Hello! I am a student of the TGM a technical college in Vienna. I use the ADSP 21161N_ez_kite_lite board with a SHARC processor. I need help because I want to receive some signals (HIGH/LOW) from an external board which is connected to a port from the DSP. The signals will be used by the application. I have problems to address each bus-line from the port separate. I tried this by the external port 9 which I prefer, but with no success. An interrupt-routine should receive the signals. The timer and his interrupt are programmed successfully by me. I need this for my project which I need to get my graduation certificate from high school. Please help me! Regards Christian
ADSP 21161N ez_kite_lite, english
Started by ●April 22, 2005
Reply by ●April 22, 20052005-04-22
chris_08 wrote:> Hello! > > I am a student of the TGM a technical college in Vienna. > > I use the ADSP 21161N_ez_kite_lite board with a SHARC processor. I > need help because I want to receive some signals (HIGH/LOW) from an > external board which is connected to a port from the DSP. The signals > will be used by the application. > > I have problems to address each bus-line from the port separate. I > tried this by the external port 9 which I prefer, but with no success. > An interrupt-routine should receive the signals. The timer and his > interrupt are programmed successfully by me.I don't understand exactly what you're trying to do, but it sounds like you should be using flag pins instead of the external port. Have you read the Hardware Reference Manual? http://www.analog.com/processors/epManualsDisplay/0,2795,,00.html?SectionWeblawId=433&ContentID=58316&Language=English Watch for word wrap in that link. The external port is covered in chapter 7. The flag pins are in chapter 13. -- Jim Thomas Principal Applications Engineer Bittware, Inc jthomas@bittware.com http://www.bittware.com (603) 226-0404 x536 Things could be a lot better around here, but worse is more likely - Calvin
