Delta-sigma ADC question
Started by soos ●April 11, 2005
Hello,
I am looking for an ADC 16+ bit resolution that would sample 64 chanels
at the
rate of 25 Khz each. switching is planned to be done with a mux.
I have heard that the sigma delta ADCs are not appropriate for this
task
Questions are:
1.If indeed they are'nt ,can some one explain why?
2.if not can any one point a specific SD ADC that can stand they rates
mentioned.
Thanks in advace,
Marc.
In article <1113255980.248460.27760@o13g2000cwo.googlegroups.com>,
marcsok@yahoo.com says...
> Hello, > > I am looking for an ADC 16+ bit resolution that would sample 64 chanels > at the > rate of 25 Khz each. switching is planned to be done with a mux. > > I have heard that the sigma delta ADCs are not appropriate for this > task > > Questions are: > > 1.If indeed they are'nt ,can some one explain why? > 2.if not can any one point a specific SD ADC that can stand they rates > mentioned.
Delta sigma converters generally require several times as long to get a stable output when switching inputs with a multiplexer because the internal digital filters require settling time. You are looking at collecting 64 x 25000 samples per second or 1.6MSamples per second. Multiply that times 3 for the extra settling time, and you're going to need a REALLY fast clock for the converter, and a very fast multiplexer. 64 channels times 25KHz is a problem better suited to multiple faster converters. The RADAR, SONAR, and ultrasound folks might have a solution, but it won't be cheap! Mark Borgerson
soos wrote:
> Hello, > > I am looking for an ADC 16+ bit resolution that would sample 64 > chanels at the > rate of 25 Khz each. switching is planned to be done with a mux. > > I have heard that the sigma delta ADCs are not appropriate for this > task > > Questions are: > > 1.If indeed they are'nt ,can some one explain why? > 2.if not can any one point a specific SD ADC that can stand they rates > mentioned. >
SD-ADCs have a latency(pipeline delay) because the conversion needs a couple of clock cycles to be finished. Look in the datasheet, usually 3 to 24 samples are needed. You can multiplex the input, but then have to wait those cycles until a meaningful data is output. The problem with so many inputs will be that now the output data has to be really fast, in fact the rate would need to be 64 * 25k * delay. The AD10678 would be possible, with 11 cycles delay you will need 17.6MHz clock, well below the 80MHz capability, but the price... A much better decision would be a SAR-based converter, which do not have a pipeline delay. Maybe you could come along with one or two AD7655, which has already a 4:1 Input mux, so your analog switches are reduced. 2 channels are sampled simultaneously, which might be of importance for certain measurements.
> Thanks in advace, > Marc.
welcome -- ciao Ban Bordighera, Italy
soos wrote:
> > I am looking for an ADC 16+ bit resolution that would sample 64 > chanels at the rate of 25 Khz each. switching is planned to be > done with a mux. > > I have heard that the sigma delta ADCs are not appropriate for > this task > > Questions are: > > 1.If indeed they are'nt ,can some one explain why? > 2.if not can any one point a specific SD ADC that can stand they > rates mentioned.
Delta modulation generally follows changes in the input signal, with significant limitations on the slew rate. A mux implies wholesale alteration in that value, and thus is not suitable in front of delta modulation. -- "If you want to post a followup via groups.google.com, don't use the broken "Reply" link at the bottom of the article. Click on "show options" at the top of the article, then click on the "Reply" at the bottom of the article headers." - Keith Thompson
On 11 Apr 2005 14:46:20 -0700, "soos" <marcsok@yahoo.com> wrote:
>I am looking for an ADC 16+ bit resolution that would sample 64 chanels >at the rate of 25 Khz each. switching is planned to be done with a mux. > >I have heard that the sigma delta ADCs are not appropriate for this task
In any sampled systems, the input spectrum must be limited to below fs/2 in order to avoid aliases. In SD ADCs, this bandwidth limitation is more or less inherent due to the way the SD converter works and very little or no external low pass filtering is required. In a multiplexed system, the multiplexer becomes the sampler and the low pass filtering has to be moved in front on the multiplexer and implemented on _every_ input channel. Implementing 64 analog low pass filters with precision resistors and capacitors or SCFs will also add quite a lot to the system cost. With current low cost of SD ADCs, using 64 separate ADCs might be more cost effective than using a super fast ADC, a multiplexer and signal conditioning for all the 64 input channels. Paul
Hi Mark,
Maybe you can enlighten me a bit here. Back in my old school/analog
days, I was taught that settling time is inversely proportional to
bandwidth. If I have a Fn Hz channel (from sampling at 2*Fn samples
per second), then why wouldn't the settling time of an input be the
same whether I used delta sigma or flash converter techniques?
I've heard this flavor of argument for years (decades?) against
using delta sigma converters in multi-channel systems. It must
be true - the folks who have used them would know (I have not). But
as I've just queried, there's something that doesn't seem to add up,
in my view.
--RY
Mark Borgerson <mborgerson@comcast.net> writes:
> In article <1113255980.248460.27760@o13g2000cwo.googlegroups.com>, > marcsok@yahoo.com says... > > Hello, > > > > I am looking for an ADC 16+ bit resolution that would sample 64 chanels > > at the > > rate of 25 Khz each. switching is planned to be done with a mux. > > > > I have heard that the sigma delta ADCs are not appropriate for this > > task > > > > Questions are: > > > > 1.If indeed they are'nt ,can some one explain why? > > 2.if not can any one point a specific SD ADC that can stand they rates > > mentioned. > > Delta sigma converters generally require several times as long to > get a stable output when switching inputs with a multiplexer because > the internal digital filters require settling time. > > You are looking at collecting 64 x 25000 samples per second or > 1.6MSamples per second. Multiply that times 3 for the extra settling > time, and you're going to need a REALLY fast clock for the converter, > and a very fast multiplexer. > > 64 channels times 25KHz is a problem better suited to multiple > faster converters. The RADAR, SONAR, and ultrasound folks might > have a solution, but it won't be cheap! > > Mark Borgerson > >
-- Randy Yates Sony Ericsson Mobile Communications Research Triangle Park, NC, USA randy.yates@sonyericsson.com, 919-472-1124
In article <1113255980.248460.27760@o13g2000cwo.googlegroups.com>, soos wrote:
It is rather difficult to find a sigma-delta ADC for that kind of sampling frequency even for a single channel. Of course, many inexpensive audio converters claim something like "192 ks/s, 24 bits", but this is not the complete truth. If you want to use such a converter in a multiplexed system, you'll face the fact that the bandwith limitation (96 kHz) effectively limits the settling time when multiplexing. The worst case is when you have two multiplexed signals which alternate between minimum and maximum. The square wave produced this way has very significant high frequency components. If you want to sample this signal down to 16 bits, the bandwidth has to be way larger than the multiplexing frequency. So, the first problem is the bandwidth-limiting nature of sigma-delta converters. Other converter types (SAR, flash) don't have this problem, their bandwidth may be much wider than the sampling frequency (which in many cases is a problem per se). Another significant problem with sigma-delta converters is their bad DC behaviour. The "el cheapo" audio converters have rather impressive dynamic performance, but when it comes to measuring DC levels, there may be hundreds of LSBs of error and drift, as those parameters are insignificant in audio processing. There are fast DC-accurate sigma-deltas as well. For example, the TI (BB) ADS1606 seems to offer 16 bits at 5 Ms/s and 2.45 MHz bandwidth. Oh, the price is $30 each, and you'd still need many of these in parallel (check the data sheet to get the idea of the settling time). There are some less expensive converters with dozens of kilosamples per second. However, they could sample only one channel at a time, and the price is still well above that of an inexpensive audio sigma-delta. I'd recommend using the approach of one converter per channel. This makes the sampling requirements much easier. If you want to sample something at 64 x 25 kHz = 1.6 MHz at 16 bits, the input impedance has to be low, but at 25 kHz there should be no problems. If you really want to multiplex, then SAR converters are better. There are 16-bit SAR converters with megasample-range throughput. Using one of these could possibly solve the problem with a single converter and a huge multiplexer. (Beware, there are even SAR converters with poor DC performance!) The solution this way would be less expensive than with per-channel converters, but the design is more complicated (multiplexers, buffers, etc. with 16-bit accuracy). In any case, you'll need to study the converter data very carefully, as very often the datasheets are rather shy when it comes to the deficiencies of the converters. - Ville -- Ville Voipio, Dr.Tech., M.Sc. (EE)
Ville Voipio <vvoipio@kosh.hut.fi> writes:
> sigma delta sigma delta sigma delta [...]
It's "delta sigma". -- Randy Yates Sony Ericsson Mobile Communications Research Triangle Park, NC, USA randy.yates@sonyericsson.com, 919-472-1124
In article <xxpfyxwb6cn.fsf@usrts005.corpusers.net>, Randy Yates wrote:
> Maybe you can enlighten me a bit here. Back in my old school/analog > days, I was taught that settling time is inversely proportional to > bandwidth. If I have a Fn Hz channel (from sampling at 2*Fn samples > per second), then why wouldn't the settling time of an input be the > same whether I used delta sigma or flash converter techniques?
If the bandwidth is the same, then there is no difference between the converters. But if you take a typical SAR converter, its analog bandwidth (before the sampling stage) is typically much larger than the sampling rate. For example, the AD7476 (1 Ms/s, 12-bit SAR ADC) has 1 Ms/s maximum sampling rate and 6.5 MHz full-power (3 dB) bandwidth. This bandwidth will give LSB settling at the maximum sampling rate. On the other hand, the (pseudo-analog) bandwidth of a sigma-delta is almost exactly Fs/2. This means in this case there is 1:10 ratio between the bandwidths, and this makes the difference in settling time. - Ville -- Ville Voipio, Dr.Tech., M.Sc. (EE)
I read in sci.electronics.design that Randy Yates
<randy.yates@sonyericsson.com> wrote (in
<xxpy8bo9l2n.fsf@usrts005.corpusers.net>) about 'Delta-sigma ADC
question', on Tue, 12 Apr 2005:
>Ville Voipio <vvoipio@kosh.hut.fi> writes: >> sigma delta sigma delta sigma delta [...] > >It's "delta sigma".
Both terms are used. I once thought they were different configurations, but it appears not. OTOH, the digma-selta converter has a higher alcohol content. -- Regards, John Woodgate, OOO - Own Opinions Only. There are two sides to every question, except 'What is a Moebius strip?' http://www.jmwa.demon.co.uk Also see http://www.isce.org.uk
