Howdy, I'm trying to get the DCT and IDCT algorithm correct for MPEG-4 encoding/decoding. Following the DCT equation that I've put here: http://www.teamearth.com/wiki/Main/MPEG4 , I generated the following DCT and IDCT algorithms: void dct(int data[8][8]) { int u,v,x,y; double temp[8][8] = {{0}}; for (u=0; u<8; u++) { for (v=0; v<8; v++) { for (x=0; x<8; x++) { for (y=0; y<8; y++) { temp[u][v] += data[x][y] * cos((2*x+1)*u*PI/16.0) * cos((2*y+1)*v*PI/16.0); } } } } for (u=0; u<8; u++) { for (v=0; v<8; v++) { if (u==0) temp[u][v] *= .7071; if (v==0) temp[u][v] *= .7071; data[u][v] = floor(temp[u][v] / 16.0+0.5); } } } void idct(int data[8][8]) { int u,v,x,y; double temp[8][8] = {{0}}; for (x=0; x<8; x++) { for (y=0; y<8; y++) { for (u=0; u<8; u++) { for (v=0; v<8; v++) { temp[x][y] += data[u][v] * cos((2*x+1)*u*PI/16.0) * cos((2*y+1)*v*PI/16.0); if (u==0) { temp[x][y] *= .7071; } if (v==0) { temp[x][y] *= .7071; } } } } } for (x=0; x<8; x++) { for (y=0; y<8; y++) { data[x][y] = floor(temp[x][y] / 16.0 + 0.5); } } } When I give DCT an 8x8 matrix of all 10s, I get back a matrix with a 20 for the DC and 0s for the AC. When I send that to the AC, I get all 0s back. Does anyone see what my problem is? Or am I approaching this incorrectly? Thanks, J.R. Test runs: Original Matrix 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 After DCT 20 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 After IDCT 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
DCT & IDCT algorithm problems
Started by ●April 10, 2005
Reply by ●April 10, 20052005-04-10
Problem 1: 2/N = 1/4, not 1/16. Problem 2: temp[u][v] += data[x][y] * cos((2*x+1)*u*PI/16.0) * cos((2*y+1)*v*PI/16.0); I think you can tell what's wrong now that I've pinpointed the line. They were rather annoying to track down; such small things are so easy to overlook. :)
Whoops never mind that second part; there was a problem with my own
copied code and I got mixed up :). The real problem is with the lines:
There is a flaw in your logic here that doesn't have anything to do
with mistyped variables or the like. I could tell you, but it'll be
more fun if you see it yourself!
Well I had that originally and the result is even more unrealistic than with 16. (Also I had some reason as to why it was 16, but I've stared at it so long I can't remember why now). Instead of an array with a DC of 20 and all 0s for AC, you get DC of 80 and 0s for all AC when you divide by 4. Regardless, sending 80 and all 0s to the IDCT function still results in all 0s and leaves me just as confused. Thanks, J.R.
It might be more fun for you... but my eyes have gone over it too many times to see the error. I'd appreciate you just pointing it out. I'm just trying to understand it all. Thanks, J.R.
Hehe, okay. The problem is that the order is wrong. The *= hits not only the term that you just +='d, but all terms that were +='d before that. I'm the same guy as before, but Google Groups was giving me a headache. <groups@jrmanes.com> wrote in message news:1113180020.027476.296660@g14g2000cwa.googlegroups.com...> > It might be more fun for you... but my eyes have gone over it too many > times to see the error. I'd appreciate you just pointing it out. I'm > just trying to understand it all. > Thanks, > J.R. >
Maybe that's a little cryptic, so here's what I mean in code:
double tempValue = data[u][v] * cos((2*x+1)*u*PI/16.0) *
if (u==0) { tempValue *= .7071; }
if (v==0) { tempValue *= .7071; }
temp[x][y] += tempValue ;
"James Park" <jpark37@hotmail.com> wrote in message
news:yt6dnbh3wNWnVMTfRVn-hQ@comcast.com...
>> Thanks,
>> J.R.
OK, I think I see what you mean. I removed those two lines, and move
the *= section down to where I go through the loop a second time:
if (x==0) { temp[x][y] *= .7071; }
if (y==0) { temp[x][y] *= .7071; }
data[x][y] = floor(temp[x][y] / 4.0 + 0.5);
When I do that, I get the 10 back as the DC, but different ACs:
Original Matrix
After DCT
80 0 0 0 0 0 0 0
0 0 0 0 0 0 0 0
0 0 0 0 0 0 0 0
0 0 0 0 0 0 0 0
0 0 0 0 0 0 0 0
0 0 0 0 0 0 0 0
0 0 0 0 0 0 0 0
0 0 0 0 0 0 0 0
After iDCT
10 14 14 14 14 14 14 14
14 20 20 20 20 20 20 20
Is this right now? Or should I be getting the original matrix back
after doing IDCT?
Thanks,
J.R.
The matrix should come back to normal. I didn't explain it too well; just see code in my other post (which judging by your post time, you probably already have come across). <groups@jrmanes.com> wrote in message news:1113181124.569060.165440@z14g2000cwz.googlegroups.com...> > OK, I think I see what you mean. I removed those two lines, and move > the *= section down to where I go through the loop a second time: > > ... > for (v=0; v<8; v++) { > temp[x][y] += data[u][v] * cos((2*x+1)*u*PI/16.0) * > cos((2*y+1)*v*PI/16.0); > } > } > } > } > > for (x=0; x<8; x++) { > for (y=0; y<8; y++) { > if (x==0) { temp[x][y] *= .7071; } > if (y==0) { temp[x][y] *= .7071; } > data[x][y] = floor(temp[x][y] / 4.0 + 0.5); > } > } > > When I do that, I get the 10 back as the DC, but different ACs: > > Original Matrix > 10 10 10 10 10 10 10 10 > 10 10 10 10 10 10 10 10 > 10 10 10 10 10 10 10 10 > 10 10 10 10 10 10 10 10 > 10 10 10 10 10 10 10 10 > 10 10 10 10 10 10 10 10 > 10 10 10 10 10 10 10 10 > 10 10 10 10 10 10 10 10 > > After DCT > 80 0 0 0 0 0 0 0 > 0 0 0 0 0 0 0 0 > 0 0 0 0 0 0 0 0 > 0 0 0 0 0 0 0 0 > 0 0 0 0 0 0 0 0 > 0 0 0 0 0 0 0 0 > 0 0 0 0 0 0 0 0 > 0 0 0 0 0 0 0 0 > > After iDCT > 10 14 14 14 14 14 14 14 > 14 20 20 20 20 20 20 20 > 14 20 20 20 20 20 20 20 > 14 20 20 20 20 20 20 20 > 14 20 20 20 20 20 20 20 > 14 20 20 20 20 20 20 20 > 14 20 20 20 20 20 20 20 > 14 20 20 20 20 20 20 20 > > > Is this right now? Or should I be getting the original matrix back > after doing IDCT? > > Thanks, > J.R. >
