Frequency measurement with missing data
Started by Nobody ●December 17, 2015
Is there a known good algorithm for measuring a clock frequency based upon
"ticks" where some of the ticks are missing?
Specifically, I'm trying to infer the video refresh rate based upon a
sequence of timestamps, each of which is shortly after vsync (i.e. the
system time at which SwapBuffers() returns).
So if the refresh rate is 60 Hz, the interval between two successive
timestamps would be one of 1/60, 1/30, 1/20, 1/15, 1/12, ... seconds, plus
some jitter (typically around a millisecond or so).
I have something which mostly works, but I can't help feeling that there's
probably something simpler and more robust.
The awkward case is where the intervals initially all correspond to an
even number of frames, resulting in the inferred frequency being half the
actual frequency, then odd multiples start occurring.
On Thu, 17 Dec 2015 07:50:35 +0000, Nobody <nobody@nowhere.invalid>
wrote:
> >Is there a known good algorithm for measuring a clock frequency based upon >"ticks" where some of the ticks are missing? > >Specifically, I'm trying to infer the video refresh rate based upon a >sequence of timestamps, each of which is shortly after vsync (i.e. the >system time at which SwapBuffers() returns). > >So if the refresh rate is 60 Hz, the interval between two successive >timestamps would be one of 1/60, 1/30, 1/20, 1/15, 1/12, ... seconds, plus >some jitter (typically around a millisecond or so). > >I have something which mostly works, but I can't help feeling that there's >probably something simpler and more robust. > >The awkward case is where the intervals initially all correspond to an >even number of frames, resulting in the inferred frequency being half the >actual frequency, then odd multiples start occurring. >
For that sort of application doesn't the minimum detected period give the frequency? Eric Jacobsen Anchor Hill Communications http://www.anchorhill.com
On Thu, 17 Dec 2015 17:04:55 +0000, Eric Jacobsen wrote:
> For that sort of application doesn't the minimum detected period give the > frequency?
Not necessarily. E.g. if it takes roughly 2.5 times the frame period to render each frame before requesting a buffer swap, the interval between events (buffer swap complete) will alternate between 2 and 3 frame periods. What I essentially want is the greatest common divisor of the intervals, but timing jitter means I can't literally use the GCD. At the moment, I divide the minimum observed interval Tmin by k=1,2,3,..., finding the least k such that all observed intervals are integer multiples of Tmin/k to within a given (and somewhat arbitrary) tolerance. At that point, I can assign an integer frame number to each event, then use linear least-squares regression on the frame number and timestamp to determine the period and offset (essentially filtering out the jitter from the timestamps). The main complication is the desire to be able to re-synchronise quickly if the frame rate changes (e.g. due to switching output between monitors), but when the frame rate is stable use a large number of samples to compute the rate accurately.
On Saturday, December 19, 2015 at 2:11:41 AM UTC-5, Nobody wrote:
> On Thu, 17 Dec 2015 17:04:55 +0000, Eric Jacobsen wrote: > > > For that sort of application doesn't the minimum detected period give the > > frequency? > > Not necessarily. E.g. if it takes roughly 2.5 times the frame period to > render each frame before requesting a buffer swap, the interval between > events (buffer swap complete) will alternate between 2 and 3 frame periods. > > What I essentially want is the greatest common divisor of the intervals, > but timing jitter means I can't literally use the GCD. > > At the moment, I divide the minimum observed interval Tmin by k=1,2,3,..., > finding the least k such that all observed intervals are integer multiples > of Tmin/k to within a given (and somewhat arbitrary) tolerance. > > At that point, I can assign an integer frame number to each event, then > use linear least-squares regression on the frame number and timestamp to > determine the period and offset (essentially filtering out the jitter from > the timestamps). > > The main complication is the desire to be able to re-synchronise quickly > if the frame rate changes (e.g. due to switching output between monitors), > but when the frame rate is stable use a large number of samples to compute > the rate accurately.
To get the most from this board I think some additional information will be beneficial. The first questions that come to (my) mind are: 1. Is the set of frame rates to be detected known a priori? 2. If so are any or all rates integrally or rationally related? 3. What is the maximum processing delay you can tolerate? 4. What is the maximum gap duration between tick events?
>Not necessarily. E.g. if it takes roughly 2.5 times the frame period to >render each frame before requesting a buffer swap, the interval between >events (buffer swap complete) will alternate between 2 and 3 frame
periods.
> >What I essentially want is the greatest common divisor of the intervals, >but timing jitter means I can't literally use the GCD. > >At the moment, I divide the minimum observed interval Tmin by
k=1,2,3,...,
multiples
>of Tmin/k to within a given (and somewhat arbitrary) tolerance. > >At that point, I can assign an integer frame number to each event, then >use linear least-squares regression on the frame number and timestamp to >determine the period and offset (essentially filtering out the jitter
from
>the timestamps). > >The main complication is the desire to be able to re-synchronise quickly >if the frame rate changes (e.g. due to switching output between
monitors),
compute
It seems to me that a histogram is your best answer and you want to have two modes. Here is some pseudocode: mode = FindingRate histogram[100] = 0s multiplier = AppropriateValue while not done time_interval = GetTimeInterval() switch mode case FindingRate LookForRate() break case MonitoringRate MonitorRate() break end switch end while return LookForRate index = time_interval * multiplier histogram[index]++ if IsThereAClusterAt( index ) then SearchForOtherClusters() If found then current_interval = cluster_spacing / multiplier mode = MontitoringRate end if end if MonitorRate frame_count = time_interval / current_interval if frame_count near integer then frame_interval = time_interval / ClosestInteger( frame_count ) current_interval = w * current_interval + ( 1 - w ) * frame_interval else mode = LookingForRate ProcessRateChange() histogram[100] = 0s LookForRate() end if If shouldn't be too difficult to fill in the missing parts, but it would make the post too long to include them. Hope this helps. Ced --------------------------------------- Posted through http://www.DSPRelated.com
[..snip..]
the
I didn't notice this at first. There is nothing you can do, unless you've built a list of possible values. In the pseudo code I provided, you can find this condition when monitoring if the frame_count is near integer+.5 and adjust your variables accordingly without kicking back into FindingRate mode. Ced --------------------------------------- Posted through http://www.DSPRelated.com
Ideally, no. Certain rates are standard, but an approach which works with any rate (at least within 50-120 Hz) is preferred.
Some are integral multiples (e.g. 60 and 120 Hz), some are small rational multiples (e.g. 60 and 75 Hz are 4:5), others may have no relation.
Processing delay?
42 ms (24 fps).
On Sunday, December 20, 2015 at 6:13:02 AM UTC-5, Nobody wrote:
> On Sat, 19 Dec 2015 05:00:04 -0800, lito844 wrote: > > > 1. Is the set of frame rates to be detected known a priori? > > Ideally, no. Certain rates are standard, but an approach which works with > any rate (at least within 50-120 Hz) is preferred. > > > 2. If so are any or all rates integrally or rationally related? > > Some are integral multiples (e.g. 60 and 120 Hz), some are small rational > multiples (e.g. 60 and 75 Hz are 4:5), others may have no relation. > > > 3. What is the maximum processing delay you can tolerate? > > Processing delay? > > > 4. What is the maximum gap duration between tick events? > > 42 ms (24 fps).
These questions are my attempt to not ony bound the problem but to frame it in a more generic signal processing context so that DSP experts without video frame rate processing experience (like me) could contribute solutions. Regarding question 1: Based on your answer that all rates over a limited range must be detected, I take it your estimator must reliably discriminate for example between 60 Hz and 60.001 Hz. If this is indeed the case then the problem is much more complicated then my original assumption. Regarding question 3: To clarify, I'm trying to understand how quickly your estimator must turn a solution. How many tick events can the estimator accumulate before rendering a frame rate output? Simplistically the more data the estimator has to work with the more accurate the result. Howerver at some point (I assume) the delay will become intolerable. Regarding question 4: In your OP you mentioned that the system is subject to "missing ticks". This question is my attempt to ascertain the maximum number of missing ticks that can occur. So in the parlance of this question the maximum gap duration refers to the maximum interval over which consecutive ticks are missing. Your answer implies that at 24 fps no missing ticks will occur. What about other frame rates?
On Sun, 20 Dec 2015 05:24:42 -0800, lito844 wrote:
> Regarding question 1: Based on your answer that all rates over a limited > range must be detected, I take it your estimator must reliably > discriminate for example between 60 Hz and 60.001 Hz. If this is indeed > the case then the problem is much more complicated then my original > assumption.
That part isn't so hard. It doesn't matter if the measured frame interval is off by a few percent, so long as the error doesn't accumulate between frames. The current approach runs a rolling least-squares regression over the timestamps of some number of previous frames, so if the frequency of either the video clock or system clock changes slightly, the parameters will be updated. This part works well enough, and should cope with significant variation in frequency. But the regression requires being able to match each timestamp with a frame number, which requires knowing the frame rate closely enough that I can calculate the frame number using F[n] = F[n-1]+round((T[n]-T[n-1])/period) where F[n] are frame numbers and T[n] are timestamps. I.e. the period needs to be accurate enough that round((T[n]-T[n-1])/period) is the correct number of frames which elapsed.
> Regarding question 3: To clarify, I'm trying to understand how quickly > your estimator must turn a solution. How many tick events can the > estimator accumulate before rendering a frame rate output? Simplistically > the more data the estimator has to work with the more accurate the result. > Howerver at some point (I assume) the delay will become intolerable.
At present, it goes with whatever it's given. Starting with a few "blank" frames ensures that the minimum observed interval is actually a single frame. But currently it doesn't attempt to re-synchronise in the event of a sudden, substantial change to the frame rate (rather than just "drift"). Detecting such a change probably isn't that hard (providing it's not e.g. 2:1; a change from 60 Hz to 120 Hz would never be noticed because I'd never get to see the extra ticks), and in the worst case I can just discard the history and start over. But this problem seems close enough to a software PLL that I wondered if there are already established solutions.
> Regarding question 4: In your OP you mentioned that the system is subject > to "missing ticks". This question is my attempt to ascertain the maximum > number of missing ticks that can occur. So in the parlance of this > question the maximum gap duration refers to the maximum interval over > which consecutive ticks are missing. Your answer implies that at 24 fps > no missing ticks will occur. What about other frame rates?
If we take 1/24 sec (~42ms) as the maximum rendering time, then at 60 Hz I expect to see the interval between swaps alternating between 2 and 3 frames (1/30 and 1/20 sec), i.e. I see every second or third tick. At 120 Hz, I would see every fifth tick. At higher frequencies, aliasing with the OS' time-slice frequency (1000 Hz on Windows) starts to become an issue.
On Sunday, December 20, 2015 at 11:49:56 PM UTC-5, Nobody wrote:
> On Sun, 20 Dec 2015 05:24:42 -0800, lito844 wrote: > > > Regarding question 1: Based on your answer that all rates over a limited > > range must be detected, I take it your estimator must reliably > > discriminate for example between 60 Hz and 60.001 Hz. If this is indeed > > the case then the problem is much more complicated then my original > > assumption. > > That part isn't so hard. It doesn't matter if the measured frame interval > is off by a few percent, so long as the error doesn't accumulate between > frames. > > The current approach runs a rolling least-squares regression over the > timestamps of some number of previous frames, so if the frequency of > either the video clock or system clock changes slightly, the parameters > will be updated. > > This part works well enough, and should cope with significant variation in > frequency. But the regression requires being able to match each timestamp > with a frame number, which requires knowing the frame rate closely enough > that I can calculate the frame number using > > F[n] = F[n-1]+round((T[n]-T[n-1])/period) > > where F[n] are frame numbers and T[n] are timestamps. I.e. the period > needs to be accurate enough that round((T[n]-T[n-1])/period) is the > correct number of frames which elapsed. > > > Regarding question 3: To clarify, I'm trying to understand how quickly > > your estimator must turn a solution. How many tick events can the > > estimator accumulate before rendering a frame rate output? Simplistically > > the more data the estimator has to work with the more accurate the result. > > Howerver at some point (I assume) the delay will become intolerable. > > At present, it goes with whatever it's given. Starting with a few "blank" > frames ensures that the minimum observed interval is actually a single > frame. But currently it doesn't attempt to re-synchronise in the event of > a sudden, substantial change to the frame rate (rather than just "drift"). > > Detecting such a change probably isn't that hard (providing it's not e.g. > 2:1; a change from 60 Hz to 120 Hz would never be noticed because I'd > never get to see the extra ticks), and in the worst case I can just > discard the history and start over. But this problem seems close enough to > a software PLL that I wondered if there are already established solutions. > > > Regarding question 4: In your OP you mentioned that the system is subject > > to "missing ticks". This question is my attempt to ascertain the maximum > > number of missing ticks that can occur. So in the parlance of this > > question the maximum gap duration refers to the maximum interval over > > which consecutive ticks are missing. Your answer implies that at 24 fps > > no missing ticks will occur. What about other frame rates? > > If we take 1/24 sec (~42ms) as the maximum rendering time, then at 60 Hz > I expect to see the interval between swaps alternating between 2 and 3 > frames (1/30 and 1/20 sec), i.e. I see every second or third tick. At 120 > Hz, I would see every fifth tick. At higher frequencies, aliasing with the > OS' time-slice frequency (1000 Hz on Windows) starts to become an issue.
I get now that you're further down the path to a working solution than I previously thought. So rather than suggest a new solution starting with a clean sheet of paper I'll try to offer something that may help you get to the next step. First, I think your heuristic solution using statistics and linear regression is fine, especially in light of the fact that you've proven it to work. It sounds like the only piece missing is detecting a change in frame rate. Others may chime in but an established software PLL solution is not immediately evident to me, at least one which provides a clear advantage over a heuristic approach. Since you have a proven method I'd suggest an approach where you use two instances of your method running concurrently, one utilizing long term statistics (call it the narrowband, or NB instance) and one processing short term statistics (the wideband, or WB instance). The NB instance is akin to what you have today and continues to provide the final output of the system. The purpose of the WB instance is to quickly detect a change in frame rate. Both instances are the same design, the difference being the WB instance measures frame rate using (much) fewer data points. (The number of data points in both instances is a design parameter.) A change in frame rate is declared when the output of the WB instance differs from the NB instance by THRESHOLD standard deviations. (THRESHOLD is a design parameter.) At this point the state history of the NB instance can be replaced with that of the WB instance and concurrent processing continues. When the frame rate is not changing the WB instance is free to wander about the mean without affecting the output of the system. But when the rate changes WB will move quickly to the new rate signaling the change.
