Friends, I face the following problem. Because several vectors of differing lenghts occur in the description, I use Harris' convention of writing [h(n):M] to denote the vector h of length M. Assume I specify the desired magnitude response of a linear-phase FIR filter at N/2+1 evenly spaced points [H(n):N/2+1], starting with 0, ending at Fs/2, where Fs is the sampling rate. Then use the inverse DFT to get the N+1 tap FIR impulse response coefficients [h(n):N+1]. I am now required to reduce the order N of the FIR to M < N (both M and N are even). I do this using some (as yet unspecified) window [w(n):M+1]. This results in a new FIR with coefficients [h'(n):M+1]. I would like to use fast convolution with an N point FFT to implement the new FIR [h'(n):M+1]. This means I have to zero pad to length N and transform the zero padded impulse response with the DFT, let's write [H'(n):N/2+1] to denote the first half of the DFT of h'(n). I have the following questions: 1. Due to real-time constraints, I would like to calculate [H'(n):N/2+1] directly from [H(n):N/2+1], without having to switch to time domain in between. If we denote by [W(n):N/2+1] the DFT of the zero padded window [w(n):M+1], we should have H' = H * W (* is convolution) from the fact that h' = h . w (where . is point wise multiplication). However, the convolution of two N/2+1 length vectors resuluts in a length N vector, whereas I want the length of H' to be N/2+1. 2. How should the window [w(n):M+1] be chosen, such that H' can easily be calculated from H? I am thinking of some interpolation scheme to compute H' from H. The problem is that H' in general has no points in common with H, so I need to apply some smoothing to H before interpolation. How can this be interpreted in the time domain, ie. how can I guarantee that the impulse response of the FIR h' is indeed limited in the range -M/2 to M/2? Best regards, Andor
Interpolated frequency sampling linear-phase FIR design
Started by ●April 27, 2005
Reply by ●April 27, 20052005-04-27
Andor, Responses are interspersed below Fred "Andor" <an2or@mailcircuit.com> wrote in message news:1114597721.830492.52220@g14g2000cwa.googlegroups.com...> Friends, > > I face the following problem. Because several vectors of differing > lenghts occur in the description, I use Harris' convention of writing > [h(n):M] to denote the vector h of length M. > > Assume I specify the desired magnitude response of a linear-phase FIR > filter at N/2+1 evenly spaced points [H(n):N/2+1], starting with 0, > ending at Fs/2, where Fs is the sampling rate.Unless you are going to do something a bit more complex, the filter has to be defined from zero to fs-fs/(N+1) not Fs/2. When there are N+1 samples starting at zero, there will be N intervals spanned to the last sample and one more interval to get to fs - so N+1 intervals (assumed) between zero and fs. Each of the intervals spans fs/(N+1). Thus the above. (But you know this, eh?)>Then use the inverse DFT > to get the N+1 tap FIR impulse response coefficients [h(n):N+1]. I am > now required to reduce the order N of the FIR to M < N (both M and N > are even). I do this using some (as yet unspecified) window [w(n):M+1]. > This results in a new FIR with coefficients [h'(n):M+1].(I do wish that folks wouldn't mix "order" and "length" in the same discussion and I wish folks would stick with N and M for lengths! Not a criticism, just a wish.) :~)> I would like to use fast convolution with an N point FFT to implement > the new FIR [h'(n):M+1]. This means I have to zero pad to length N and > transform the zero padded impulse response with the DFT, let's write > [H'(n):N/2+1] to denote the first half of the DFT of h'(n). > > I have the following questions: > > 1. Due to real-time constraints, I would like to calculate > [H'(n):N/2+1] directly from [H(n):N/2+1], without having to switch to > time domain in between. If we denote by [W(n):N/2+1] the DFT of the > zero padded window [w(n):M+1], we should have H' = H * W (* is > convolution) from the fact that h' = h . w (where . is point wise > multiplication). However, the convolution of two N/2+1 length vectors > resuluts in a length N vector, whereas I want the length of H' to be > N/2+1.Consider the time-domain above first: You start with N+1 points in frequency and IFFT. You multiply with a length M+1 window where M<N, thus introducing zeros. You FFT the result including the zeros using length N+1. In frequency, the dual convolution is as you've observed and there is overlap. In order to avoid the overlap, you have to have arrays of length M+N+2-1. By doing the time domain multiplication (windowing to a shorter length) you have introduced frequency aliasing - mostly in the form of smearing. It's curious that you would use frequency multiplication (FFT/x/IFFT) to apply the desired filter but are trying to avoid doing the dual process for generating the filter (IFFT/x/FFT).> 2. How should the window [w(n):M+1] be chosen, such that H' can easily > be calculated from H? I am thinking of some interpolation scheme to > compute H' from H. The problem is that H' in general has no points in > common with H, so I need to apply some smoothing to H before > interpolation. How can this be interpreted in the time domain, ie. how > can I guarantee that the impulse response of the FIR h' is indeed > limited in the range -M/2 to M/2?Smoothing to H before interpolation? Interpolation is had by a smoothing process, no? I'd just look at some transform pairs of length M+1. One way to do what you want: Define a rectangular window of length M+1. The transform will be a Dirichlet. *All* windows will transform into a sum of a shifted set of weighted Dirichlets. The Dirichlets frequency scale depends on the temporal length. They have periodic zeros directly related to the temporal length. So, this may give you some insight into how to make that sum of Dirichlets into a "nice" convolution kernel. [I'm thinking that having lots of zeros in the kernel may be useful]. For example: Let's assume that M+1 = (N+1)/2. Now the Dirichlets will have zeros at every other frequency sample (except at the peak). You can construct a sum of shifted Dirichlets such that there are lots of zero-valued samples by forcing many of the shifted members to have zero weights. Similar to a half-band filter's weights which have almost N/2 zeros in their coefficient set. This really anwers your question because there are few "windows" that won't have lots of frequency domain samples - if "window" has the normal meaning / intent. Fred
Reply by ●April 28, 20052005-04-28
Fred, thanks for pitching in! Fred Marshall wrote:> > Assume I specify the desired magnitude response of a linear-phaseFIR> > filter at N/2+1 evenly spaced points [H(n):N/2+1], starting with 0, > > ending at Fs/2, where Fs is the sampling rate. > > Unless you are going to do something a bit more complex, the filterhas to> be defined from zero to fs-fs/(N+1) not Fs/2.If you don't supply a value at Fs/2, the frequency response specification is incomplete. Consider N = 4, N/2+1 = 3. Then the frequency resolution is (0, 1/4 Fs, 1/2 Fs, 3/4 Fs). To get a real vector after IDFT (the FIR coefficients), the frequency response vector must be of the form (H(0),H(1),H(2),H(1)*), where * denotes complex conjugate, and H(0) and H(2) have to be real (didn't you know that? ;-).> > I would like to use fast convolution with an N point FFT toimplement> > the new FIR [h'(n):M+1]. This means I have to zero pad to length Nand> > transform the zero padded impulse response with the DFT, let'swrite> > [H'(n):N/2+1] to denote the first half of the DFT of h'(n). > > > > I have the following questions: > > > > 1. Due to real-time constraints, I would like to calculate > > [H'(n):N/2+1] directly from [H(n):N/2+1], without having to switchto> > time domain in between. If we denote by [W(n):N/2+1] the DFT of the > > zero padded window [w(n):M+1], we should have H' = H * W (* is > > convolution) from the fact that h' = h . w (where . is point wise > > multiplication). However, the convolution of two N/2+1 lengthvectors> > resuluts in a length N vector, whereas I want the length of H' tobe> > N/2+1. > > Consider the time-domain above first: > You start with N+1 points in frequency and IFFT. > You multiply with a length M+1 window where M<N, thus introducingzeros.> You FFT the result including the zeros using length N+1. > In frequency, the dual convolution is as you've observed and there is> overlap. > In order to avoid the overlap, you have to have arrays of lengthM+N+2-1.> By doing the time domain multiplication (windowing to a shorterlength) you> have introduced frequency aliasing - mostly in the form of smearing.Agreed - for discrete vectors, the point-wise multiplication in "time domain" is equal to the circular convolution in "frequency domain".> It's curious that you would use frequency multiplication (FFT/x/IFFT)to> apply the desired filter but are trying to avoid doing the dualprocess for> generating the filter (IFFT/x/FFT).Haha, good point! I was motivated by the fact that the DFT of a Hann window has only three non-zero coefficients, and therefore the circular convolution can be calculated a lot quicker than (IFFT/x/FFT). Hence my question about a "good" window.> > 2. How should the window [w(n):M+1] be chosen, such that H' caneasily> > be calculated from H? I am thinking of some interpolation scheme to > > compute H' from H. The problem is that H' in general has no pointsin> > common with H, so I need to apply some smoothing to H before > > interpolation. How can this be interpreted in the time domain, ie.how> > can I guarantee that the impulse response of the FIR h' is indeed > > limited in the range -M/2 to M/2? > > Smoothing to H before interpolation?If you have an ordered set of values, smoothing means that you make the set less wiggly (usually with lowpass filtering of some kind). OTH, interpolation assumes that the set of values are samples of some continuous function, and you want to approximate that function in between the available samples.> Interpolation is had by a smoothing process, no?In this case, the true underlying function (the zero phase frequency response) can be retrieved by a weighted sum of shifted Dirichlet kernels. Interpolation is had by evaluating this function at the new sampling grid.> I'd just look at some transform pairs of length M+1. > > One way to do what you want: > Define a rectangular window of length M+1. The transform will be a > Dirichlet. > *All* windows will transform into a sum of a shifted set of weighted > Dirichlets. > The Dirichlets frequency scale depends on the temporal length. > They have periodic zeros directly related to the temporal length. > So, this may give you some insight into how to make that sum ofDirichlets> into a "nice" convolution kernel.That's what I arrived at yesterday as well. By the way, what is a good numeric approximation to the Dirichlet kernel? I tried Mathematica's minmax, but it wouldn't converge ...> [I'm thinking that having lots of zeros in the kernel may be useful]. > For example: > Let's assume that M+1 = (N+1)/2.Unfortunately, I cannot choose M - it is a given design parameter. All I can do is choose the window [w(n):M+1].> This really anwers your question because there are few "windows" thatwon't> have lots of frequency domain samples - if "window" has the normalmeaning /> intent.As I said, the DFT of the Hann window has only three non-zero coefficients. I guess I can compute the N point DFT of the zero-padded M point Hann window. Thanks for the discussion, Regards, Andor
"Andor" <an2or@mailcircuit.com> wrote in message news:1114676599.443239.231560@f14g2000cwb.googlegroups.com...> Fred, thanks for pitching in! > > Fred Marshall wrote: > >> > Assume I specify the desired magnitude response of a linear-phase > FIR >> > filter at N/2+1 evenly spaced points [H(n):N/2+1], starting with 0, >> > ending at Fs/2, where Fs is the sampling rate. >> >> Unless you are going to do something a bit more complex, the filter > has to >> be defined from zero to fs-fs/(N+1) not Fs/2. > > If you don't supply a value at Fs/2, the frequency response > specification is incomplete. Consider N = 4, N/2+1 = 3. Then the > frequency resolution is (0, 1/4 Fs, 1/2 Fs, 3/4 Fs). To get a real > vector after IDFT (the FIR coefficients), >Oh, I didn't mean that you didn't have to define it at fs/2. I meant you had to define it all the way up to fs-fs/(N+1) and to not stop at fs/2.> the frequency response vector must be of the form > (H(0),H(1),H(2),H(1)*), where * denotes complex conjugate, and H(0) > and H(2) have to be real (didn't you know that? ;-).Yes but I'm lazy. That's what I meant by "unless you do something a bit more complex". Saying H(3)=H(1)* is more complex :-) and it is "defining". I would rather talk about an IFFT on N points for purposes of discussion to avoid misconceptions. Then you can do what you want in implementation.>> One way to do what you want: >> Define a rectangular window of length M+1. The transform will be a >> Dirichlet. >> *All* windows will transform into a sum of a shifted set of weighted >> Dirichlets. >> The Dirichlets frequency scale depends on the temporal length. >> They have periodic zeros directly related to the temporal length. >> So, this may give you some insight into how to make that sum of > Dirichlets >> into a "nice" convolution kernel. > > That's what I arrived at yesterday as well. By the way, what is a good > numeric approximation to the Dirichlet kernel? I tried Mathematica's > minmax, but it wouldn't converge ...I'm being lazy again.... :-) A good numeric approximation to the Dirichlet should be: FFT(gate) e.g. FFT([1 1 1 1 0 0 ........ 0 0 1 1 1]) Once you have the central length of 1's (in this case 7), then put as many zeros as you like in the middle. You may find that the total N=10x or 20x the number of 1's is a good choice for a lot of things. So, if there are 7 1's as above N=140 and there are N-7=133 zeros.> >> [I'm thinking that having lots of zeros in the kernel may be useful]. >> For example: >> Let's assume that M+1 = (N+1)/2. > > Unfortunately, I cannot choose M - it is a given design parameter. All > I can do is choose the window [w(n):M+1]. > > >> This really anwers your question because there are few "windows" that > won't >> have lots of frequency domain samples - if "window" has the normal > meaning / >> intent. > > As I said, the DFT of the Hann window has only three non-zero > coefficients. I guess I can compute the N point DFT of the zero-padded > M point Hann window.Exactly, and then it won't have only three non-zero coefficients any more! As above... It's pretty easy to try it out: Try a "window" in frequency that's 0.5 1 0.5 so to keep things real it would be: [1 .5 0 0 ... 0 0 .5] defined over M+1 samples. IFFT this window with suitable scaling. You will get a raised cosine with peak 1.0 that is centered at zero time. Perhaps you will want to shift this so that it starts at zero time. Append zeros at the end to reach N+1 samples. FFT the result. You will see lots of nonzero samples in frequency - even though you only started with 3 nonzero samples. That's because you have effectively interpolated the original frequency response. And, that should be the effect of windowing N+1 samples down to M+1 samples - there will be frequency smearing - thus nonzero samples in the FFT of the window. Fred
Reply by ●April 29, 20052005-04-29
Fred Marshall wrote: ...> Oh, I didn't mean that you didn't have to define it at fs/2. I meantyou> had to define it all the way up to fs-fs/(N+1) and to not stop atfs/2. Sorry, my misunderstanding. It seems to be quite hard (as noted in other threads) to agree on one meaning of a written phrase ...> > As I said, the DFT of the Hann window has only three non-zero > > coefficients. I guess I can compute the N point DFT of thezero-padded> > M point Hann window. > > Exactly, and then it won't have only three non-zero coefficients anymore!> As above... > It's pretty easy to try it out: > Try a "window" in frequency that's 0.5 1 0.5 so to keep things realit would> be: > [1 .5 0 0 ... 0 0 .5] defined over M+1 samples. > IFFT this window with suitable scaling. > You will get a raised cosine with peak 1.0 that is centered at zerotime.> Perhaps you will want to shift this so that it starts at zero time. > Append zeros at the end to reach N+1 samples. > FFT the result. > You will see lots of nonzero samples in frequency - even though youonly> started with 3 nonzero samples. That's because you have effectively > interpolated the original frequency response. > And, that should be the effect of windowing N+1 samples down to M+1 > samples - there will be frequency smearing - thus nonzero samples inthe FFT> of the window.I think I will do it the "right" way: FFT/x/IFFT. Everything else is approximative, and probably takes longer to compute. However, I'm still interested in windows with few DFT coefficients (there is another application where I might be interested in windowing _after_ the DFT). Is there any treatsie on windows with maximum sidelobe roll-off given some fixed number of non-zero DFT coefficients? Regards, Andor
I asked: " Is there any treatsie on windows with maximum sidelobe roll-off given some fixed number of non-zero DFT coefficients? " Well, I found just the article: A H Nuttall: "Some Windows with Very Good Sidelobe Behaviour" IEEE Transactions on Acoustics, Speech, and Signal Processing, Vol. ASSP-29, No. 1, Feb. 1981
"Andor" <an2or@mailcircuit.com> wrote in message news:1114779891.017133.244780@o13g2000cwo.googlegroups.com...>I asked: > > " > Is there any treatsie on windows with maximum > sidelobe roll-off given some fixed number of non-zero DFT coefficients? > > " > > Well, I found just the article: > > A H Nuttall: > "Some Windows with Very Good Sidelobe Behaviour" > IEEE Transactions on Acoustics, Speech, and Signal Processing, > Vol. ASSP-29, No. 1, Feb. 1981 >
"Andor" <an2or@mailcircuit.com> wrote in message news:1114779891.017133.244780@o13g2000cwo.googlegroups.com...>I asked: > > " > Is there any treatsie on windows with maximum > sidelobe roll-off given some fixed number of non-zero DFT coefficients? > > " > > Well, I found just the article: > > A H Nuttall: > "Some Windows with Very Good Sidelobe Behaviour" > IEEE Transactions on Acoustics, Speech, and Signal Processing, > Vol. ASSP-29, No. 1, Feb. 1981Yes, you found one of the classics! Another is: harris, fred, "On the Use of Windows for Harmonic Analysis with the Discrete Fourier Transform", Proceedings of the IEEE, Vol. 66 No. 1, January 1978 pp 51-83 Something I did is in: Temes, Barcilon, Marshall "The Optimization of Bandlimited Sytems" Proc IEEE Vol 61 No. 2 Feb 1973 pp 196-234. What is particularly pertinent about the last paper is that we used sincs (or Dirichlets) as basis functions instead of sinusoids. Depending on how you look at it you may think there is really no difference - because sincs and Dirichlets are just sums of sinusoids - so its a mapping from one basis function set to another. However, if you approximate with sincs / Dirichlets then you can decide how many of them will be used while keeping the full set of sinusoids. This means that you can design an optimum function with 3 sincs or 5 sincs only. This means that you will have only 3 or 5 or .... samples in frequency that are nonzero. Just what you want it seems. I wrote a Remez-based program that approximates with sincs. So, it can be done. Here's how it works: Let's say you want to design a lowpass filter (which is a lot like the kernel that you want only you want it to be quite narrow, right?) Let's say you will use a minimax approach like the Remez algorithm. Let's say you don't mind if the stopband / sidelobes decay as you get some distance from the passband - as compared to being equiripple. You realize that sincs decay as 1/f and Dirichlets' sidelobes go flat at fs/2. You realize that sinc^2 decays as 1/f^3 and Dirichlets' sidelobes get pretty low at fs/2 also as long as there are enough sample points in frequency. So, imagine a lowpass filter that's made up of a contiguous sequence of sincs. And, imagine that there are nonzero sincs in the stopband that's adjacent to the passband. And, imagine that there are all zero sincs in the remaining stopband. So, there's a "cluster" of sincs on the stopband and its edges and there are no sincs elsewhere. The peak of each sinc is the value of the frequency sample. In your case you want the cluster of non-zero sincs to be small. The peak values are the samples you will use for convolution. Obviously your sincs will have periodicity related to M+1. So, you may still have problems making this work over your N+1 points..... The method works best if the new window is the same length as the original. So, in retrospect, I don't think this solves your problem very well. I'm still stuck on the notion that you're after non-obtainium. Fred
Reply by ●April 30, 20052005-04-30
On 29 Apr 2005 06:04:51 -0700, "Andor" <an2or@mailcircuit.com> wrote:>I asked: > >" >Is there any treatsie on windows with maximum >sidelobe roll-off given some fixed number of non-zero DFT coefficients? > >" > >Well, I found just the article: > >A H Nuttall: >"Some Windows with Very Good Sidelobe Behaviour" >IEEE Transactions on Acoustics, Speech, and Signal Processing, >Vol. ASSP-29, No. 1, Feb. 1981Hi Andor, If you experiment with Nuttall's equations, pay attention to his Eq. (5). It means that alternating a_k coefficients are negative. For example, the coefficients for his Eq. (30), on pp. 88, are: a_0 = 10/32, a_1 = -15/32, a_2 = 6/32, & a_3 = -1/32. See ya', [-Rick-]
