HPPCI + ADSP-BF533 EZLITE + Video: Problems
Started by April 16, 2005
Hi,
I'm trying to run a small demonstration aplpication on which I
capture images from a camera trough the video codec on the ADDS-
BF533-EZLITE (rev 1.1, silicon rev 0.1).
This behavior happens both with VisualDSP++ 4.0 and 3.5 Nov'04
update, and if using HPPCI emulator:
The program loads fine. I can start to run it. But the PPI interrupt
never comes back. If I try to halt the DSP, I get the following
JTAG scan failed - Check target power and emulator connection.
Failed getting full context from the target.
Error writing user opcode for breakpoint remove at address:
0xffa0327c.
Error Getting PC after Halting.
The most strange thing is that it works absolutely flawlessly with
the slow EzKit USB link!!! I wanted to use the emulator to get the
processed images faster, but does not nork.
I am using the HPPCI in legacy mode. Will I need to change to High
Speed mode?
Has anyone experienced similar problems? Any workaround that you
know of?
Kindest regards,
Jaime Andr�s Aranguren Cardona
jaac@sanjaac.com
SanJaaC Electronics
Soluciones en DSP
www.sanjaac.com
Hello,
I've found the same problem when working on the old SummitPCI emulator.
Somewhere in my code I configure the PPI like this:
#include <cdefBF533.h>
void Init_PPI(void)
  //The PPI is set to receive 525 lines for each frame
  *pPPI_FRAME = 525;
  //PPI enabled, input mode, active video only, receive field 1&2,
  //packing enabled, DMA32 enabled, skipping enabled, skip odd
  //elements, 8bit data bus, nothing inverted
  *pPPI_CONTROL = SKIP_EN | PORT_EN | FLD_SEL | PACK_EN | DLEN_8 ;
}//end Init_PPI
The emulator gets lost exactly after writting to *pPPI_CONTROL.
Any idea of why? Any workaround?
Regards,
Jaime Andr&#2013265929;s Aranguren Cardona
jaac@sanjaac.com
SanJaaC Electronics
Soluciones en DSP
www.sanjaac.com
"Jaime Andr&#2013265929;s Aranguren Cardona" <jaac@nospam.sanjaac.com>
escribi&#2013265923; en el
mensaje news:1113681039.8e571c6cb2010cec5ee632c076057bab@teranews...
> Hi, > > I'm trying to run a small demonstration aplpication on which I > capture images from a camera trough the video codec on the ADDS- > BF533-EZLITE (rev 1.1, silicon rev 0.1). > > This behavior happens both with VisualDSP++ 4.0 and 3.5 Nov'04 > update, and if using HPPCI emulator: > > The program loads fine. I can start to run it. But the PPI interrupt > never comes back. If I try to halt the DSP, I get the following > messages: > > JTAG scan failed - Check target power and emulator connection. > Failed getting full context from the target. > Error writing user opcode for breakpoint remove at address: > 0xffa0327c. > JTAG scan failed - Check target power and emulator connection. > Failed getting full context from the target. > Error Getting PC after Halting. > JTAG scan failed - Check target power and emulator connection. > Failed getting full context from the target. > JTAG scan failed - Check target power and emulator connection. > Failed getting full context from the target. > > The most strange thing is that it works absolutely flawlessly with > the slow EzKit USB link!!! I wanted to use the emulator to get the > processed images faster, but does not nork. > > I am using the HPPCI in legacy mode. Will I need to change to High > Speed mode? > > Has anyone experienced similar problems? Any workaround that you > know of? > > Kindest regards, > > -- > ------------------------------ > Jaime Andr&#2013265929;s Aranguren Cardona > jaac@sanjaac.com > SanJaaC Electronics > Soluciones en DSP > www.sanjaac.com > >
Even more strange: the example provided with VisualDSP++ for video capture
works flawlessly with SummitICE (haven't tried with HPPCI yet).... the only
difference I see is that in my demo I skip color components, I just store
the luminance, and in theirs they get it, but waste twice the memory.
In my configuration:
In their configuration:
//packing enabled, DMA32 enabled, skipping disabled, skip odd
*pPPI_CONTROL = PORT_EN | FLD_SEL | PACK_EN | DLEN_8 ;
If I run the code from the USB link provided with the kit (EZKit session),
either of the codes work OK; but if I run it from an emulator session
(either HPPCI or SummitICE) only the non-skipping code works.
I've reviewed the HPPCI manual, and the ADSP-BF533-EZLITE schematics, and I
see that all of the VDDIO/BTMS, BTCK, /BTRST and BTDI signals are grounded
on the kit. Does it has some to do with my problem?
Regards
jaac@sanjaac.com
SanJaaC Electronics
Soluciones en DSP
www.sanjaac.com
mensaje news:1113682502.c8e7c8f1bbf5916fc468d15c406827d6@teranews...
> Hello, > > I've found the same problem when working on the old SummitPCI emulator. > Somewhere in my code I configure the PPI like this: > > #include <cdefBF533.h> > > void Init_PPI(void) > { > //The PPI is set to receive 525 lines for each frame > *pPPI_FRAME = 525; > > //PPI enabled, input mode, active video only, receive field 1&2, > //packing enabled, DMA32 enabled, skipping enabled, skip odd > //elements, 8bit data bus, nothing inverted > *pPPI_CONTROL = SKIP_EN | PORT_EN | FLD_SEL | PACK_EN | DLEN_8 ; > > }//end Init_PPI > > The emulator gets lost exactly after writting to *pPPI_CONTROL. > > Any idea of why? Any workaround? > > Regards, > > -- > ------------------------------ > Jaime Andr&#2013265929;s Aranguren Cardona > jaac@sanjaac.com > SanJaaC Electronics > Soluciones en DSP > www.sanjaac.com > > > "Jaime Andr&#2013265929;s Aranguren Cardona" <jaac@nospam.sanjaac.com>
> mensaje news:1113681039.8e571c6cb2010cec5ee632c076057bab@teranews... >> Hi, >> >> I'm trying to run a small demonstration aplpication on which I >> capture images from a camera trough the video codec on the ADDS- >> BF533-EZLITE (rev 1.1, silicon rev 0.1). >> >> This behavior happens both with VisualDSP++ 4.0 and 3.5 Nov'04 >> update, and if using HPPCI emulator: >> >> The program loads fine. I can start to run it. But the PPI interrupt >> never comes back. If I try to halt the DSP, I get the following >> messages: >> >> JTAG scan failed - Check target power and emulator connection. >> Failed getting full context from the target. >> Error writing user opcode for breakpoint remove at address: >> 0xffa0327c. >> JTAG scan failed - Check target power and emulator connection. >> Failed getting full context from the target. >> Error Getting PC after Halting. >> JTAG scan failed - Check target power and emulator connection. >> Failed getting full context from the target. >> JTAG scan failed - Check target power and emulator connection. >> Failed getting full context from the target. >> >> The most strange thing is that it works absolutely flawlessly with >> the slow EzKit USB link!!! I wanted to use the emulator to get the >> processed images faster, but does not nork. >> >> I am using the HPPCI in legacy mode. Will I need to change to High >> Speed mode? >> >> Has anyone experienced similar problems? Any workaround that you >> know of? >> >> Kindest regards, >> >> -- >> ------------------------------ >> Jaime Andr&#2013265929;s Aranguren Cardona >> jaac@sanjaac.com >> SanJaaC Electronics >> Soluciones en DSP >> www.sanjaac.com >> >> > >
