OFDM FFT 802.11a/g QUESTION ~~~~~~~~~~~~~~~~~~~~
Started by Unknown ●May 2, 2005
Jerry Avins wrote:
> I see the complex representation of signals as a, well,
representation.
> You see it as signal. I think that the issue is important for
beginners. I think "representation" is the key word here. In my field of work, which is acoustics, the "signal" "exists" in at least three forms: - The physical pressure field in the medium, which is what I'm interested in - The electrical signal inside the measurement device, which is the link to the physics - The numbers on file in my computer, which is what I manipulate during analysis. Each and every one of these representations have their own limitations. Physical pressure can never go negative. It can go to zero, but it can't go negative. We circumvent that hurdle by defining an "acoustic" pressure as P = p_0 + p where P is the "physical" (total) pressure, p_0 is the isostatic (background) pressure, and p is the fluctuations we concentrate on. So do we use a "true" representation when we choose to use the zero-mean fluctuation p and call it "the pressure signal"? Hardly. Is it a useful representation? Most certainly. The same thing can be said for the electrical signal in the recording device: It, too, has a refernce level we have to take into account, and here there is a maximum amplitude where the signal might clip in the power supply limits. Does this represent a limitation to signal? Sure. Do we care? Not at all, as long as the signal does not saturate. So these complex/real numbers fit the pattern. They represent certain views about the world. Whether they "mean" anything is up to each and every one to decide for themselves. The important thing is that the maths works, that the results are consistent and that the analysis is either simpler or more efficient with one representation or the other.
> I know at least two people with IQs over 150 who can't face algebra > without tears. When they were told that "minus times minus is plus"
is a
> self-evident truth, and they were never able to figure out why,
I may be wrong, but isn't that one of the 10 or 12 axioms that form the basis of maths?
> they > both concluded that math was beyond their ken and turned to other > topics. I got to one of them (the other was my first wife) early
enough
> to save him by telling him that it is not logically necessary, but a > definition adopted for convenience and elegance. I gave examples
where
> this definition simplified an otherwise complicated analysis (and
some
> systems where it doesn't apply). > > When you say of a signal represented by a complex number, "This is
what
> it is" rather than "This is how we chose to represent it", you create
an
> unnecessary hurdle for those who naturally look deep into relations. > Some of them don't get over it.
True. Over-simplification is a very dangerous thing. As the proverb says "as simple as possible but not simpler". Rune
Rick Lyons wrote:
> HI, > well, my thinking is that Clay meant some > sort of modulated signal where the > modulation, somehow, contains two > orthogonal signals that can represent > an "I" signal and a "Q" signal. > > At least that's what I thought.
Rick, Thinking about modulated signals as containing separate I and Q channels simplifies the subject to the point that I can begin to understand it. It's an inspired thing to do. Nevertheless, I hold firm to the belief that when that modulated signal travels down a wire, each instant and place is characterized by a single voltage which can be expressed by a real number. To me, that's what's actual. Jerry -- Engineering is the art of making what you want from things you can get. �����������������������������������������������������������������������
Randy Yates wrote:
> Fair enough. The context within which I tend to work in these usenet > posts is as far as what is posted and quoted, but this is indeed what > was said at that point. > > When I used the word "signal" there, I did not intend to imply that > I would always forever and ever constrain a "signal" to be a real > entity. > > So, now may we back up and resume?
OK, but first, some clarification. I'm not trying to convert you to another way of thinking about signal-processing issues. I'm not trying to change your views at all. I _am_ trying to explain mine to you. I don't see an argument that I can either concede or win. I just wrote to Rick: "Thinking about modulated signals as containing separate I and Q channels simplifies the subject to the point that I can begin to understand it. It's an inspired thing to do. Nevertheless, I hold firm to the belief that when that modulated signal travels down a wire, each instant and place is characterized by a single voltage which can be expressed by a real number. To me, that's what's actual." I get the impression that you reject that view, but the possibility remains that we haven't been communicating well enough for me to know that. Can we use that paragraph as a starting point for future discussion? Jerry -- Engineering is the art of making what you want from things you can get. �����������������������������������������������������������������������
Andor wrote:
> Jerry wrote: > > >>All right. Show me a transversal filter with a complex >>number of taps. :-0 > > > The reals and the integers are subsets of the complex numbers. In other > words if x is real, it is also complex. Every FIR has a complex number > of taps :-). > > Andor
Jolly good! And every square is a rectangle, or a rhombus, or a parallelogram, or a trapezoid, or a quadrilateral. And Andor is a life form! :-) Jerry -- Engineering is the art of making what you want from things you can get. �����������������������������������������������������������������������
"Bhaskar Thiagarajan" <bhaskart@deja.com> wrote in message
news:427c0e7a$0$79461$14726298@news.sunsite.dk...
> <radio913@aol.com> wrote in message > news:1115423351.853877.150650@o13g2000cwo.googlegroups.com... > > > > Eric Jacobsen wrote: > > > On 4 May 2005 22:37:57 -0700, radio913@aol.com wrote: > > > > > > ... > > > > > > > My question is that it seems that > > > >after our product does the A/D conversion on > > > >the baseband signals, that we are left with 24 > > > >positive frequencies and 24 "negative" ones. > > > > > > > > > > > > I understand that the negative > > > >frequencies are something like the > > > >imaginary portions of the FFT, or > > > >something like that. > > > > > > > > > > > > But if all the carriers are carrying > > > >different data, then the negative > > > >frequencies are not just a mirror image > > > >of the positive carriers, so it's not > > > >like a dual-sideband signal at all, where > > > >you can get rid of one side and still > > > >retain all the info. > > > > > > > > > > > > And how do they down-convert in 802.11, > > > >and extract "negative" frequencies? > > > > > > Complex values. Most implementations use direct-conversion to > > > baseband with a quadrature mix and two ADCs, one for the I channel > > and > > > one for the Q. The FFT/IFFT is complex, so the output subcarriers > > > will be complex and therefore not necessarily symmetric about zero > > Hz. > > > > > > > I understand the addition of the 90 degree out > > of phase of the quadrature component. What i don't > > get is what a "negative" frequency looks like in the > > baseband. Like what it would look like in the time-domain > > on an oscilloscope. > > The signals just run backwards on the scope... > Sorry, couldn't resist the wise-crack on a Friday eve. > > I hope you aren't starting another thread that starts an argument over
real
> and complex signals - we've been over several rounds of "real signals
can
> be sent over a wire, complex is just math and cannot be sent over wires".
Monday morning makes me realize I should run for a bucket of water and put out this fire :-) But S (the OP) - don't complain that I didn't warn you. But seriously, I think Eric Jacobsen's recent post should've given enough to think about regards your original question. It might also help to state *exactly* what about negative frequencies you have trouble with...you'll no doubt generate a multitude of responses but that's usenet. Cheers Bhaskar
Stan Pawlukiewicz wrote:
> Jerry Avins wrote: > >> Randy Yates wrote: >> >>> Jerry Avins <jya@ieee.org> writes: >>> >>> >>>> When you say of a signal represented by a complex number, "This is >>>> what it is" rather than "This is how we chose to represent it", you >>>> create an unnecessary hurdle for those who naturally look deep into >>>> relations. Some of them don't get over it. >>> >>> >>> >>> >>> How would you, then, represent the square root of -1 by a real number? >> >> >> >> I would not claim that a voltage's fundamental representation involved >> the square root of -1 in any way. I show anyone who needs trig for any >> purpose that complex arithmetic can derive all the trig identities and >> manipulate all the trig relations with great ease. That's an entirely >> different matter. You can sell me j volts when your grocer sells you j >> pounds of potatoes. >> >> Jerry > > > > My checking account often has a j balance.
The real number line is an adequate description of mine. Right now, the balance is negative. Real negative! Jerry -- Engineering is the art of making what you want from things you can get. &#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;
Those statements are all correct :-). To prove the last, look here to
see me feeding my daughter Viviana during the break of a foosball
tournament:
http://www.fordere.ch/bar-foos-league/galleries/bflfinal_liga1_05_096.jpg
She has grown, hasn't she?
Regards,
Andor
Jon Harris wrote:
> "Jerry Avins" <jya@ieee.org> wrote in message > news:Ct6dnemnypNTTOHfRVn-pg@rcn.net... > >>I know at least two people with IQs over 150 who can't face algebra without >>tears. When they were told that "minus times minus is plus" is a self-evident >>truth, and they were never able to figure out why, they both concluded that >>math was beyond their ken and turned to other topics. I got to one of them >>(the other was my first wife) early enough to save him by telling him that it >>is not logically necessary, but a definition adopted for convenience and >>elegance. I gave examples where this definition simplified an otherwise >>complicated analysis (and some systems where it doesn't apply). > > > Out of curiosity, what types of examples did you use? I had a memorable similar > conversation with a "non-math guy" friend of mine over lunch where he challenged > me to explain why a negative times a negative was positive. I came up with a > fairly simple example using the familiar trains traveling in opposite directions > story problem where an answer that was intuitively obvious required that a > negative times a negative was positive to make the math work out. He conceded > that it did make sense, so that was a positive. But I was never fully satisfied > with my explanation since I had to somewhat arbitrarily define a "zero" point in > order to make certain quantities negative, so it seemed a bit of a contrived > system.
I reasoned about areas, where zero isn't arbitrary. Geometrically expand (a+b)^2, showing the areas of the individual products. Do it again for (a-b)^2. You get the large square a^2, two overlapping rectangles ab which are subtracted from it, and the small square a^2, the area of the overlap which, having been subtracted twice, must be added back. One is faced with two choices: special rules to account for situations like these, or a general rule that takes care of all such. The richness of arithmetic derives from avoiding special rules. Example: "If, in subtracting a from b it happens that a is larger, subtract b from a instead, and write the result with red ink." Then other rules follow about using red numbers. Negative numbers aren't necessary, just convenient. The same applies to our sign conventions. Jerry -- Engineering is the art of making what you want from things you can get. &#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;
news:p82dnRfwGqRACeLfRVn-hw@rcn.net...
> Jon Harris wrote: > > "Jerry Avins" <jya@ieee.org> wrote in message > > news:Ct6dnemnypNTTOHfRVn-pg@rcn.net... > > > >>I know at least two people with IQs over 150 who can't face algebra without > >>tears. When they were told that "minus times minus is plus" is a
self-evident
> >>truth, and they were never able to figure out why, they both concluded that > >>math was beyond their ken and turned to other topics. I got to one of them > >>(the other was my first wife) early enough to save him by telling him that
it
> >>is not logically necessary, but a definition adopted for convenience and > >>elegance. I gave examples where this definition simplified an otherwise > >>complicated analysis (and some systems where it doesn't apply). > > > > > > Out of curiosity, what types of examples did you use? I had a memorable
similar
challenged
a
directions
> > story problem where an answer that was intuitively obvious required that a > > negative times a negative was positive to make the math work out. He
conceded
satisfied
point in
> > order to make certain quantities negative, so it seemed a bit of a contrived > > system. > > I reasoned about areas, where zero isn't arbitrary. Geometrically expand > (a+b)^2, showing the areas of the individual products. Do it again for > (a-b)^2. You get the large square a^2, two overlapping rectangles ab > which are subtracted from it, and the small square a^2, the area of the > overlap which, having been subtracted twice, must be added back. One is > faced with two choices: special rules to account for situations like > these, or a general rule that takes care of all such. The richness of > arithmetic derives from avoiding special rules.
That's an approach I haven't seen before--good one!
> Example: "If, in subtracting a from b it happens that a is larger, > subtract b from a instead, and write the result with red ink." Then > other rules follow about using red numbers. Negative numbers aren't > necessary, just convenient. The same applies to our sign conventions.
Agree 100%. Few people understand that 1) our mathematics system is one of conventions, not absolute truths and that other systems could have been used instead and 2) the conventions chosen are logical and elegant and simplify solving our real-world problems, so they are not arbitrary. When we find real-world problem we cannot effectively solve, we invent new math to help us (i.e. imaginary numbers), making sure the new conventions make sense in the big picture.
Jerry Avins wrote:
(someone wrote)
>>> I know at least two people with IQs over 150 who can't face algebra >>> without tears. When they were told that "minus times minus is plus" >>> is a self-evident truth, and they were never able to figure out why, >>> they both concluded that math was beyond their ken and turned to >>> other topics.
(snip)
It might take some algebra to understand that example, though. My favorite problems discussing math with kids who are just starting to understand these problems involve cookies. Subtraction is something like "you have five cookies and eat two, how many do you have left." Multiplication might be "You give three cookies to each of your two friends. How many cookies did you give out." It gets interesting with negative numbers, "You give three cookies to negative two friends", or "you give negative three cookies to negative two friends". Well, at least zero isn't arbitrary in this case. -- glen
