a reversal of the input. I call the "flat spot" you describe in poorly biased class-B amplifiers "center clipping". It's not conceptually the same as backlash at all. On the other hand, like center clipping, quantizing loss is a failure of the output to move while the input continues in the same direction. For me, the similarity ends there, and I derive no insight from connecting the phenomena. Jerry -- Engineering is the art of making what you want from things you can get. �����������������������������������������������������������������������
Chris Hornbeck wrote:> Several audio related devices exhibit zero-crossing > "flat-spots", regions in their transfer curves near > zero crossing where the Y axis output is transitionally > flat. Poorly designed push-pull amplifiers exhibit > "crossover distortion", magnetic storage has poorly > characterized related effects, etc. > > Question: is this electronic "backlash", to use an old > machinist's term, conceptually related (at all?) to the > well understood issue of quantizing distortion/ error?Only in as much as there is a flat spot involved, and an error between the input and the output representation.> And, if so, could classical dither be considered to be > a possible remedy?Yes.> > Or, to put the question another way, could dither (of any > amount) correct a ferinstance problem of a D/A conversion > with zero output below some absolute level, but with correct output > above that level? Not an error in estimating a quantized > level, but rather zero output below some (unsigned) level.Probably not in either this case or your (corrected) A/D case -- reason being that dither _can_ be used to force a correct average value, but only if you can bracket the intended value. Obviously if your intended value is outside of the range achievable then you're out of luck.> > I've approached an acquaintance from rec.audio.pro who's > the only person I know capable of answering the question. > He didn't have an off-the-cuff answer, but suggested that > I ask here, and specifically that I ask Randy Yates, as my > best bet. > > Much thanks for any input, thoughts, insights. Anything currently > over my head will be studied into submission. > > Great newsgroup; very impressive in so many ways, > (but sadly over my head) > > Chris Hornbeck > 6x9=42-- Tim Wescott Wescott Design Services http://www.wescottdesign.com
John E. Hadstate wrote: --snip--> Dithering the input is hardly a "remedy" for quantization > error. The dynamic effect of adding random dither before > quantizing is to blur the step locations. The effect is to > cause sampled values to change value in response to input > changes that are too small to cause a change by themselves. > If the dither is random and unbiased, the digitized data can > be averaged to yield a better estimate of the analog value. > This effectively adds another bit or two to the low end of > the A/D converter at the expense of adding lag (and phase > distortion) to the system. > > There are two better solutions to the problem: add more bits > to the A/D converter or add a preamplifier to raise the > analog level to take advantage of more of the dynamic range. >Neither of which can be used if you've already used up your power and space claim with the smallest, lowest power, decently fast converter chips that will fit in the design, and have chosen appropriate gain levels. In that case then oversampling a 16-bit ADC and averaging works quite well to extend the ADC resolution (_not_, unfortunately, it's accuracy). This technique is enhanced by the fact that almost any ADC that you can get that is at the limit of the current market's precision range will have random dither of the least significant bits thrown in _for free_! It'll be called "noise" and it'll be in small print on the data sheet, but it'll be there. -- Tim Wescott Wescott Design Services http://www.wescottdesign.com
On Sun, 10 Apr 2005 12:20:14 -0700, Tim Wescott <tim@wescottnospamdesign.com> wrote:> dither _can_ be used to force a correct average value, but >only if you can bracket the intended value. Obviously if your intended >value is outside of the range achievable then you're out of luck.Thanks, Tim, this helps a lot to clear my thinking. Thanks also to John and Jerry for reminding me that magnetic hysteresis is a dynamic process. My interest springs from iron-cored transformers, and now I'm wondering if the convention solution to B-H zero crossing flat spot, DC bias, is even approprite. I hadn't thought that it was even related to hysteresis. Thanks! Chris Hornbeck 6x9=42
Chris Hornbeck wrote: > [snip]> > Thanks, Tim, this helps a lot to clear my thinking. Thanks > also to John and Jerry for reminding me that magnetic > hysteresis is a dynamic process. >Is not "hysteresis" by definition "dynamic"? I guess I'm *presuming* "path dependence"="dynamic".
Reply by ●April 11, 20052005-04-11
On Sun, 10 Apr 2005 21:06:33 -0500, Richard Owlett <rowlett@atlascomm.net> wrote:>> for reminding me that magnetic >> hysteresis is a dynamic process.>Is not "hysteresis" by definition "dynamic"? >I guess I'm *presuming* "path dependence"="dynamic".Thanks for your thoughts. I'm still slightly uncertain whether magnetic hysteresis is the physical phenomenon I'm interested in. Iron cored magnetics have a zero- crossing flat spot in their B-H curves that is often ascribed to hysteresis. I'd come to believe that that wasn't the case, but now am a-sea without a paddle. If, as several knowledgeable posters have said, the flat spot is an artifact of hysteresis, then I need to work on my meager mental model some (a lot) more. Thanks to all, Chris Hornbeck 6x9=42
"Chris Hornbeck" <chrishornbeckremovethis@att.net> wrote in message news:0coj51hjufkagslg58e96kt64h8q7cl8fe@4ax.com...> On Sun, 10 Apr 2005 21:06:33 -0500, Richard Owlett > <rowlett@atlascomm.net> wrote: > > > If, as several knowledgeable > posters have said, the flat spot is an artifact of > hysteresis, then I need to work on my meager mental model > some (a lot) more.Chris, I don't see where anyone said that...... The description you gave: "Several audio related devices exhibit zero-crossing "flat-spots", regions in their transfer curves near zero crossing where the Y axis output is transitionally flat. Poorly designed push-pull amplifiers exhibit "crossover distortion", ..." seems to be clear enough and the principle is at least implied by the amplifier example. From the description and experience would suggest a "single trajectory plot" - that is, for every value of x, there is a single value of y with a shape like this: | | / | / | / | / | / | / | / | / | / | / -----------------+----|----+------------------ / | / | / | / | / | / | / | / | / | / | / | / | | Hysteresis and backlash have a different kind of plot where there are families of curves such that for every curve and for every value of x, there are (mostly) two values of y (except at the end points). Poorly meshed gears are a good example. One can drive the gear train in one direction - when the direction is reversed the drive gear must move through the dead space until it engages the driven gear once more. This means that the driven gear will stop moving while the drive gear does move. The result is sort of an S-shaped double curve. Note that there is one double curve for each value of maximum excursion and at each end of the excursions. Thus, an infinity of round-trip curves with a general shape like this: | | ----<-----+ | / / | / / | / / |/ / / / /| / / | / / | / / | / -----------------/----|----/------------------ / | / / | / / | / / |/ / / / /| / / | / / | / / | / / | / / | +---->----- | | Unless there is some known relationship between hysteresis and a single-curve zero-crossing flat spot, I think the term "hysteresis" doesn't belong in this discussion. Fred
