Hi. I am trying to model oscillator phase noise using Matlab m-code. I know there is a phase noise blockset in the simulink. I looked under the blockset mask and learnt that the phase noise is modelled by passing AWGN noise through a direct form II transposed (DF2T) filter whose shape is probably 1/f. If given another type of frequency response of a phase noise model, how do I generate the filter coefficients for the DF2T filter? Is the Matlab function 'Yulewalk' sufficient to generate these filter coefficients? Thanks! -- Regards, kc
Phase Noise Modeling
Started by ●April 21, 2005
Reply by ●April 21, 20052005-04-21
If you search comp.dsp with the phrase "simulation of 1/f noise" you will find a link to an old post which contains Matlab code to do just that. Regards, Andor
"Andor" <an2or@mailcircuit.com> wrote in message news:<1114070997.337971.263040@z14g2000cwz.googlegroups.com>...> If you search comp.dsp with the phrase > > "simulation of 1/f noise" > > you will find a link to an old post which contains Matlab code to do > just that. > > Regards, > AndorHi Andor, Thank you very much for pointing out the link. I will try that out first thing next morning. I note that the Matlab code models a 1/f noise model. If a specific non 1/f noise model is to be modelled, is there a way to do it? Regards, kc
Reply by ●April 22, 20052005-04-22
I guess that kind of depends how non-1/f the noise model is. You should also find a link to the following paper N. J. Kasdin, "Discrete Simulation of Colored Noise and Stochastic Processes and 1/f^a Power Law Noise Generation," Proceedings of the IEEE, May, 1995. It is a nice read. If you still have questions after that, come back here. Regards, Andor
I have verified the Matlab code in a QPSK modulation system with a similar one that is built on simulink. The BERs matched :) Have obtained the paper too.... 26 pages! Will certainly try to read it. Thks Andor. Regards, kc "Andor" <an2or@mailcircuit.com> wrote in message news:1114158399.566733.229080@o13g2000cwo.googlegroups.com...>I guess that kind of depends how non-1/f the noise model is. You should > also find a link to the following paper > > N. J. Kasdin, "Discrete Simulation of Colored Noise and Stochastic > Processes and 1/f^a Power Law Noise Generation," Proceedings of > the IEEE, May, 1995. > > It is a nice read. If you still have questions after that, come back > here. > > Regards, > Andor >
