radio913@aol.com wrote:> Randy Yates wrote: > >>"Bhaskar Thiagarajan" <bhaskart@deja.com> writes: >> >> >>><radio913@aol.com> wrote in message >>>news:1115423351.853877.150650@o13g2000cwo.googlegroups.com... >>> >>>>Eric Jacobsen wrote: >>>> >>>>>On 4 May 2005 22:37:57 -0700, radio913@aol.com wrote: >>>>> >>>>>... >>>>> >>>>> >>>>>> My question is that it seems that >>>>>>after our product does the A/D conversion on >>>>>>the baseband signals, that we are left with 24 >>>>>>positive frequencies and 24 "negative" ones. >>>>>> >>>>>> >>>>>> I understand that the negative >>>>>>frequencies are something like the >>>>>>imaginary portions of the FFT, or >>>>>>something like that. >>>>>> >>>>>> >>>>>> But if all the carriers are carrying >>>>>>different data, then the negative >>>>>>frequencies are not just a mirror image >>>>>>of the positive carriers, so it's not >>>>>>like a dual-sideband signal at all, where >>>>>>you can get rid of one side and still >>>>>>retain all the info. >>>>>> >>>>>> >>>>>> And how do they down-convert in 802.11, >>>>>>and extract "negative" frequencies? >>>>> >>>>>Complex values. Most implementations use direct-conversion to >>>>>baseband with a quadrature mix and two ADCs, one for the I > > channel > >>>>and >>>> >>>>>one for the Q. The FFT/IFFT is complex, so the output > > subcarriers > >>>>>will be complex and therefore not necessarily symmetric about > > zero > >>>>Hz. >>>> >>>> I understand the addition of the 90 degree out >>>>of phase of the quadrature component. What i don't >>>>get is what a "negative" frequency looks like in the >>>>baseband. Like what it would look like in the time-domain >>>>on an oscilloscope. >>> >>>The signals just run backwards on the scope... >>>Sorry, couldn't resist the wise-crack on a Friday eve. >> >>Actually that's pretty close to the truth. In order to see a complex >>signal on a scope, you'd use x-y mode, and in that mode a positive >>frequency will move counterclockwise while a negative frquency moves >>clockwise. >> > > > I was thinking it might actually be something like > this, is the phasor moving clock-wise or counter-clock-wise? > > > > >>>I hope you aren't starting another thread that starts an argument > > over real > >>>and complex signals - we've been over several rounds of "real > > signals can > >>>be sent over a wire, complex is just math and cannot be sent over > > wires". > >>Then all those orthogonal signalling schemes (all PSKs, e.g.) are >>being transmitted "illegally"??? >> >>Yeah, OK, so we use modulation to get two signals onto one wire. > > Still, > >>the point is that it isn't "just math." > > > > Sigh... I don't think anyone here's really > gonna help me..... >These should be considered meaningful and useful answers to your question. A bit whimsical, maybe, but to the point. If you don't find them helpful, maybe you need to be asking more basic questions. Regards, Steve
OFDM FFT 802.11a/g QUESTION ~~~~~~~~~~~~~~~~~~~~
Started by ●May 2, 2005
Reply by ●May 7, 20052005-05-07
Jerry Avins <jya@ieee.org> writes:> Randy Yates wrote: > > ... > >> Yeah, OK, so we use modulation to get two signals onto one wire. Still, >> the point is that it isn't "just math." > > I can multiplex two signal of any type if I modulate. Call me back > when you can send a baseband complex signal on a single wire in the > same direction. (Hybrids allow two baseband signals to be transmitted > on the same wire if they travel in opposite directions.)You might as well be saying, "Let me know when you can get a complex value into a real value." Of course the answer is "you can't," but it is just as ludicrous to imply that complex signals aren't significant and aren't in very real [no pun intended] ways used in many signal processing and communication systems. I think you know that, but I still get the impression that you want to blow off the importance of this mathematical system. -- % Randy Yates % "Bird, on the wing, %% Fuquay-Varina, NC % goes floating by %%% 919-577-9882 % but there's a teardrop in his eye..." %%%% <yates@ieee.org> % 'One Summer Dream', *Face The Music*, ELO http://home.earthlink.net/~yatescr
radio913@aol.com writes:> Sigh... I don't think anyone here's really gonna help me.....You may be right, in which case I'd ask for my money back. -- % Randy Yates % "My Shangri-la has gone away, fading like %% Fuquay-Varina, NC % the Beatles on 'Hey Jude'" %%% 919-577-9882 % %%%% <yates@ieee.org> % 'Shangri-La', *A New World Record*, ELO http://home.earthlink.net/~yatescr
On Sat, 07 May 2005 01:24:18 GMT, R.Lyons@_BOGUS_ieee.org (Rick Lyons) wrote:> >Ha. But complex *CAN* be sent over wires >if you have two wires.Hi, actually, as Clay Turner reminded me onetime, complex signals can be transmitted over a wire if you have two "channels". See Ya', [-Rick-]
On 6 May 2005 23:35:59 -0700, radio913@aol.com wrote: (snipped)> > > Sigh... I don't think anyone here's really >gonna help me.....Hi, your questions are simple, straightforward, and easy to ask. But believe me they're not simple to answer. I'm guesing that you might find some useful answers at: http://www.dspguru.com/info/tutor/quadsig2.htm Good Luck, [-Rick-]
Rick Lyons wrote:> On Sat, 07 May 2005 01:24:18 GMT, R.Lyons@_BOGUS_ieee.org (Rick Lyons) > wrote: > > > >>Ha. But complex *CAN* be sent over wires >>if you have two wires. > > > Hi, > actually, as Clay Turner reminded me onetime, > complex signals can be transmitted over a > wire if you have two "channels".So what do the channels consist of? Grooves that run the length of the wire? Instead of getting tricky with a definition of "send", let's discuss signals that can be displayed with a single oscilloscope probe. Or is there a way to sidetrack that discussion also? Jerry -- Engineering is the art of making what you want from things you can get. �����������������������������������������������������������������������
Randy Yates wrote:> Jerry Avins <jya@ieee.org> writes: > > >>Randy Yates wrote: >> >> ... >> >> >>>Yeah, OK, so we use modulation to get two signals onto one wire. Still, >>>the point is that it isn't "just math." >> >>I can multiplex two signal of any type if I modulate. Call me back >>when you can send a baseband complex signal on a single wire in the >>same direction. (Hybrids allow two baseband signals to be transmitted >>on the same wire if they travel in opposite directions.) > > > You might as well be saying, "Let me know when you can get a complex > value into a real value." Of course the answer is "you can't," but it > is just as ludicrous to imply that complex signals aren't significant > and aren't in very real [no pun intended] ways used in many signal > processing and communication systems. > > I think you know that,I do.> but I still get the impression that you want to > blow off the importance of this mathematical system.If by "importance" you mean "intrinsically unavoidable conceptual necessity", then yes; I think it's not important. If instead you mean "beautifully simple way to summarize and calculate" then it is certainly important. I see the complex representation of signals as a, well, representation. You see it as signal. I think that the issue is important for beginners. I know at least two people with IQs over 150 who can't face algebra without tears. When they were told that "minus times minus is plus" is a self-evident truth, and they were never able to figure out why, they both concluded that math was beyond their ken and turned to other topics. I got to one of them (the other was my first wife) early enough to save him by telling him that it is not logically necessary, but a definition adopted for convenience and elegance. I gave examples where this definition simplified an otherwise complicated analysis (and some systems where it doesn't apply). When you say of a signal represented by a complex number, "This is what it is" rather than "This is how we chose to represent it", you create an unnecessary hurdle for those who naturally look deep into relations. Some of them don't get over it. Jerry -- Engineering is the art of making what you want from things you can get. �����������������������������������������������������������������������
Randy Yates wrote: ...> Actually that's pretty close to the truth. In order to see a complex > signal on a scope, you'd use x-y mode, and in that mode a positive > frequency will move counterclockwise while a negative frquency moves > clockwise.Another point: If there's one wire, there's no X-Y display. Jerry -- Engineering is the art of making what you want from things you can get. �����������������������������������������������������������������������
On 6 May 2005 23:35:59 -0700, radio913@aol.com wrote:>Randy Yates wrote: >> "Bhaskar Thiagarajan" <bhaskart@deja.com> writes: >> >> > <radio913@aol.com> wrote in message >> > news:1115423351.853877.150650@o13g2000cwo.googlegroups.com... >> >> >> >> Eric Jacobsen wrote: >> >> > On 4 May 2005 22:37:57 -0700, radio913@aol.com wrote: >> >> > >> >> > ... >> >> > >> >> > > My question is that it seems that >> >> > >after our product does the A/D conversion on >> >> > >the baseband signals, that we are left with 24 >> >> > >positive frequencies and 24 "negative" ones. >> >> > > >> >> > > >> >> > > I understand that the negative >> >> > >frequencies are something like the >> >> > >imaginary portions of the FFT, or >> >> > >something like that. >> >> > > >> >> > > >> >> > > But if all the carriers are carrying >> >> > >different data, then the negative >> >> > >frequencies are not just a mirror image >> >> > >of the positive carriers, so it's not >> >> > >like a dual-sideband signal at all, where >> >> > >you can get rid of one side and still >> >> > >retain all the info. >> >> > > >> >> > > >> >> > > And how do they down-convert in 802.11, >> >> > >and extract "negative" frequencies? >> >> > >> >> > Complex values. Most implementations use direct-conversion to >> >> > baseband with a quadrature mix and two ADCs, one for the I >channel >> >> and >> >> > one for the Q. The FFT/IFFT is complex, so the output >subcarriers >> >> > will be complex and therefore not necessarily symmetric about >zero >> >> Hz. >> >> > >> >> >> >> I understand the addition of the 90 degree out >> >> of phase of the quadrature component. What i don't >> >> get is what a "negative" frequency looks like in the >> >> baseband. Like what it would look like in the time-domain >> >> on an oscilloscope. >> > >> > The signals just run backwards on the scope... >> > Sorry, couldn't resist the wise-crack on a Friday eve. >> >> Actually that's pretty close to the truth. In order to see a complex >> signal on a scope, you'd use x-y mode, and in that mode a positive >> frequency will move counterclockwise while a negative frquency moves >> clockwise. >> > > I was thinking it might actually be something like >this, is the phasor moving clock-wise or counter-clock-wise?Whatever they do, the rotation is opposite for positive or negative frequencies. In practice the baseband signal is always mixed up to some IF for transmission. It's only at baseband that this conceptual problem exists for some people.>> > I hope you aren't starting another thread that starts an argument >over real >> > and complex signals - we've been over several rounds of "real >signals can >> > be sent over a wire, complex is just math and cannot be sent over >wires". >> >> Then all those orthogonal signalling schemes (all PSKs, e.g.) are >> being transmitted "illegally"??? >> >> Yeah, OK, so we use modulation to get two signals onto one wire. >Still, >> the point is that it isn't "just math." > > > Sigh... I don't think anyone here's really >gonna help me.....Everybody that's posted has been trying to help, I think. I hope you're getting an appreciation that there are some signficant conceptual and philosophical issues buried under the question you've asked, and that's what's fueling the discussion. To attempt to simplify a bit, though, each subcarrier just has a magnitude and a phase. With complex input values the FFT can transform the received baseband signal into independent magnitude and phase values for each subcarrier. Since the modulations used all manipulate magnitude and phase to modulate the data, this allows full recovery in the receiver. As long as the FFT input is complex all of the subcarriers can be modulated independent of each other. Eric Jacobsen Minister of Algorithms, Intel Corp. My opinions may not be Intel's opinions. http://www.ericjacobsen.org
Rick Lyons wrote:> > > > Sigh... I don't think anyone here's really > >gonna help me..... > > Hi, > > your questions are simple, straightforward, and > easy to ask. But believe me they're not simple to answer. > I'm guesing that you might find some useful > answers at: > > http://www.dspguru.com/info/tutor/quadsig2.htm >Are you really the Richard Lyons that wrote the book i was reading last night at Barnes and Nobles? Excellent. A pleasure to hear from you. You chapter on the difference between linear and non-linear in the DSP world was VERY clearly written. There are some people who are extremely knowledgable about a subject, but it's even rarer to find one of them who can explain concepts CLEARLY to other people. I'm an analog RF/ADS/Smith Chart/phase-locked-loop engineer, so i'm more used to talking about Class C or Class A gate-biasing on n-channel enhancement-mode mosfets, and how IP3s grow with non-linearities, etc. But it was good to see non-linearity discussed from a DSP point of view. It looks like the 18 page link you wrote includes some discussion of the negative frequency baseband concept, so i'll absorb that and get back to you. Funny how the old Digital vs. Analog divide is getting fuzzier and fuzzier by the year, eh? This forces strictly RF guys like me to bug you DSP guys so we know at least a little bit about what happpens before/after the D/A/A/D converters. And also forces the digital people to learn co-planar waveguides and RF layout techniques. I was thinking of buying your book, it seems to be what i want. $80??? Damn! this reminds me of college! Could i order one from you directly? Maybe a first-timer discount? hehe! :) S.
