Accurate frequency measurement problem
Started by Unknown February 11, 2016
On Tue, 16 Feb 2016 19:55:17 +0200, Tauno Voipio wrote:
> On 16.2.16 18:00, Tim Wescott wrote: >> On Tue, 16 Feb 2016 10:03:49 +0200, Tauno Voipio wrote: >> >>> On 15.2.16 22:54, Steve Pope wrote: >>>> <a.turowski@ymail.com> wrote: >>>> >>>>> I think we all arrived to the conclusion that it all should be >>>>> doable. >>>>> The bigger system is now at the very early stage of feasibility >>>>> study. >>>>> That is why I didn't have a complete set of data regarding >>>>> requirements or signal properties. In couple of weeks I will have a >>>>> meeting with people who designed the sensor. This would be the >>>>> opportunity to ask for more data regarding sensor operation, so if >>>>> you have any questions you want me to ask, shoot away. >>>> >>>> One thing you may need is requirements collapse. That is, if your >>>> part of the system requires a timebase good to 0.01 ppm, it may be >>>> that other parts of the system require similarly accurate timebases. >>>> Perhaps there needs to be a system-wide timebase generator, distinct >>>> from your module, since if you "own" the entire timebase problem, >>>> your part of the system might appear disproportionately expensive. >>>> >>>> Another thing you may want to consider is whether you need live >>>> calibration -- that is, when employing the sensor, you alternate >>>> between a calibration phase (which could be infrequent) and >>>> measurement phase. This might make life easier. >>>> >>>> Good luck. >>>> >>>> Steve >>> >>> >>> I just wonder what may be a physical system supplying the frequency to >>> be measured to an accuracy in the ppb class, except a frequency >>> standard. >> >> The 10ppb figure does become suspicious, doesn't it? Some measurement >> system that depends on something like a piezo-electric crystal or a >> mechanical resonator changing it's resonant frequency in response to >> the parameter being measured jumps to mind. >> >> If I'm measuring to "100ppb, 10ppb preferred" then I probably have a >> total error budget of 1ppm or so, and I want the frequency measurement >> part of that error budget to be somewhere between definitely small >> enough and not a worry at all. >> >> I could see such a system being valid if it had temperature >> compensation, >> or if it were measuring temperature. > > > My son, a PhD in measurement technology, likes to say that every > measurement system will be a thermometer, and maybe a barometer, > if sufficiently sensitive. > > I have been suspecting the accuracy spec from the start on.
I once sat in a meeting room while a project engineer from a company trying to sell us gyroscopes hold up a soup-can sized gyro and say "This is a gyroscope. It's also a microphone, accelerometer, thermometer, and various other measuring instruments..." We didn't buy the gyroscope, but it was because it was much too big, not because we didn't like the presentation. -- Tim Wescott Wescott Design Services http://www.wescottdesign.com
On 16.2.16 20:18, Tim Wescott wrote:
> On Tue, 16 Feb 2016 19:55:17 +0200, Tauno Voipio wrote: > >> On 16.2.16 18:00, Tim Wescott wrote: >>> On Tue, 16 Feb 2016 10:03:49 +0200, Tauno Voipio wrote: >>> >>>> On 15.2.16 22:54, Steve Pope wrote: >>>>> <a.turowski@ymail.com> wrote: >>>>> >>>>>> I think we all arrived to the conclusion that it all should be >>>>>> doable. >>>>>> The bigger system is now at the very early stage of feasibility >>>>>> study. >>>>>> That is why I didn't have a complete set of data regarding >>>>>> requirements or signal properties. In couple of weeks I will have a >>>>>> meeting with people who designed the sensor. This would be the >>>>>> opportunity to ask for more data regarding sensor operation, so if >>>>>> you have any questions you want me to ask, shoot away. >>>>> >>>>> One thing you may need is requirements collapse. That is, if your >>>>> part of the system requires a timebase good to 0.01 ppm, it may be >>>>> that other parts of the system require similarly accurate timebases. >>>>> Perhaps there needs to be a system-wide timebase generator, distinct >>>>> from your module, since if you "own" the entire timebase problem, >>>>> your part of the system might appear disproportionately expensive. >>>>> >>>>> Another thing you may want to consider is whether you need live >>>>> calibration -- that is, when employing the sensor, you alternate >>>>> between a calibration phase (which could be infrequent) and >>>>> measurement phase. This might make life easier. >>>>> >>>>> Good luck. >>>>> >>>>> Steve >>>> >>>> >>>> I just wonder what may be a physical system supplying the frequency to >>>> be measured to an accuracy in the ppb class, except a frequency >>>> standard. >>> >>> The 10ppb figure does become suspicious, doesn't it? Some measurement >>> system that depends on something like a piezo-electric crystal or a >>> mechanical resonator changing it's resonant frequency in response to >>> the parameter being measured jumps to mind. >>> >>> If I'm measuring to "100ppb, 10ppb preferred" then I probably have a >>> total error budget of 1ppm or so, and I want the frequency measurement >>> part of that error budget to be somewhere between definitely small >>> enough and not a worry at all. >>> >>> I could see such a system being valid if it had temperature >>> compensation, >>> or if it were measuring temperature. >> >> >> My son, a PhD in measurement technology, likes to say that every >> measurement system will be a thermometer, and maybe a barometer, >> if sufficiently sensitive. >> >> I have been suspecting the accuracy spec from the start on. > > I once sat in a meeting room while a project engineer from a company > trying to sell us gyroscopes hold up a soup-can sized gyro and say "This > is a gyroscope. It's also a microphone, accelerometer, thermometer, and > various other measuring instruments..." > > We didn't buy the gyroscope, but it was because it was much too big, not > because we didn't like the presentation.
So, you met a scarcity: a honest salesman. He deserves a prize. -- -TV
On Tue, 16 Feb 2016 22:38:48 +0200, Tauno Voipio wrote:
> On 16.2.16 20:18, Tim Wescott wrote: >> On Tue, 16 Feb 2016 19:55:17 +0200, Tauno Voipio wrote: >> >>> On 16.2.16 18:00, Tim Wescott wrote: >>>> On Tue, 16 Feb 2016 10:03:49 +0200, Tauno Voipio wrote: >>>> >>>>> On 15.2.16 22:54, Steve Pope wrote: >>>>>> <a.turowski@ymail.com> wrote: >>>>>> >>>>>>> I think we all arrived to the conclusion that it all should be >>>>>>> doable. >>>>>>> The bigger system is now at the very early stage of feasibility >>>>>>> study. >>>>>>> That is why I didn't have a complete set of data regarding >>>>>>> requirements or signal properties. In couple of weeks I will have >>>>>>> a meeting with people who designed the sensor. This would be the >>>>>>> opportunity to ask for more data regarding sensor operation, so if >>>>>>> you have any questions you want me to ask, shoot away. >>>>>> >>>>>> One thing you may need is requirements collapse. That is, if your >>>>>> part of the system requires a timebase good to 0.01 ppm, it may be >>>>>> that other parts of the system require similarly accurate >>>>>> timebases. >>>>>> Perhaps there needs to be a system-wide timebase generator, >>>>>> distinct from your module, since if you "own" the entire timebase >>>>>> problem, your part of the system might appear disproportionately >>>>>> expensive. >>>>>> >>>>>> Another thing you may want to consider is whether you need live >>>>>> calibration -- that is, when employing the sensor, you alternate >>>>>> between a calibration phase (which could be infrequent) and >>>>>> measurement phase. This might make life easier. >>>>>> >>>>>> Good luck. >>>>>> >>>>>> Steve >>>>> >>>>> >>>>> I just wonder what may be a physical system supplying the frequency >>>>> to be measured to an accuracy in the ppb class, except a frequency >>>>> standard. >>>> >>>> The 10ppb figure does become suspicious, doesn't it? Some >>>> measurement system that depends on something like a piezo-electric >>>> crystal or a mechanical resonator changing it's resonant frequency in >>>> response to the parameter being measured jumps to mind. >>>> >>>> If I'm measuring to "100ppb, 10ppb preferred" then I probably have a >>>> total error budget of 1ppm or so, and I want the frequency >>>> measurement part of that error budget to be somewhere between >>>> definitely small enough and not a worry at all. >>>> >>>> I could see such a system being valid if it had temperature >>>> compensation, >>>> or if it were measuring temperature. >>> >>> >>> My son, a PhD in measurement technology, likes to say that every >>> measurement system will be a thermometer, and maybe a barometer, >>> if sufficiently sensitive. >>> >>> I have been suspecting the accuracy spec from the start on. >> >> I once sat in a meeting room while a project engineer from a company >> trying to sell us gyroscopes hold up a soup-can sized gyro and say >> "This is a gyroscope. It's also a microphone, accelerometer, >> thermometer, and various other measuring instruments..." >> >> We didn't buy the gyroscope, but it was because it was much too big, >> not because we didn't like the presentation. > > > So, you met a scarcity: a honest salesman. He deserves a prize.
He was the engineering manager. I suspect that the sales guy was wishing for a remote with a "voice off" button. -- Tim Wescott Wescott Design Services http://www.wescottdesign.com
On 13.02.2016 20:29, Eric Jacobsen wrote:
(snip)
> > I tried to run this but there is a term, sgn, near the end that > appears to be undefined? I'm attempting to run it on Octave, so > maybe there's a difference there. > > Cool stuff, though. > > > Eric Jacobsen > Anchor Hill Communications > http://www.anchorhill.com >
I could not reproduce the error in Octave. I used the latest Windows release of Octave and loaded three packages (communications, signal and control). And it worked allright, although more slowly than in Matlab. Regards, Evgeny.
On Wed, 17 Feb 2016 14:04:31 +0300, Evgeny Filatov
<filatov.ev@mipt.ru> wrote:
>On 13.02.2016 20:29, Eric Jacobsen wrote: > >(snip) > >> >> I tried to run this but there is a term, sgn, near the end that >> appears to be undefined? I'm attempting to run it on Octave, so >> maybe there's a difference there. >> >> Cool stuff, though. >> >> >> Eric Jacobsen >> Anchor Hill Communications >> http://www.anchorhill.com >> > >I could not reproduce the error in Octave. I used the latest Windows >release of Octave and loaded three packages (communications, signal and >control). And it worked allright, although more slowly than in Matlab. > >Regards, >Evgeny.
Oh, sorry! I had fixed it and a few other issues in Octave already. It was just an issue with passing the arguments. Eric Jacobsen Anchor Hill Communications http://www.anchorhill.com
