Jerry Avins wrote:> Andre wrote: > >> Jon Harris wrote: >> >> -snip- >> >>> I tend to stick with integer multiples of 10 seconds for my heating >>> times so >>> that it doesn't "waste" time/energy spinning back around to the front >>> (which >>> isn't necessary anyway for large plates of food that take up the whole >>> carousel). >> >> >> >> I guess its more energy efficient to heat exactly as long as needed. >> Adding just a second of heating time to end up with a multiple of 10 >> seconds will easily consume as much energy as a minute of running the >> carousel motor... (guessing the magnetron consumes 1.2kW, the motor >> something like 20W) > > > I think you miss Jon's point. I read him as saying that the carousel > continues to turn after the heating stops in order to round the rotation > count up to an integer. > > JerryI don't think he missed the point at all. If Jon needed to heat his food for 25 seconds and rounded it to 30 instead, he'd run the magnetron for 5 seconds longer than necessary. -- Jim Thomas Principal Applications Engineer Bittware, Inc jthomas@bittware.com http://www.bittware.com (603) 226-0404 x536 Today is the last day of your life so far.
Off-topic teaser
Started by ●April 16, 2005
Reply by ●April 19, 20052005-04-19
"Jim Thomas" <jthomas@bittware.com> wrote in message news:116a90fn80vhj76@corp.supernews.com...> Jerry Avins wrote: > > Andre wrote: > > > >> Jon Harris wrote: > >> > >> -snip- > >> > >>> I tend to stick with integer multiples of 10 seconds for my heating > >>> times so > >>> that it doesn't "waste" time/energy spinning back around to the front > >>> (which > >>> isn't necessary anyway for large plates of food that take up the whole > >>> carousel). > >> > >> I guess its more energy efficient to heat exactly as long as needed. > >> Adding just a second of heating time to end up with a multiple of 10 > >> seconds will easily consume as much energy as a minute of running the > >> carousel motor... (guessing the magnetron consumes 1.2kW, the motor > >> something like 20W) > > > > > > I think you miss Jon's point. I read him as saying that the carousel > > continues to turn after the heating stops in order to round the rotation > > count up to an integer. > > > > Jerry > > I don't think he missed the point at all. If Jon needed to heat his > food for 25 seconds and rounded it to 30 instead, he'd run the magnetron > for 5 seconds longer than necessary.That's a good point in theory, but in practice one doesn't usually know _exactly_ how long to heat something. I would say my estimates would be lucky to be accurate to within 10 seconds (especially with any longer than 30 seconds)!
"Jerry Avins" <jya@ieee.org> wrote in message news:NO-dncRu_arSwPnfRVn-sw@rcn.net...> Jon Harris wrote: > > SPAM blocked e-mail address in use. Replace the ANIMAL with 7 to reply. > > "Jerry Avins" <jya@ieee.org> wrote in message > > news:nK6dnWvg5Iyk0vzfRVn-jA@rcn.net... > > > >>The turntable of my GE microwave oven makes one revolution every ten > >>seconds. For reasons I can only attribute to the designer's whim, the > >>turntable reverses direction with every new start and continues to turn > >>for some fixed time after the cycle times out. A heating duration of an > >>integer number of seconds times tens carries my coffee somewhere toward > >>the back. > >> > >>Without knowing how long the "afterglow" period lasts, how can I heat my > >>coffee to that the cup will be at the front when the heating finishes? > > > > > > The way mine works, it always turns for an integer multiple of 10 seconds(and> > it also has a 10 second rotation time). So if you leave your coffee at the > > front, it will end up at the front no matter what length you heat for. For > > example, if you select 11 seconds, it will heat for 11 seconds and then turn > > with no heat for 9 seconds to give you 2 full rotations. > > > > I tend to stick with integer multiples of 10 seconds for my heating times so > > that it doesn't "waste" time/energy spinning back around to the front (which > > isn't necessary anyway for large plates of food that take up the whole > > carousel). > > That's probably a reflection of some executive's pet peeve. Ain't > computers wonderful!It seems like maybe the designers of your GE microwave tried to do the same thing mine does, but "missed". BTW, mine also does the reversal and I can't figure out why either.
interesting, it seems my microwave turntable does the same thing...... reverses direction at each start ... I Googled around to try to find the reason why.... the best I could find is that the motors are synchronous motors and lack a "starting device" and therefore start in _random_ directions. This makes sense but it sure seems to me that mine reverses each time... or is there some mechanism that "accidentally" biases the system to reverse each time? I'll have to do a more controlled test. Mark
Jim Thomas wrote:> Jerry Avins wrote: > >> Andre wrote: >> >>> Jon Harris wrote: >>> >>> -snip- >>> >>>> I tend to stick with integer multiples of 10 seconds for my heating >>>> times so >>>> that it doesn't "waste" time/energy spinning back around to the >>>> front (which >>>> isn't necessary anyway for large plates of food that take up the whole >>>> carousel). >>> >>> >>> >>> >>> I guess its more energy efficient to heat exactly as long as needed. >>> Adding just a second of heating time to end up with a multiple of 10 >>> seconds will easily consume as much energy as a minute of running the >>> carousel motor... (guessing the magnetron consumes 1.2kW, the motor >>> something like 20W) >> >> >> >> I think you miss Jon's point. I read him as saying that the carousel >> continues to turn after the heating stops in order to round the >> rotation count up to an integer. >> >> Jerry > > > I don't think he missed the point at all. If Jon needed to heat his > food for 25 seconds and rounded it to 30 instead, he'd run the magnetron > for 5 seconds longer than necessary.I read what Jon wrote as meaning that if he punched in 25 seconds, the magnetron would be on for 25 seconds, but the carousel would stay on for 30, bring the food back to its initial orientation in the cavity. I quote him: "For example, if you select 11 seconds, it will heat for 11 seconds and then turn with no heat for 9 seconds to give you 2 full rotations." Jerry -- Engineering is the art of making what you want from things you can get. �����������������������������������������������������������������������
"Jerry Avins" <jya@ieee.org> wrote in message news:XvidnVlqO9LD4_jfRVn-hQ@rcn.net...> Jim Thomas wrote: > > Jerry Avins wrote: > > > >> Andre wrote: > >> > >>> Jon Harris wrote: > >>> > >>> -snip- > >>> > >>>> I tend to stick with integer multiples of 10 seconds for my heating > >>>> times so > >>>> that it doesn't "waste" time/energy spinning back around to the > >>>> front (which > >>>> isn't necessary anyway for large plates of food that take up the whole > >>>> carousel). > >>> > >>> > >>> I guess its more energy efficient to heat exactly as long as needed. > >>> Adding just a second of heating time to end up with a multiple of 10 > >>> seconds will easily consume as much energy as a minute of running the > >>> carousel motor... (guessing the magnetron consumes 1.2kW, the motor > >>> something like 20W) > >> > >> > >> > >> I think you miss Jon's point. I read him as saying that the carousel > >> continues to turn after the heating stops in order to round the > >> rotation count up to an integer. > >> > >> Jerry > > > > > > I don't think he missed the point at all. If Jon needed to heat his > > food for 25 seconds and rounded it to 30 instead, he'd run the magnetron > > for 5 seconds longer than necessary. > > I read what Jon wrote as meaning that if he punched in 25 seconds, the > magnetron would be on for 25 seconds, but the carousel would stay on for > 30, bring the food back to its initial orientation in the cavity. I > quote him: "For example, if you select 11 seconds, it will heat for 11 > seconds and then turn with no heat for 9 seconds to give you 2 full > rotations."You are both right and arguing separate points. Andre is responding to my statement where I said "I tend to stick with integer multiples of 10 seconds for my heating times so that it doesn't 'waste' time/energy spinning back around to the front". In other words, I wouldn't punch in 25 seconds, I would punch in 30 seconds instead. His claim was that wastes even more energy. My rebuttal is that the cook time is an inexact quantity, often not known to sub-10-second accuracy anyway.
Reply by ●April 20, 20052005-04-20
Jon Harris wrote:> "Jerry Avins" <jya@ieee.org> wrote in message > news:XvidnVlqO9LD4_jfRVn-hQ@rcn.net... > >>Jim Thomas wrote: >> >>>Jerry Avins wrote: >>> >>> >>>>Andre wrote: >>>> >>>> >>>>>Jon Harris wrote: >>>>> >>>>>-snip- >>>>> >>>>> >>>>>>I tend to stick with integer multiples of 10 seconds for my heating >>>>>>times so >>>>>>that it doesn't "waste" time/energy spinning back around to the >>>>>>front (which >>>>>>isn't necessary anyway for large plates of food that take up the whole >>>>>>carousel). >>>>> >>>>> >>>>>I guess its more energy efficient to heat exactly as long as needed. >>>>>Adding just a second of heating time to end up with a multiple of 10 >>>>>seconds will easily consume as much energy as a minute of running the >>>>>carousel motor... (guessing the magnetron consumes 1.2kW, the motor >>>>>something like 20W) >>>> >>>> >>>> >>>>I think you miss Jon's point. I read him as saying that the carousel >>>>continues to turn after the heating stops in order to round the >>>>rotation count up to an integer. >>>> >>>>Jerry >>> >>> >>>I don't think he missed the point at all. If Jon needed to heat his >>>food for 25 seconds and rounded it to 30 instead, he'd run the magnetron >>>for 5 seconds longer than necessary. >> >>I read what Jon wrote as meaning that if he punched in 25 seconds, the >>magnetron would be on for 25 seconds, but the carousel would stay on for >>30, bring the food back to its initial orientation in the cavity. I >>quote him: "For example, if you select 11 seconds, it will heat for 11 >>seconds and then turn with no heat for 9 seconds to give you 2 full >>rotations." > > > You are both right and arguing separate points. Andre is responding to my > statement where I said "I tend to stick with integer multiples of 10 seconds for > my heating times so that it doesn't 'waste' time/energy spinning back around to > the front". In other words, I wouldn't punch in 25 seconds, I would punch in 30 > seconds instead. His claim was that wastes even more energy. My rebuttal is > that the cook time is an inexact quantity, often not known to sub-10-second > accuracy anyway.I'm with you on the futility of precision timing and the simplicity of round numbers. Thanks for dispelling my confusion about who said what. Jerry -- Engineering is the art of making what you want from things you can get. �����������������������������������������������������������������������
Jerry Avins wrote:> I'm with you on the futility of precision timing and the simplicity of > round numbers. Thanks for dispelling my confusion about who said what. >How's this for optimizing that which does not need to be optimized: when I think 30 seconds is about right, I punch in 33. Reduces seek time ;-) I also routinely use 88 or 99 when I want 1:30. -- Jim Thomas Principal Applications Engineer Bittware, Inc jthomas@bittware.com http://www.bittware.com (603) 226-0404 x536 Sometimes experience is the only teacher that works - Mike Rosing
"Jim Thomas" <jthomas@bittware.com> wrote in message news:116cmosdlich3ee@corp.supernews.com...> Jerry Avins wrote: > > I'm with you on the futility of precision timing and the simplicity of > > round numbers. Thanks for dispelling my confusion about who said what. > > > > How's this for optimizing that which does not need to be optimized: > when I think 30 seconds is about right, I punch in 33. Reduces seek > time ;-) > > I also routinely use 88 or 99 when I want 1:30.I do that too! I guess it's just an engineering thing to seek efficiency/optimization in everything we do. I think about the most efficient pattern to cut my lawn in, taking into account that the bag should be full when I am close to the place where I empty it. I consider how best to walk around cars and other obstacles to get from point A to B the fastest. And I love squeezing one more cycle out of that DSP algorithm! It's a mind set I can't escape.
