Andre <no_spam@fischer-zoth.de> wrote in news:d3gkoo$57c$02$1@news.t- online.com:> Additionally, you might have to deal with delays. Typical delay times > between analog input and digital output of delta-sigma ADs are around15> samples! This might make synching mux timing and sampled data hard todo.>This delay is exactly why SAR converters are used in feedback systems. A very big advantage to sigma delta converters is that the analog antialiasing filters are trivial since the actual sample rate is much high than the "effective" sample rate. The internal digital filters may have stopband attenuation of 90dB at something near 1/2 the "sample rate" This of course is a major reason for the added delay. The better converters have better filters which have more delay. You may find that low cost sigma delta converters are still a better choice than a muxed SAR. You can find 4 channel devices that smaple at 100kHz or 200kHz for reasonable cost. -- Al Clark Danville Signal Processing, Inc. -------------------------------------------------------------------- Purveyors of Fine DSP Hardware and other Cool Stuff Available at http://www.danvillesignal.com
Delta-sigma ADC question
Started by ●April 11, 2005
Reply by ●April 12, 20052005-04-12
John Larkin wrote:> On Tue, 12 Apr 2005 10:33:59 -0500, Rob Gaddi > <rgaddi@bcm.YUMMYSPAMtmc.edu> wrote: > > >>Ville Voipio wrote: >> >>>Actually, it would be more precise to talk about "oversampling" >>>converters, because that's what makes the difference. Not the >>>actual converter topology or modulator order. >>> >>>- Ville >>> >> >>Not exactly. The pole in the feedback loop of a delta-sigma converter >>serves to take the nominally white quantization noise power and blue >>shift it into the higher frequencies, which if your mixed signal system >>is designed correctly will then be out of band from your signal, such >>that the quantization noise can be filtered and decimated out. This is >>in contrast to just taking say an SAR, oversampling by N, filtering, and >>decimating, which doesn't perform this noise shaping because it doesn't >>have the feedback. > > > > I've never understood that. You'll have to explain it to me some day. > > John >the simple way: If you model the quantization as as adding white noise with a power proportional to the number of bits, you'll see that for a delta-sigma modulator that noise will show up at the output high-passed, the power is still the same but "pushed" towards higher frequencies. When you then lowpass and decimate you remove the higher frequencies and thus much of the the noise. quatization noise before lowpass and decimate: ^ | - - | / | / | / +==------+> f fs/2 quatization noise after lowpass and decimate: ^ | | | | +==+------> f fs/2 With a SAR the noise is flat at the output, so lowpass and decimate will remove less of the noise power. quatization noise before lowpass and decimate: ^ | | | |--------- +---------+> fs/2 quatization noise after lowpass and decimate: ^ | | | |-- +--+-----> f fs/2 -Lasse
"Al Clark" <dsp@danvillesignal.com> wrote in message news:Xns9636B5ED48E0Baclarkdanvillesignal@66.133.129.71...> Andre <no_spam@fischer-zoth.de> wrote in news:d3gkoo$57c$02$1@news.t- > online.com: > > > Additionally, you might have to deal with delays. Typical delay times > > between analog input and digital output of delta-sigma ADs are around > 15 > > samples! This might make synching mux timing and sampled data hard to > do. > > > > This delay is exactly why SAR converters are used in feedback systems. > > A very big advantage to sigma delta converters is that the analog > antialiasing filters are trivial since the actual sample rate is much > high than the "effective" sample rate. > > The internal digital filters may have stopband attenuation of 90dB at > something near 1/2 the "sample rate" This of course is a major reason for > the added delay. The better converters have better filters which have > more delay.I have noticed a trend recently where some of the higher-end audio converters (especially DACs) are offering lower latency outputs, either standard, or as an option. Before, no one seemed to care too much or talk about it, but the manufacturers are starting to make a bigger deal about latency/group delay. Just thought I'd mention this.
