Hi - I'm interested in computing 2d convolutions of matrix X with arbitrary kernel K and its non-conjugate transpose K'. Is there a way to compute conv2(X,K) and conv2(X,K') faster than doing 2 generic convolutions? Also, if kernel KK has radial symmetry, can conv2(X,KK) be computed faster than doing a generic convolution? Thanks!
fast 2d convolution with simmetric kernels
Started by ●April 13, 2005
Reply by ●April 14, 20052005-04-14
eugenemi@gmail.com wrote:> Hi - I'm interested in computing 2d convolutions of matrix X > with arbitrary kernel K and its non-conjugate transpose K'. > Is there a way to compute conv2(X,K) and conv2(X,K') faster thandoing> 2 generic convolutions? > Also, if kernel KK has radial symmetry, can conv2(X,KK) be computed > faster > than doing a generic convolution? > Thanks!What about a 2D FFT? Rune
Rune - thanks for your answer! I understand that I can use 2D FFT to do both conv2(X,K) and conv2(X,K'). But I'm trying to use the fact that I'm convolving with K and its transpose to generate results even faster. Do you know of any technique that utilizes the fact that convolution is done with K and K' to achieve faster runtime? Rune Allnor wrote:> eugenemi@gmail.com wrote: > > Hi - I'm interested in computing 2d convolutions of matrix X > > with arbitrary kernel K and its non-conjugate transpose K'. > > Is there a way to compute conv2(X,K) and conv2(X,K') faster than > doing > > 2 generic convolutions? > > Also, if kernel KK has radial symmetry, can conv2(X,KK) be computed > > faster > > than doing a generic convolution? > > Thanks! > > What about a 2D FFT? > > Rune
eugenemi@gmail.com wrote:> Rune - thanks for your answer! > > I understand that I can use 2D FFT to do both > conv2(X,K) and conv2(X,K'). > But I'm trying to use the fact that I'm convolving with > K and its transpose to generate results even faster. > Do you know of any technique that utilizes > the fact that convolution is done with K and K' > to achieve faster runtime?Yes. Provided that K is a given function and you want both conv2(X,K) and conv2(X,K') most of the time Look carefully at redundant operations in the dataflow diagram. It should be obvious where you can save time. Regards, Martin Brown
Hi Martin! Thanks for you suggestion! Could you tell me what dataflow diagram you are refering to? Using 2d FFT or doing the convolution in the spatial domain? Martin Brown wrote:> eugenemi@gmail.com wrote: > > Rune - thanks for your answer! > > > > I understand that I can use 2D FFT to do both > > conv2(X,K) and conv2(X,K'). > > But I'm trying to use the fact that I'm convolving with > > K and its transpose to generate results even faster. > > Do you know of any technique that utilizes > > the fact that convolution is done with K and K' > > to achieve faster runtime? > > Yes. Provided that K is a given function and you want both > conv2(X,K) and conv2(X,K') most of the time > > Look carefully at redundant operations in the dataflow diagram. > It should be obvious where you can save time. > > Regards, > Martin Brown
