Pardon pun;} Rune Allnor wrote: > Simo S�rkk� <simo.sarkka@hut.fi> wrote in message news:<Pine.OSF.4.58.0408271231210.280764@zeus.lce.hut.fi>... > >>Hi, >> >>What is the reason to that dicrete IIR filters are usually >>designed using impulse invariant transformation (= Euler >>integration) or bilinear transformation (= trapetzoidal >>integration) instead of the closed form solution that >>can be computed by the matrix exponential function? > > > You need to keep an eye on the history of DSP to see the full reasons. > When DSP was in its infancy (form an operational, not necessarily > theoretical, point of view), the engineers who designed and implemented > the filters were trained as "analog" engineers, and had little if any > formal or theoretical training in designing discrete-time systems. > These engineers were trained to think in terms of Butterorth, Chebychev, > etc., filters, and knew how to design the filters from an *analog* spec. > > [snip] > > Once DSP "matured" in the sense that DSP was taught in courses in > universities and engineering schools, IIR design by analog template > was kept as a link to the world of continuous time, while purely > discrete-time design methods were developed.[snip] Now I understand why experts confuse me and I them when I ask DSP Newbie questions. I have a profoundly analog formal background ( computers have lots of 6J6's, 12AX7's and 5U4's don't they ;) which I never used in 'real' world. I was "out of it" ( yeah another pun ) for ~ 30 yrs. Now there a computational tools ( eg Scilab ) that make strange computations possible. I've asked questions about "arbitrarily shaped frequency response filters". I kept getting answers assuming "arbitrary" referred to amount of ripple in passband/stopband. What I *MEANT* was an *ARBITRARY* form of response vs frequency characteristic. Correlation to a *physically* realizable system being irrelevant. Similarly for windowing functions. When I've said an "arbitrarily shaped function" {be it time or frequency domain} my only implied restriction was that it be continuous ( would 'smooth' be better term).
Window of understanding opened ONCE WAS [Re: Imp.inv/bilinear trans. vs. expm()]
Started by ●August 30, 2004
Reply by ●August 31, 20042004-08-31
Richard Owlett <rowlett@atlascomm.net> wrote in message news:<10j70psl0g15r9d@corp.supernews.com>...> I've asked questions about "arbitrarily shaped frequency response > filters". I kept getting answers assuming "arbitrary" referred to > amount of ripple in passband/stopband. What I *MEANT* was an > *ARBITRARY* form of response vs frequency characteristic. Correlation > to a *physically* realizable system being irrelevant. > > Similarly for windowing functions. > > When I've said an "arbitrarily shaped function" {be it time or > frequency domain} my only implied restriction was that it be > continuous ( would 'smooth' be better term)."Continuous" is not a good term to use when discussing discrete-time systems... As for "arbitrary" filters, some clarification of the terminology might be in useful. First, there are methods available for designing "arbitrary" filters in frequency domain (see below). However, the time-domain response of these filters are left unspecified, except for the resulting filters being linear-phase FIRs. One could do some fancy fiddeling in time domain (seismic data processing is infamous for that), with un-specified consequences in frequency domain. So you can do "arbitrary" stuff in *either* time domain *or* frequency domain. The price paid for fancy action in one domain is loss of control, to some extent, in the other [*]. Having said that, the matlab signal processing toolbox provides the Remez algorithm for designing "arbitrary" filters in frequency domain:>> help remezREMEZ Parks-McClellan optimal equiripple FIR filter design. B=REMEZ(N,F,A) returns a length N+1 linear phase (real, symmetric coefficients) FIR filter which has the best approximation to the desired frequency response described by F and A in the minimax sense. F is a vector of frequency band edges in pairs, in ascending order between 0 and 1. 1 corresponds to the Nyquist frequency or half the sampling frequency. A is a real vector the same size as F which specifies the desired amplitude of the frequency response of the resultant filter B. The desired response is the line connecting the points (F(k),A(k)) and (F(k+1),A(k+1)) for odd k; REMEZ treats the bands between F(k+1) and F(k+2) for odd k as "transition bands" or "don't care" regions. Thus the desired amplitude is piecewise linear with transition bands. The maximum error is minimized. Scilab, or some DSP extension of it, might have available some version of the Remez algorith. Another possible method to design not quite as arbitrary but still flexible filters, is demonstrated in chapter 7.3 of Oppenheim & Schafer: Discrete-Time Signal Processing Prentice-Hall, 1999. Rune
Rune Allnor may be paraphrased by: > ... some clarification of the terminology might be in useful. OK, 'might' much to mild ;} Rune stated: > > "Continuous" is not a good term to use when discussing discrete-time > systems... > OK, just how does one UNAMBIGUOUSLY refer to digitized version of a analog domain function function which meets ALL traditional definitions of 'continuous' Specifically: 1. satisfys "Mean value theorem" [ Now, ~40 yrs later I'm beginning to understand why my 1st semester calculus instructor thought it was important. ] 2. infinetly (spelling?) differentiable
On Tue, 31 Aug 2004 14:13:19 -0500, Richard Owlett <rowlett@atlascomm.net> wrote:> Rune Allnor may be paraphrased by: > > > ... some clarification of the terminology might be in useful. > > OK, 'might' much to mild ;} > > Rune stated: > > > > > "Continuous" is not a good term to use when discussing discrete-time > > systems... > > > > > OK, just how does one UNAMBIGUOUSLY refer to digitized version of a > analog domain function function which meets ALL traditional > definitions of 'continuous' > Specifically: > 1. satisfys "Mean value theorem" > [ Now, ~40 yrs later I'm beginning to understand why my 1st > semester calculus instructor thought it was important. ]The MVT is defined in terms of differentiable functions, not the other way 'round.> 2. infinetly (spelling?) differentiable >A function f is said to be continuous at the point x_0 if: Lim f(x) = f(x_0) x --> x_0 A function need not be continuously differentiable, and in fact a function can be continuous ONLY at x_0. Continuity and differentiability are different things. DAGS on the Blancmange function which is continuous everywhere but differentiable nowhere. If you take something called either "Real Analysis" or "Advanced Calculus" you run into all sorts of odd-duck functions as examples such as. "Define f such that f is defined everywhere but continuous nowhere" which yields f = 0 if x is rational 1 if x is irrational Which can easily be shown to satisfy the conditions of the problem.
Richard Owlett wrote:> Rune Allnor may be paraphrased by: > > > ... some clarification of the terminology might be in useful. > > OK, 'might' much to mild ;} > > Rune stated: > > > > > "Continuous" is not a good term to use when discussing discrete-time > > systems... > > > > > OK, just how does one UNAMBIGUOUSLY refer to digitized version of a > analog domain function function which meets ALL traditional definitions > of 'continuous'You just did. There's no single word.> Specifically: > 1. satisfys "Mean value theorem" > [ Now, ~40 yrs later I'm beginning to understand why my 1st semester > calculus instructor thought it was important. ] > 2. infinetly (spelling?) differentiableWhy infinitely differentiable? Even the first derivative of a continuous function need not be continuous. Indeed, it may not even exist at some points. If a function has a value at a particular point that depends on the whether the independent variable is increasing or decreasing, the function is continuous; otherwise not. A digitized signal can be continuous only if it never varies or if there are an infinite number of quantization levels crammed into a finite dynamic range using an infinite sampling frequency. Few busses are wide enough and few devices fast enough to accommodate the second kind. :^) A signal that doesn't meet either of those criteria necessarily has gaps and/or jumps, breaking its discontinuity. Jerry -- Engineering is the art of making what you want from things you can get. �����������������������������������������������������������������������
Reply by ●September 1, 20042004-09-01
Richard Owlett <rowlett@atlascomm.net> wrote in message news:<10j9j7d1mi7t3aa@corp.supernews.com>...> Rune Allnor may be paraphrased by: > > > ... some clarification of the terminology might be in useful. > > OK, 'might' much to mild ;} > > Rune stated: > > > > > "Continuous" is not a good term to use when discussing discrete-time > > systems... > > > > > OK, just how does one UNAMBIGUOUSLY refer to digitized version of a > analog domain function function which meets ALL traditional > definitions of 'continuous'One can't. Rick's chapter 1 has a very nice discussion about these things, in particular his figure 1-1. Some aspects of the continuous-time signal are lost when we sample it. One can only hope the important aspects are preserved. That's why the Nyquist sampling criterion is so important.> Specifically: > 1. satisfys "Mean value theorem" > [ Now, ~40 yrs later I'm beginning to understand why my 1st > semester calculus instructor thought it was important. ]The versions of the MVT I know of, explicitly recuire the functions to be continuous. A discrete-time signal is not continuous, so the MVT can not be applied. At least not the naive versions I know of. I don't know where the MVT fits in, in mathematics. If it is derived from concepts of general Hilbert space theory, there may exist a discrete-time version of it somewhere. If so, I don't know about it. If the MVT is derived from concepts of the theory of continuous functions, there is probably no way to extend it to discrete functions.> 2. infinetly (spelling?) differentiableWell... it might be *formally* possible to use some sort of continuous representation of the discrete signal, something along the lines of inf inf x[n] = sum integral x(tau)D(tau-nT) dtau (1) n=-inf -inf x[n] - discrete sequence x(t) - continuous function D(t) - Dirac's delta function T - Sampling period I think I have seen somewhere (I can't remember the reference off the top of my head) that the Delta function is *formally* differentiable as something like dD(t)/dt= lim D(t+e) - D(t-e), e->0 but I can't see how this can be *practically* useful in any meaningful way. Rune
Charles wrote: ...> ...and in fact a function can be continuous ONLY at x_0.That doesn't make sense. If a function is continuous in x_0, it is also continuous in a small open interval containing x_0.
Richard Owlett wrote:> Rune Allnor may be paraphrased by: > > > ... some clarification of the terminology might be in useful. > > OK, 'might' much to mild ;} > > Rune stated: > > > > > "Continuous" is not a good term to use when discussing discrete-time > > systems... > > > > > OK, just how does one UNAMBIGUOUSLY refer to digitized version of a > analog domain function function which meets ALL traditional definitions > of 'continuous' > Specifically: > 1. satisfys "Mean value theorem" > [ Now, ~40 yrs later I'm beginning to understand why my 1st semester > calculus instructor thought it was important. ] > 2. infinetly (spelling?) differentiableRichard, 1. Bandlimited integrable functions are smooth (ie. infinitely often differentiable). If you periodically extend the spectrum, and calculate the Fourier series coefficients of this new periodic spectrum, these coefficients are a (temporal) sampling of the bandlimited function. 2. Conversely, if you have a sumable stream of numbers and calculate the DTFT you get a periodic spectrum. If you (symmetrically about 0) ideally bandpass this spectrum (by multiplying the spectrum with a rectangle function), and calculate the inverse FT of the bandpassed spectrum you get a smooth, real valued function. Therefore it makes perfect sense to speak of the continuity, or differentiability, or differential, or whatever, of a discrete set of numbers if you mean the corresponding property of the uniquely defined smooth function which you get via 2 (commonly known as digital-to-analogue conversion). If you are working with a set of numbers obtained by sampling a function (as in 1), the uniqueness is only preserved if you make sure that the Nyquist criterium was met, ie. you periodically extended the spectrum such that no overlap occured. FWIW, Andor
On Wed, 01 Sep 2004 18:55:09 +0200, Andor Bariska <an2or@nospam.net> wrote:> Charles wrote: > ... > >> ...and in fact a function can be continuous ONLY at x_0. > > That doesn't make sense. If a function is continuous in x_0, it is also > continuous in a small open interval containing x_0. >Ah . .right. I mangled that bit.
U-CDK_CHARLES\Charles wrote:> On Wed, 01 Sep 2004 18:55:09 +0200, Andor Bariska <an2or@nospam.net> wrote: > >>Charles wrote: >>... >> >> >>>...and in fact a function can be continuous ONLY at x_0. >> >>That doesn't make sense. If a function is continuous in x_0, it is also >>continuous in a small open interval containing x_0. >> > > > Ah . .right. I mangled that bit. >Let f(x) = x if x is rational, and f(x) = -x if x is irrational. Then f is continuous at 0 but discontinuous everywhere else. Now back to your regularly-scheduled DSP programming.... Bob Beaudoin
