I have bought a HIO EMB 1200 HW development board which runs Yocto Linux. I plan to do some audio processing on this board. For that reason, I also had to add the HIO 1240 IO module which provides the ability to hook up a microphone and a speaker via a 10-pin header. As far as I can tell, the header has the following layout: PIN 10: MIC IN PIN 8: MIC GND PIN 7: SPK GND PIN 8: SPK (RIGHT) PIN 5: SPK (LEFT) What would the easiest/fastest way be to get a microphone and a speaker to work with this board? Is there some "plug'n'play" kit out there which I can just buy and hook up? Thank you in advance. Pictures here ---> http://electronics.stackexchange.com/questions/233815/looking-for-a-compatible-microphone-need-advice
Looking for a compatible microphone - need advice
Started by ●May 12, 2016
Reply by ●May 12, 20162016-05-12
Mauritz Jameson <mjames2393@gmail.com> wrote:>I have bought a HIO EMB 1200 HW development board which runs Yocto >Linux. I plan to do some audio processing on this board. For that >reason, I also had to add the HIO 1240 IO module which provides the >ability to hook up a microphone and a speaker via a 10-pin header.>As far as I can tell, the header has the following layout: > >PIN 10: MIC IN >PIN 8: MIC GND >PIN 7: SPK GND >PIN 8: SPK (RIGHT) >PIN 5: SPK (LEFT)>What would the easiest/fastest way be to get a microphone and a speaker >to work with this board?Have you googled on something like "header pin test leads"? Steve
> Have you googled on something like "header pin test leads"? >Yes. I've googled for that as well, but I am not looking for guidance on wire-selection. I am looking for guidance regarding microphone+speaker selection.
Mauritz Jameson <mjames2393@gmail.com> wrote:>> Have you googled on something like "header pin test leads"?>Yes. I've googled for that as well, but I am not looking for guidance on >wire-selection. I am looking for guidance regarding microphone+speaker >selection.There doesn't seem to be any documentation for this board on hioproject.org . If you can identify which audio CODEC they are using, perhaps that is documented. Most of the time, a microphone input not otherwise specified expects a dynamic microphone (as opposed to a crystal microphone or a condensor microphone, although electret condensors have interfaces similar to that of a dynamic microphone). For the speaker outputs, it's unclear whether the unit expects to drive a powered speaker, or a plain un-powered speaker. In either case it should be able to drive earbuds. I think a bit of trial and error will tell you most of what you need to know. Steve
Steve Pope <spope33@speedymail.org> wrote:>There doesn't seem to be any documentation for this board on >hioproject.org . If you can identify which audio CODEC they >are using, perhaps that is documented. > >Most of the time, a microphone input not otherwise specified >expects a dynamic microphone (as opposed to a crystal microphone >or a condensor microphone, although electret condensors have >interfaces similar to that of a dynamic microphone). > >For the speaker outputs, it's unclear whether the unit expects >to drive a powered speaker, or a plain un-powered speaker. >In either case it should be able to drive earbuds.There is a little more information on http://hioproject.org/hio-basic-io-module/ The speaker outputs are stated to drive one watt. There are also line in and headphone out connections. Since one watt isn't a lot of power you may be best off connecting the headphone output to powered speakers (JBL, etc.) Any dynamic or electret-condensor microphone should work. Most of the time it is worth paying for a reasonably good microphone (e.g. Shure SM58, etc.) Good luck. Steve
Reply by ●May 13, 20162016-05-13
It seems they expect a mic similar to a hobby mic that you would plug into any PC. That is a small electret type. A low z pro SM58 will probably not work well connected directly to that with A preamp or at least a matching transformer. M
<makolber@yahoo.com> wrote:>It seems they expect a mic similar to a hobby mic that you would plug >into any PC. >That is a small electret type. >A low z pro SM58 will probably not work well connected directly to that with >A preamp or at least a matching transformer.Interesting, thanks. I know that a typical electret creates more signal than a typical dynamic microphone, but had not known this was really factored into the gain of a microphone input, to where a dynamic mike would not be suitable. So scratch the suggestion of an SM58. Steve
Mauritz Jameson wrote:> I have bought a HIO EMB 1200 HW development board which runs Yocto Linux. I plan to do some audio processing on this board. For that reason, I also had to add the HIO 1240 IO module which provides the ability to hook up a microphone and a speaker via a 10-pin header. > > As far as I can tell, the header has the following layout: > > PIN 10: MIC IN > PIN 8: MIC GND > PIN 7: SPK GND > PIN 8: SPK (RIGHT) > PIN 5: SPK (LEFT) > > What would the easiest/fastest way be to get a microphone and a speaker to work with this board? >What I would want is a 5X2 dual-row header ( female ) on one end and a terminal strip on the other. The 5X2 looks like: http://www.amazon.com/2-54mm-Pitch-2x5Pin-Ribbon-12-inch/dp/B00NQ8BFF2 You'll need to verify the pitch of the pins. Im guessing from your photo. The terminal strip may look like this: http://www.allelectronics.com/make-a-store/item/ter-104/4-position-pluggable-terminal-strip-and-header/1.html That's not exactly a complete solution, although you can strip and solder the ribbon, it's not ideal for it. And you'll need more conductors unless you want to buss the grounds ( not recommended ). Obviously, the speaker ground is common. If you use ribbons like that grey flat one, buy two or three of them while you learn how to work with the insulation. The headphone out @ 1W will drive a powered speaker or receiver and speakers well. There are small electret elements that can be battery powered that would be good for this. Google "Electret Condenser Microphone Element" - the few I found had monstrous URLs. You can use a condenser mic with a case and an XLR connector but you'll nic a "microphone amplifier" or "mic preamp"* with phantom power and it gets more complicated fast, but you'll have better control over position. *a very small mixer will also work: http://www.guitarcenter.com/Behringer/XENYX-802-Mixer-1275776902518.gc> Is there some "plug'n'play" kit out there which I can just buy and hook up? > > Thank you in advance. > > Pictures here ---> http://electronics.stackexchange.com/questions/233815/looking-for-a-compatible-microphone-need-advice >-- Les Cargill
Les Cargill <lcargill99@comcast.com> wrote:>There are small electret elements that can be battery powered that would >be good for this. Google "Electret Condenser Microphone >Element" - the few I found had monstrous URLs.>You can use a condenser mic with a case and an XLR connector but >you'll nic a "microphone amplifier" or "mic preamp"* with phantom >power and it gets more complicated fast, but you'll have better >control over position.In addition to battery-powered electrets and phantom-powered condensers, there are electrets powered from the 3.5 mm phone jack (5 volts). Whether the OP's header includes this power is unknown, given as there is no spec in evidence. Steve
I updated my post here: http://electronics.stackexchange.com/questions/233815/looking-for-a-compatible-microphone-need-advice and included a specification of the electrical circuits including another 4-PIN header (next to the 10-pin header) which can supply power. Please have a look :-) Thank you.
