Hi all, I am trying to figure out the consequences of groupdelay variation in a DMT system. When some frequencies of the pasband are expossed to a groupdelay variation of maybe 50us, will these frequencies get delayed: 50us/Ts samples, and thereby exceed the timedomain boundry of the original DMT symbol (one N point FFT) and cross over into another symbol? Are my thoughts on this matter all wrong ? Thanks in advance -- Morten M. J�rgensen
Theoretical and practical consequences of groupdelay variation in DMT.
Started by ●April 17, 2005
Reply by ●April 18, 20052005-04-18
Morten M. J=F8rgensen wrote:> Hi all, > > I am trying to figure out the consequences of groupdelay variation ina DMT> system. When some frequencies of the pasband are expossed to agroupdelay> variation of maybe 50us, will these frequencies get delayed: 50us/Ts > samples, and thereby exceed the timedomain boundry of the originalDMT> symbol (one N point FFT) and cross over into another symbol? > > Are my thoughts on this matter all wrong ?I don't know much about the DMT application, but group delays *may* have the effect that energy "leaks" from one time frame to the next. Group delays are no problems if they are equal for all frequencues. That's just an extra delay of the signal. Problems may occur if the group delays differ for different frequencies. That's a dispersive channel, and the net effect could be that the recieved signal is totally unintelligable. The symbols may interfer with each other in time, or the sympol waveforms may have been distorted so they can no longer be recognized at the reciever. Channel dispersion is one of the really big problems in low-frequency acoustic communication under water. Rune
I dont know the answer to your question, but I have a suggestion that may lead you to the answer. The channel you are considering has a large group delay at some frequencies. But what does this do to the impulse response? You should examine the channel impulse response, using Matlab or whatever. you will see that a certain amount of dispersion is introduced by the group delay on certain frequencies. The key point is: if the time-dispersion is shorter in duration than the cyclic prefix, then NO, you will not get interference between successive frames. However, if the impulse response is significantly longer than the cyclic prefix, you will get appreciable ISI. To overcome this, it is common to use a time-domain equaliser (TEQ) to shorten the channel impulse response. What this equaliser might do is delay the remaining frequencies to produuce the same group delay on all frequencies.
> if the time-dispersion is shorter in duration than the cyclic prefix, > then NO, you will not get interference between successive frames. > However, if the impulse response is significantly longer than the > cyclic prefix, you will get appreciable ISI.Hmm....I'm not quite sure I get it :D Is the ISI caused by the "transient" of my impulse respons or is it caused by the groupdelay variation....? The cyclic prefix is 80 samples with an IFFT size of 1024 and a sampling freq of 4.416Mhz. This make the lenght of the cyclic prefix 80*(4.416Mhz)^-1 =18.1us but still the standard maximum is at 50us ? Why won't a 40us groupdelay variation cause ISI ? A bit confussed ;)
Hi all, I am trying to figure out the consequences of groupdelay variation in a DMT system. When some frequencies of the pasband are expossed to a groupdelay variation of maybe 50us, will these frequencies get delayed: 50us/Ts samples, and thereby exceed the timedomain boundry of the original DMT symbol (one N point FFT) and cross over into another symbol? Are my thoughts on this matter all wrong ? Thanks in advance -- Morten M. J�rgensen ************************************************ Well, if there is a variation in group delay then certainly different frequencies will be delayed differently - really by definition of "group delay" which is usually supposed to be a single number and not a range. But, if in context, it should be understandable. ISI could be caused by both group delay variation and impulse reponse transient as a general statement. Generally you design the impulse response so that ISI is zeroed out. If I'm talking about the same thing you are. Then you suffer system variations on top of that. There is a pretty good discussion at: http://commsdesign.com/design_corner/showArticle.jhtml?articleID=47902272 and there is a block diagram at: http://i.cmpnet.com/commsdesign/2004/sept04/dmt-fig2.jpg also: http://www.nextep.com.au/upload/DSL_Modulation_Techniques.pdf and: http://www.ifip.or.at/con2000/icct2000/icct420.pdf You can Google on better key words than I..... Fred
> There is a pretty good discussion at: > http://commsdesign.com/design_corner/showArticle.jhtml?articleID=47902272 > and there is a block diagram at: > http://i.cmpnet.com/commsdesign/2004/sept04/dmt-fig2.jpg > > also: > http://www.nextep.com.au/upload/DSL_Modulation_Techniques.pdf > > and: > http://www.ifip.or.at/con2000/icct2000/icct420.pdfGreat links....thanks allot! -- Morten
"Morten M. J�rgensen" <grinder213SPAM@HELL_NOhotmail.com> writes:>> if the time-dispersion is shorter in duration than the cyclic prefix, >> then NO, you will not get interference between successive frames. >> However, if the impulse response is significantly longer than the >> cyclic prefix, you will get appreciable ISI. > > Hmm....I'm not quite sure I get it :D Is the ISI caused by the "transient" > of my impulse respons or is it caused by the groupdelay variation....?Thre's a difference? -- % Randy Yates % "Remember the good old 1980's, when %% Fuquay-Varina, NC % things were so uncomplicated?" %%% 919-577-9882 % 'Ticket To The Moon' %%%% <yates@ieee.org> % *Time*, Electric Light Orchestra http://home.earthlink.net/~yatescr
> Thre's a difference?Saying that the transient Impuls reponse is the same as groupdelay? -- Morten
On 19 Apr 2005 04:26:32 +0100, "Morten M. J�rgensen" <grinder213SPAM@HELL_NOhotmail.com> wrote:>> Thre's a difference? > >Saying that the transient Impuls reponse is the same as groupdelay?Doesn't one completely define the other? Chris Hornbeck 6x9=42 April 29
