Hard drive head motor question
Started by Tim Wescott ●May 8, 2016
On Mon, 09 May 2016 13:33:20 +0000, Bob Masta wrote:
> On Sun, 08 May 2016 16:52:52 -0500, Tim Wescott > <seemywebsite@myfooter.really> wrote: > >>I know that someone who works, or has worked, on hard drives lurks here. >> >>I'm trying to re-purpose a hard drive head motor into a science demo. >>It appears to have 64 turns of #30 or #31 (or metric equivalent -- 9 >>turns of enameled wire fits into .09", at any rate), with a >>circumference of around 1.4". That works out to a total length of 90", >>and a resistance of 1 ohm or so. >> >>Yet the measured resistance of the coil is 15 ohms. >> >>Might there be some reason to intentionally add resistance to the coil, >>(buried where I can't see it), or is my math just cracked today? >> >>Also -- some control guys swear by embedding a shorted coil in their >>torquer motors. Is that common practice in the disk drive world? > > I don't suppose it's like those transformer winding where they use a > heavier gage for the external leads, with a much smaller gage just under > the paper skin?
Don't think so. It's an amazing little piece of manufacturing engineering, by the by. -- Tim Wescott Control systems, embedded software and circuit design I'm looking for work! See my website if you're interested http://www.wescottdesign.com
On Sun, 08 May 2016 16:52:52 -0500, Tim Wescott wrote:
> I know that someone who works, or has worked, on hard drives lurks here. > > I'm trying to re-purpose a hard drive head motor into a science demo. > It appears to have 64 turns of #30 or #31 (or metric equivalent -- 9 > turns of enameled wire fits into .09", at any rate), with a > circumference of around 1.4". That works out to a total length of 90", > and a resistance of 1 ohm or so. > > Yet the measured resistance of the coil is 15 ohms. > > Might there be some reason to intentionally add resistance to the coil, > (buried where I can't see it), or is my math just cracked today? > > Also -- some control guys swear by embedding a shorted coil in their > torquer motors. Is that common practice in the disk drive world?
A new coil, using about 20 feet of #34 wire (I calculate about 160 turns, but did not count), generates about twice the signal (60mV peak-peak at 1Hz) with a 4-ohm coil -- and it doesn't fill as much space with wire as they used. So I should be able to improve on their performance. Whatever was in the drive, they weren't optimizing for conductivity. -- Tim Wescott Wescott Design Services http://www.wescottdesign.com
On 5/9/2016 12:52 PM, Tim Wescott wrote:
> On Sun, 08 May 2016 16:52:52 -0500, Tim Wescott wrote: > >> I know that someone who works, or has worked, on hard drives lurks here. >> >> I'm trying to re-purpose a hard drive head motor into a science demo. >> It appears to have 64 turns of #30 or #31 (or metric equivalent -- 9 >> turns of enameled wire fits into .09", at any rate), with a >> circumference of around 1.4". That works out to a total length of 90", >> and a resistance of 1 ohm or so. >> >> Yet the measured resistance of the coil is 15 ohms. >> >> Might there be some reason to intentionally add resistance to the coil, >> (buried where I can't see it), or is my math just cracked today? >> >> Also -- some control guys swear by embedding a shorted coil in their >> torquer motors. Is that common practice in the disk drive world? > > A new coil, using about 20 feet of #34 wire (I calculate about 160 turns, > but did not count), generates about twice the signal (60mV peak-peak at > 1Hz) with a 4-ohm coil -- and it doesn't fill as much space with wire as > they used. So I should be able to improve on their performance. > > Whatever was in the drive, they weren't optimizing for conductivity.
That's not terribly surprising. The head movements are very fast and the currents are in pulses which are likely not resistance limited. Don Kuenz said his coil wire was larger gauge than estimated by resistance and suggested it might be copper clad aluminum. Given the skin effect on fast pulses and the need for low weight, that is not an unreasonable suggestion. Have you tried scraping or cutting the old coil wire to see if it was solid copper? -- Rick C
On Mon, 09 May 2016 13:04:45 -0400, rickman wrote:
> On 5/9/2016 12:52 PM, Tim Wescott wrote: >> On Sun, 08 May 2016 16:52:52 -0500, Tim Wescott wrote: >> >>> I know that someone who works, or has worked, on hard drives lurks >>> here. >>> >>> I'm trying to re-purpose a hard drive head motor into a science demo. >>> It appears to have 64 turns of #30 or #31 (or metric equivalent -- 9 >>> turns of enameled wire fits into .09", at any rate), with a >>> circumference of around 1.4". That works out to a total length of >>> 90", and a resistance of 1 ohm or so. >>> >>> Yet the measured resistance of the coil is 15 ohms. >>> >>> Might there be some reason to intentionally add resistance to the >>> coil, (buried where I can't see it), or is my math just cracked today? >>> >>> Also -- some control guys swear by embedding a shorted coil in their >>> torquer motors. Is that common practice in the disk drive world? >> >> A new coil, using about 20 feet of #34 wire (I calculate about 160 >> turns, >> but did not count), generates about twice the signal (60mV peak-peak at >> 1Hz) with a 4-ohm coil -- and it doesn't fill as much space with wire >> as they used. So I should be able to improve on their performance. >> >> Whatever was in the drive, they weren't optimizing for conductivity. > > That's not terribly surprising. The head movements are very fast and > the currents are in pulses which are likely not resistance limited. > > Don Kuenz said his coil wire was larger gauge than estimated by > resistance and suggested it might be copper clad aluminum. Given the > skin effect on fast pulses and the need for low weight, that is not an > unreasonable suggestion. Have you tried scraping or cutting the old > coil wire to see if it was solid copper?
I may eventually do that, but at the moment the original coil is the only usable one I have -- My shop is slightly more capable than the usual home shop, but the one coil I've built so far is a hand-made atrocity that is unusable. Hopefully the second try will be usable, with more bulk of wire, maybe in a smaller gauge, and wound more neatly on the form. -- Tim Wescott Wescott Design Services http://www.wescottdesign.com
On 2016-05-08, Tim Wescott <seemywebsite@myfooter.really> wrote:
> I know that someone who works, or has worked, on hard drives lurks here. > > I'm trying to re-purpose a hard drive head motor into a science demo. It > appears to have 64 turns of #30 or #31 (or metric equivalent -- 9 turns > of enameled wire fits into .09", at any rate), with a circumference of > around 1.4". That works out to a total length of 90", and a resistance > of 1 ohm or so. > > Yet the measured resistance of the coil is 15 ohms.
a shorted turn will slow its response down making it easier to control. I've not seen that in and disk drives. -- \_(&#12484;)_
110 feet of #40 wire gives me about 200mV p-p on a 1Hz pendulum, and "lots" of force when I put five volts on it (I couldn't measure -- it's "lots"). Total resistance is about 120 ohms, and it's big enough to dissipate 1/4 watt easily. This is becoming an obsession -- have you ever wound 100 feet of hair- fine wire onto a form? -- Tim Wescott Wescott Design Services http://www.wescottdesign.com I'm looking for work -- see my website!
On 11/05/16 15:00, Tim Wescott wrote:
> On Sun, 08 May 2016 16:52:52 -0500, Tim Wescott wrote: >> I'm trying to re-purpose a hard drive head motor into a science demo. >> Might there be some reason to intentionally add resistance to the coil, >> (buried where I can't see it), or is my math just cracked today?
Much reduced L/R time constant, at the price of needing a higher drive voltage. Is it possible that the disk drive generates, say 80V internally? A lot of the "pinwriter" style dot matrix printers use high drive voltages (up to 90V); and even 30-40V for low-ohm steppers.
>> Also -- some control guys swear by embedding a shorted coil in their >> torquer motors. Is that common practice in the disk drive world? > > 110 feet of #40 wire gives me about 200mV p-p on a 1Hz pendulum, and > "lots" of force when I put five volts on it (I couldn't measure -- it's > "lots"). Total resistance is about 120 ohms, and it's big enough to > dissipate 1/4 watt easily. > > This is becoming an obsession -- have you ever wound 100 feet of hair- > fine wire onto a form?
3300 feet (1km) #43 wire. Multiple times, but not manually. I started by building a winding machine...for guitar pickups. Clifford Heath
On Wed, 11 May 2016 15:29:53 +1000, Clifford Heath wrote:
> On 11/05/16 15:00, Tim Wescott wrote: >> On Sun, 08 May 2016 16:52:52 -0500, Tim Wescott wrote: >>> I'm trying to re-purpose a hard drive head motor into a science demo. >>> Might there be some reason to intentionally add resistance to the >>> coil, >>> (buried where I can't see it), or is my math just cracked today? > > Much reduced L/R time constant, at the price of needing a higher drive > voltage. Is it possible that the disk drive generates, say 80V > internally? A lot of the "pinwriter" style dot matrix printers use high > drive voltages (up to 90V); and even 30-40V for low-ohm steppers. > >>> Also -- some control guys swear by embedding a shorted coil in their >>> torquer motors. Is that common practice in the disk drive world? >> >> 110 feet of #40 wire gives me about 200mV p-p on a 1Hz pendulum, and >> "lots" of force when I put five volts on it (I couldn't measure -- it's >> "lots"). Total resistance is about 120 ohms, and it's big enough to >> dissipate 1/4 watt easily. >> >> This is becoming an obsession -- have you ever wound 100 feet of hair- >> fine wire onto a form? > > 3300 feet (1km) #43 wire. Multiple times, but not manually. > I started by building a winding machine...for guitar pickups.
It's bedded in epoxy, and since it's 30-minute epoxy I was starting to worry toward the end. Fortunately, while it was starting to get sticky toward the end, I still managed to finish. I have a lathe I could have wound it on, but I was afraid of overshooting and breaking that fine wire. -- Tim Wescott Control systems, embedded software and circuit design I'm looking for work! See my website if you're interested http://www.wescottdesign.com
On 2016-05-11, Tim Wescott <seemywebsite@myfooter.really> wrote:
> On Sun, 08 May 2016 16:52:52 -0500, Tim Wescott wrote: > >> I know that someone who works, or has worked, on hard drives lurks here. >> >> I'm trying to re-purpose a hard drive head motor into a science demo. >> It appears to have 64 turns of #30 or #31 (or metric equivalent -- 9 >> turns of enameled wire fits into .09", at any rate), with a >> circumference of around 1.4". That works out to a total length of 90", >> and a resistance of 1 ohm or so. >> >> Yet the measured resistance of the coil is 15 ohms. >> >> Might there be some reason to intentionally add resistance to the coil, >> (buried where I can't see it), or is my math just cracked today? >> >> Also -- some control guys swear by embedding a shorted coil in their >> torquer motors. Is that common practice in the disk drive world? > > 110 feet of #40 wire gives me about 200mV p-p on a 1Hz pendulum, and > "lots" of force when I put five volts on it (I couldn't measure -- it's > "lots"). Total resistance is about 120 ohms, and it's big enough to > dissipate 1/4 watt easily. > > This is becoming an obsession -- have you ever wound 100 feet of hair- > fine wire onto a form?
I re-wound the 240V primaries in a few ~10VA transformers when I was in high school... there's a lot of wire in them. -- \_(&#12484;)_
