Fred Marshall wrote:> "Jerry Avins" <jya@ieee.org> wrote in message > news:9YadnR6Ov5Q_9fzfRVn-rg@rcn.net... > >>Fred Marshall wrote: >> >>>"Jerry Avins" <jya@ieee.org> wrote in message >>>news:nK6dnWvg5Iyk0vzfRVn-jA@rcn.net... >>> >>> >>>>The turntable of my GE microwave oven makes one revolution every ten >>>>seconds. For reasons I can only attribute to the designer's whim, the >>>>turntable reverses direction with every new start and continues to turn >>>>for some fixed time after the cycle times out. A heating duration of an >>>>integer number of seconds times tens carries my coffee somewhere toward >>>>the back. >>>> >>>>Without knowing how long the "afterglow" period lasts, how can I heat my >>>>coffee to that the cup will be at the front when the heating finishes? >>>> >>>>Jerry >>> >>> >>>A very practical problem indeed! >>> >>>Add or subtract 5 seconds from the set time? >> >>7 is about right. But that's a priori knowledge. >> > > > Well, I was going to be more mathematical initially. So there are a lot of > assumptions. Now one of the assumptions has to be that the "data" was bad > in the beginning. > > Here's what I got from your "statement": > > 1 revolution in 10 seconds and I assumed for all modes.Right: the gearing sets it at 6 rpm. (Note lower case.)> You program it for N*10 seconds where N is an integer. > It stops in the back - at 0.5 revolutions.I wrote "near the back".> 0.5 revolutions is 5 seconds at 0.1rps.Irrelevant.> If it stops in the back at 0.1rps then the total run is R+0.5 revolutions > where R is an integer > So, the overrun must be K+0.5 revolutions where K is an integer and R = K + > N > > So, there must be a flaw in the data or the assumptions...... :-)I don't understand your confusion. Suppose you want to heat for one minute. Let the time to 5x seconds and start it. (So you needn't hang around very long, let x = 1, but any number less than 12 will do.) When it stops, having overrun however much is its wont, set it for the rest of the time. The total heating time will be correct, and the overruns will have canceled.> I like putting it in the middle!Not a bad cop-out! jerry -- Engineering is the art of making what you want from things you can get. �����������������������������������������������������������������������
Off-topic teaser
Started by ●April 16, 2005
Reply by ●April 16, 20052005-04-16
Jerry Avins wrote:> Piergiorgio Sartor wrote: > >> Jerry Avins wrote: >> >>> >>> Without knowing how long the "afterglow" period lasts, how can I heat >>> my coffee to that the cup will be at the front when the heating >>> finishes? >> >> >> >> 1) Put the cup first in the back, so you'll get in the front. >> 2) Put the cup in the middle, so there is no problem. >> >> ;-) >> >> bye, > > > You seem to assume a time of extra movement. On what do you base that > assumption? I wrote only that it is always the same. > > Jerry-- piergiorgio
Jerry Avins wrote:> > You seem to assume a time of extra movement. On what do you base that > assumption? I wrote only that it is always the same.I understood you _always_ get the cup at the back. Anyway, what about the middle? :-) bye, -- piergiorgio
Reply by ●April 17, 20052005-04-17
Piergiorgio Sartor wrote:> Jerry Avins wrote: > >> >> You seem to assume a time of extra movement. On what do you base that >> assumption? I wrote only that it is always the same. > > > I understood you _always_ get the cup at the back. > > Anyway, what about the middle? :-) > > bye,For the present purpose, I want the handle to face me. Jerry -- Engineering is the art of making what you want from things you can get. �����������������������������������������������������������������������
Reply by ●April 18, 20052005-04-18
Buy a good espresso machine! Jerry Avins wrote:> Piergiorgio Sartor wrote: > >> Jerry Avins wrote: >> >>> >>> You seem to assume a time of extra movement. On what do you base that >>> assumption? I wrote only that it is always the same. >> >> >> >> I understood you _always_ get the cup at the back. >> >> Anyway, what about the middle? :-) >> >> bye, > > > For the present purpose, I want the handle to face me. > > Jerry-- Please change no_spam to a.lodwig when replying via email!
Jerry Avins wrote:> The turntable of my GE microwave oven makes one revolution every ten > seconds. For reasons I can only attribute to the designer's whim, the > turntable reverses direction with every new start and continues to turn > for some fixed time after the cycle times out. A heating duration of an > integer number of seconds times tens carries my coffee somewhere toward > the back. > > Without knowing how long the "afterglow" period lasts, how can I heat my > coffee to that the cup will be at the front when the heating finishes?Put it in the back when you start?> > Jerry
SPAM blocked e-mail address in use. Replace the ANIMAL with 7 to reply. "Jerry Avins" <jya@ieee.org> wrote in message news:nK6dnWvg5Iyk0vzfRVn-jA@rcn.net...> The turntable of my GE microwave oven makes one revolution every ten > seconds. For reasons I can only attribute to the designer's whim, the > turntable reverses direction with every new start and continues to turn > for some fixed time after the cycle times out. A heating duration of an > integer number of seconds times tens carries my coffee somewhere toward > the back. > > Without knowing how long the "afterglow" period lasts, how can I heat my > coffee to that the cup will be at the front when the heating finishes?The way mine works, it always turns for an integer multiple of 10 seconds (and it also has a 10 second rotation time). So if you leave your coffee at the front, it will end up at the front no matter what length you heat for. For example, if you select 11 seconds, it will heat for 11 seconds and then turn with no heat for 9 seconds to give you 2 full rotations. I tend to stick with integer multiples of 10 seconds for my heating times so that it doesn't "waste" time/energy spinning back around to the front (which isn't necessary anyway for large plates of food that take up the whole carousel). -- Jon Harris
Jon Harris wrote:> SPAM blocked e-mail address in use. Replace the ANIMAL with 7 to reply. > "Jerry Avins" <jya@ieee.org> wrote in message > news:nK6dnWvg5Iyk0vzfRVn-jA@rcn.net... > >>The turntable of my GE microwave oven makes one revolution every ten >>seconds. For reasons I can only attribute to the designer's whim, the >>turntable reverses direction with every new start and continues to turn >>for some fixed time after the cycle times out. A heating duration of an >>integer number of seconds times tens carries my coffee somewhere toward >>the back. >> >>Without knowing how long the "afterglow" period lasts, how can I heat my >>coffee to that the cup will be at the front when the heating finishes? > > > The way mine works, it always turns for an integer multiple of 10 seconds (and > it also has a 10 second rotation time). So if you leave your coffee at the > front, it will end up at the front no matter what length you heat for. For > example, if you select 11 seconds, it will heat for 11 seconds and then turn > with no heat for 9 seconds to give you 2 full rotations. > > I tend to stick with integer multiples of 10 seconds for my heating times so > that it doesn't "waste" time/energy spinning back around to the front (which > isn't necessary anyway for large plates of food that take up the whole > carousel).That's probably a reflection of some executive's pet peeve. Ain't computers wonderful! Jerry -- Engineering is the art of making what you want from things you can get. �����������������������������������������������������������������������
Reply by ●April 19, 20052005-04-19
Jon Harris wrote: -snip-> I tend to stick with integer multiples of 10 seconds for my heating times so > that it doesn't "waste" time/energy spinning back around to the front (which > isn't necessary anyway for large plates of food that take up the whole > carousel).I guess its more energy efficient to heat exactly as long as needed. Adding just a second of heating time to end up with a multiple of 10 seconds will easily consume as much energy as a minute of running the carousel motor... (guessing the magnetron consumes 1.2kW, the motor something like 20W) -- Please change no_spam to a.lodwig when replying via email!
Andre wrote:> Jon Harris wrote: > > -snip- > >> I tend to stick with integer multiples of 10 seconds for my heating >> times so >> that it doesn't "waste" time/energy spinning back around to the front >> (which >> isn't necessary anyway for large plates of food that take up the whole >> carousel). > > > I guess its more energy efficient to heat exactly as long as needed. > Adding just a second of heating time to end up with a multiple of 10 > seconds will easily consume as much energy as a minute of running the > carousel motor... (guessing the magnetron consumes 1.2kW, the motor > something like 20W)I think you miss Jon's point. I read him as saying that the carousel continues to turn after the heating stops in order to round the rotation count up to an integer. Jerry -- Engineering is the art of making what you want from things you can get. �����������������������������������������������������������������������
