TO sample and be able to reconstruct the sine wave we need to sample it at >2 x maximum frequency present. Can the same sampling rate be used to sample a square wave of the same frequence ? thanks, ajw
SINE SQUARE NYQUIST
Started by ●April 13, 2005
Reply by ●April 13, 20052005-04-13
If you know that it is a square wave: yes.
Regards, Wolfgang
<archilleswaterland@hotmail.com> schrieb im Newsbeitrag
news:1113373887.037645.319150@g14g2000cwa.googlegroups.com...
> frequence ?
> thanks,
> ajw
archilleswaterland@hotmail.com wrote:> TO sample and be able to reconstruct the sine wave we need to sampleit> at >2 x maximum frequency present. > > Can the same sampling rate be used to sample a square wave of thesame> frequence ?No. To see why, compute the Fourier series of the square wave train, and then reconstruct the wave by adding successively more Fourier components. How many overharmonics do you need to see that you have a square wavetrain? You need to sample at more than twice the frequency of the highest harmonic. Rune
archilleswaterland@hotmail.com wrote:> TO sample and be able to reconstruct the sine wave we need to sampleit> at >2 x maximum frequency present. > > Can the same sampling rate be used to sample a square wave of thesame> frequence ?No. Mathematically, the maximum frequency present in a square wave is infinite, so you just can't recover *perfectly* a sampled square wave. However, in practice, you can neglect high frequency harmonics, so sampling at about 20 * f0 (twenty times the fundamental frequency) or more will suffice for most uses. Hope that helps. -- Manuel M.
>TO sample and be able to reconstruct the sine wave we need to sampleit>at >2 x maximum frequency present.I think.. the better way to state this would be " to reconstruct the sine waver we need to sample it at 2X the bandwidth of the sinewave". If it is from ideal source then bandwidth tends to zero.. else if it is impure then anything greater than 2x the bw will do. Tarang
<tarangdadia@gmail.com> wrote in message news:1113404987.623959.199560@l41g2000cwc.googlegroups.com...> >TO sample and be able to reconstruct the sine wave we need to sample > it >>at >2 x maximum frequency present. > > I think.. the better way to state this would be " to reconstruct the > sine waver we need to sample it at 2X the bandwidth of the sinewave". > If it is from ideal source then bandwidth tends to zero.. else if it is > impure then anything greater than 2x the bw will do. > > TarangIt would be a good thing if folks didn't continue to say things like: "we need to sample it at 2X the bandwidth of the sinewave" It perpetuates a common error. There are two ways to say it correctly: Theoretically: "we need to sample it at *Greater Than* 2X the bandwidth of the signal" In practice: "we need to sample it at a rate that is at least (approximately) K*2X the bandwidth of the signal .. where K is perhaps 1.1 or 1.2 or ...." The reason for the latter is that subsequent filtering is likely to be applied and there needs to be some guard band or room for a transition band between the signal bandwidth and the sample rate. If the signal is relatively narrow band then I,Q sampling at an I or Q rate that is >1x (and thus overall >2x) the bandwidth (not related to the center frequency) is possible. So, that approach would apply to a signal that approaches a pure sinusoid. It's not OK to simply sample at >2x the *bandwidth* of a narrowband signal unless some tricks are applied. See Lyon's 2nd Ed. p474 section 13.1.2 for a trick that works well for this. Regarding the square wave question, here is an interesting way to look at it: We start with a square wave that we assume is of infinite extent. We compute the Fourier Series. We note that the Fourier Series is the same as the Fourier Transform of this signal. However, the Fourier Transform is discrete because the time signal is periodic - thus it becomes a series and the Fourier Series formulation is easier to deal with and visualize. The Fourier Transform / Series is of infinite extent in frequency - thus the time signal can't be sampled theoretically as the sample rate would have to be infinite. A physical interpretation might be: the sample rate has to be infinite in order to "catch" the edges. Any lower sample rate won't do that. The Gibbs phenomenon is well known. It is caused by truncating the Fourier Series. The Gibbs phenomenon "ringing" can be eliminated by spectral shaping. i.e. lowpass filtering the square wave. There have been analyses done that provide for the fastest rise time with no ringing / i.e. so the edges of the filtered square wave are monotonic. Thus, it is possible to relate a non-ringing square wave with arbitrary rise and fall times to a bandwidth and filter characteristic. The answer to the original post recognizes that it poses a trick question or is at least nota well-formed question: The sample rate there is >2x the bandwidth of some postulated signal. So, the sample rate could be very high indeed! Then it asks if a square wave of the "same frequency" can be sampled at the same rate? Well, if we assume that the sample rate is modestly >2x the original signal's bandwidth and if we assume that the square wave frequency is equal to the original signal's bandwidth, then the answer is definitely No. However, if the sample rate is very high indeed then the answer is a definite Maybe depending on tolerable Gibbs phenomenon, ringing in general and acceptable rise and fall times of the presumed reconstructed square wave. I say "presumed" because we often use the idea of reconstruction as a convenient way to analyze these things. Also, it depends on the application. If all one wants to know is if the square wave is high or low at any instant on some acceptable time grid then this is (in some sense) less demanding than recreating the edges. But it does introduce the issue of ambiguity if a sample occurs at or near a transition. Fred
Reply by ●April 14, 20052005-04-14
> == 4 of 4 == > Date: Wed,Apr 13 2005 10:26am > From: "Fred Marshall" > It would be a good thing if folks didn't continue to say things like: > "we need to sample it at 2X the bandwidth of the sinewave" > > It perpetuates a common error. There are two ways to say itcorrectly:> Theoretically: "we need to sample it at *Greater Than* 2X thebandwidth of> the signal"Agreed. That was mistake on my part. In my thoughts it was " we need to sample it atleast at twice the bandwidth of the signal" ( but anyways who cares what I think ... its all about what I convey :-) ). Probably a little more as u have mentioned in ur post below.> In practice: "we need to sample it at a rate that is at least > (approximately) K*2X the bandwidth of the signal .. where K isperhaps 1.1> or 1.2 or ...." > The reason for the latter is that subsequent filtering is likely tobe> applied and there needs to be some guard band or room for atransition band> between the signal bandwidth and the sample rate.True.> > If the signal is relatively narrow band then I,Q sampling at an I orQ rate> that is >1x (and thus overall >2x) the bandwidth (not related to thecenter> frequency) is possible. So, that approach would apply to a signalthat> approaches a pure sinusoid. It's not OK to simply sample at >2x the > *bandwidth* of a narrowband signal unless some tricks are applied.See> Lyon's 2nd Ed. p474 section 13.1.2 for a trick that works well forthis. Did not quite understand what you are trying to say. And do not have Rick Lyons book in hand. Would appreciate it if you could say what trick is he talking in his book. Thanks. Tarang
<tarangdadia@gmail.com> wrote in message news:1113500484.364164.184270@z14g2000cwz.googlegroups.com...>> == 4 of 4 == >> Date: Wed,Apr 13 2005 10:26am >> From: "Fred Marshall" >> It would be a good thing if folks didn't continue to say things like: >> "we need to sample it at 2X the bandwidth of the sinewave" >> >> It perpetuates a common error. There are two ways to say it > correctly: >> Theoretically: "we need to sample it at *Greater Than* 2X the > bandwidth of >> the signal" > > Agreed. That was mistake on my part. In my thoughts it was " we need to > sample it atleast at twice the bandwidth of the signal" ( but anyways > who cares what I think ... its all about what I convey :-) ). Probably > a little more as u have mentioned in ur post below. > >> In practice: "we need to sample it at a rate that is at least >> (approximately) K*2X the bandwidth of the signal .. where K is > perhaps 1.1 >> or 1.2 or ...." >> The reason for the latter is that subsequent filtering is likely to > be >> applied and there needs to be some guard band or room for a > transition band >> between the signal bandwidth and the sample rate. > > True. > >> >> If the signal is relatively narrow band then I,Q sampling at an I or > Q rate >> that is >1x (and thus overall >2x) the bandwidth (not related to the > center >> frequency) is possible. So, that approach would apply to a signal > that >> approaches a pure sinusoid. It's not OK to simply sample at >2x the >> *bandwidth* of a narrowband signal unless some tricks are applied. > See >> Lyon's 2nd Ed. p474 section 13.1.2 for a trick that works well for > this. > > > Did not quite understand what you are trying to say. And do not have > Rick Lyons book in hand. Would appreciate it if you could say what > trick is he talking in his book.Well, you gotta get his book! :-) Rick treats it as a decimation approach for downconversion of a signal centered at fs/4 by fs/4: The I "modulation" is with values 1, 0, -1, 0 (which are samples of cos at fs/4) The Q "modulation" is with values 0, -1, 0, 1 (which are samples of -sin) So, there are no multiplies required at all. Now, if you were A/D converting a known bandlimited/bandpass signal, I believe you could do the A/D conversion this way to generate the I/Q samples - then you aren't tied to a submultiple of a sampling rate. Example: Bandpass signal centered at 10kHz with bandwidth 1kHz. Sample at 2.5kHz I and Q as above. The result are I and Q samples at a sample rate much less than what would otherwise be >20kHz ! well, I think I have the numbers right.... Fred
Reply by ●April 16, 20052005-04-16
Fred Marshall wrote:> <tarangdadia@gmail.com> wrote in message > news:1113404987.623959.199560@l41g2000cwc.googlegroups.com...>>> TO sample and be able to reconstruct the sine wave we need to sample >>> it at >2 x maximum frequency present.>>I think.. the better way to state this would be " to reconstruct the >>sine waver we need to sample it at 2X the bandwidth of the sinewave". >>If it is from ideal source then bandwidth tends to zero.. else if it is >>impure then anything greater than 2x the bw will do.> It would be a good thing if folks didn't continue to say things like: > "we need to sample it at 2X the bandwidth of the sinewave"> It perpetuates a common error.Isn't the bandwidth of a sine wave zero? -- glen
Reply by ●April 17, 20052005-04-17
"glen herrmannsfeldt" <gah@ugcs.caltech.edu> wrote in message news:B_qdnbWNK7cBLPzfRVn-gg@comcast.com...> Fred Marshall wrote: > >> <tarangdadia@gmail.com> wrote in message >> news:1113404987.623959.199560@l41g2000cwc.googlegroups.com... > >>>> TO sample and be able to reconstruct the sine wave we need to sample >>>> it at >2 x maximum frequency present. > >>>I think.. the better way to state this would be " to reconstruct the >>>sine waver we need to sample it at 2X the bandwidth of the sinewave". >>>If it is from ideal source then bandwidth tends to zero.. else if it is >>>impure then anything greater than 2x the bw will do. > >> It would be a good thing if folks didn't continue to say things like: >> "we need to sample it at 2X the bandwidth of the sinewave" > >> It perpetuates a common error. > > Isn't the bandwidth of a sine wave zero? > > -- glenYes, it is. I hope you are taking the comments and quotes in context. I suppose that it's OK for someone to say that the bandwidth of a signal (which just happens to be composed of only a sinusoid at frequency f0) is f0 - taking that sinusoid in the context of a general lowpass signal bandlimited to f0. Fred
