Jerry Avins wrote: (snip describing complex numbers, potatoes, volts, and money)> The real number line is an adequate description of mine. Right now, the > balance is negative. Real negative!When I was younger, learning about negative numbers but not yet checking accounts I tried to understand negative dollars. I had imagined special negative dollar bills with complex packaging and electronics that prevented you from getting rid of them except by taking them to a bank with the appropriate number of positive dollars. -- glen
OFDM FFT 802.11a/g QUESTION ~~~~~~~~~~~~~~~~~~~~
Started by ●May 2, 2005
Reply by ●May 9, 20052005-05-09
Jerry Avins wrote:> I can multiplex two signal of any type if I modulate. Call me back when> you can send a baseband complex signal on a single wire in the same > direction. (Hybrids allow two baseband signals to be transmitted on > the same wire if they travel in opposite directions.) and in another post wrote:> I just wrote to Rick: "Thinking about modulated signals as containing > separate I and Q channels simplifies the subject to the point that I can > begin to understand it. It's an inspired thing to do. Nevertheless, I > hold firm to the belief that when that modulated signal travels down a > wire, each instant and place is characterized by a single voltage which > can be expressed by a real number. To me, that's what's actual."and in a third post (not necessarily in order) wrote: > I can multiplex two signal of any type if I modulate. Call me back > when you can send a baseband complex signal on a single wire in the > same direction. (Hybrids allow two baseband signals to be transmitted > on the same wire if they travel in opposite directions.) It is interesting the number of cases where two signals are sent together with some sort of quadrature modulation. It might be that one of the first I learned about was FM stereo. I started learning about electronics when my father built a Heathkit tuner when I was about seven or eight. I got to build the amplifier a year or two later. The 19kHz pilot is needed to properly demodulate the subcarrier. For the NTSC chrominance signal, quadrature modulated, the color burst is needed as a reference. Without it, it is not possible to separate the two components. The two signals in the opposite direction are another interesting case. They are not separable measuring only the voltage at a point, but they are by measuring the voltage and current at a point. (In electromagnetic terms, E and B components of the electromagnetic wave.) Another interesting case is quadrature modulation for digital signals, such as QAM modems. The reference signal is recovered by squaring and filtering the signal, assuming there are a sufficient number of phase transitions. To ensure phase transitions in the case of low entropy signals (such as a continuous train of zero bits) a scrambler is used before modulation, and descrambler afterwards. In all cases information outside that used to actually send the signal must be available to recover the two components from one signal. -- glen
Rick Lyons wrote: (snip)> Ha. But complex *CAN* be sent over wires > if you have two wires.Well, you usually have two wires, though there once was a system that would send signals over one wire. (Coupling the center conductor of a coax cable onto a single wire, without an abrupt transition.) Consider, though, that you can send a signal with no wires (radio) and in that case you can send two signals with orthogonal polarization. Either two perpendicular linear polarization modes, or left and right circular polarization. In this case, as with the case of signals going opposite direction on a transmission line, it is the case of separate E and B fields, and the allowable phase of the two. -- glen
glen herrmannsfeldt wrote:> Rick Lyons wrote: > > (snip) > >> Ha. But complex *CAN* be sent over wires >> if you have two wires. > > > Well, you usually have two wires, though there once was a system > that would send signals over one wire. (Coupling the center conductor > of a coax cable onto a single wire, without an abrupt transition.) > > Consider, though, that you can send a signal with no wires > (radio) and in that case you can send two signals with orthogonal > polarization. Either two perpendicular linear polarization modes, > or left and right circular polarization. In this case, as with the > case of signals going opposite direction on a transmission line, it is > the case of separate E and B fields, and the allowable phase of the two. > > -- glenAll this is tangential to what I tried to convey, but interesting. Actually, according to field theory (Kirchoff's Laws oversimplify it, as Newtonian mechanics does relativity), power doesn't travel along a wire at all, but in the space along side it. (Poynting vector and all that.) Such theoretical refinements don't bear on the discussion I've been having. The theory of the G-string -- as the one-wire transmission device you mentioned is called -- is easily explained with only a little arm waving. Consider a sphere far removed from any other conductor. It has capacitance. As the distance from it its surroundings increases, the capacitance decreases asymptotically to an amount that depends only on its radius. (Capacitance is measured in centimeters in the CGS system of units; the asymptotic minimum capacitance is equal to the radius.) We then say that the other "plate" of the capacitor is at infinity. Now look at a G-string. The end of the co-ax shield connects to a horn called a launcher. (If the flare is low enough, it might as well be a cone. An exponential launcher can be shorter.) When the launcher has reached an "big enough" diameter (big enough depends on the wavelength), the impedance is so high that an abrupt transition of diameter to infinity has vanishing effect. At that diameter, the wave is launched. This is not an antenna. The wave will follow curves in the wire that are not "too sharp". It is possible to have a launcher on one pole and a mating catcher in the next, with the wire hanging in a catenary between them. The field strength decreases with distance from the wire. Plots of field strength vs. distance near a G-string and much nearer the center conductor of a coax that to the shield are indistinguishable to my eye. The actual math is not simple. The inventor didn't use any. He waved his arms as I described, tried it, and showed that it works. Jerry -- Engineering is the art of making what you want from things you can get. �����������������������������������������������������������������������
Andor wrote:> Those statements are all correct :-). To prove the last, look here to > see me feeding my daughter Viviana during the break of a foosball > tournament: > > http://www.fordere.ch/bar-foos-league/galleries/bflfinal_liga1_05_096.jpg > > She has grown, hasn't she? > > Regards, > AndorThey sure do grow fast! Do you also want to host the material at http://users.rcn.com/jyavins/bariska.htm? Jerry -- Engineering is the art of making what you want from things you can get. �����������������������������������������������������������������������
glen herrmannsfeldt wrote:> Jerry Avins wrote: > > (snip describing complex numbers, potatoes, volts, and money) > >> The real number line is an adequate description of mine. Right now, >> the balance is negative. Real negative! > > > When I was younger, learning about negative numbers but not yet checking > accounts I tried to understand negative dollars. I had imagined special > negative dollar bills with complex packaging and electronics that > prevented you from getting rid of them except by taking them to a bank > with the appropriate number of positive dollars. > > -- glenHow about negative coconuts? http://www.csit.fsu.edu/~burkardt/fun/puzzles/coconut_puzzle.html -- Engineering is the art of making what you want from things you can get. �����������������������������������������������������������������������
Jerry Avins wrote: (snip)> All this is tangential to what I tried to convey, but interesting. > Actually, according to field theory (Kirchoff's Laws oversimplify it, as > Newtonian mechanics does relativity), power doesn't travel along a wire > at all, but in the space along side it. (Poynting vector and all that.) > Such theoretical refinements don't bear on the discussion I've been having.I did mention E and B just for that reason. (Maybe that was a different post.)> The theory of the G-string -- as the one-wire transmission device you > mentioned is called -- is easily explained with only a little arm > waving. Consider a sphere far removed from any other conductor. It has > capacitance. As the distance from it its surroundings increases, the > capacitance decreases asymptotically to an amount that depends only on > its radius. (Capacitance is measured in centimeters in the CGS system of > units; the asymptotic minimum capacitance is equal to the radius.) We > then say that the other "plate" of the capacitor is at infinity.> Now look at a G-string. The end of the co-ax shield connects to a horn > called a launcher. (If the flare is low enough, it might as well be a > cone. An exponential launcher can be shorter.) When the launcher has > reached an "big enough" diameter (big enough depends on the wavelength), > the impedance is so high that an abrupt transition of diameter to > infinity has vanishing effect. At that diameter, the wave is launched.I remember mentioning this one before and that you knew more details than I did. I believe I saw it in Popular Electronics many years ago, most likely from an older issue from the library.> This is not an antenna. The wave will follow curves in the wire that are > not "too sharp".(snip) Waves can also travel on the outside of the outer conductor of coaxial cables in a similar way, often when you don't want them to do that. -- glen
Jerry Avins <jya@ieee.org> writes:> Randy Yates wrote: > > ... > >> Fair enough. The context within which I tend to work in these usenet >> posts is as far as what is posted and quoted, but this is indeed what >> was said at that point. When I used the word "signal" there, I did >> not intend to imply that >> I would always forever and ever constrain a "signal" to be a real >> entity. So, now may we back up and resume? > > OK, but first, some clarification. I'm not trying to convert you to > another way of thinking about signal-processing issues. I'm not trying > to change your views at all. I _am_ trying to explain mine to you. I > don't see an argument that I can either concede or win.I sense a conflict between your beliefs and mine. I don't mind facing the conflict head-on. If you'd prefer to dress it down and not call it a conflict, then I'm not playing that game. If, however, you want to verify that we do indeed have a conflict and not a difference in terminology or some such, then I'm game. Now before you get mad, read on because I'm about to agree with you. :)> I just wrote to Rick: "Thinking about modulated signals as containing > separate I and Q channels simplifies the subject to the point that I > can begin to understand it. It's an inspired thing to > do. Nevertheless, I hold firm to the belief that when that modulated > signal travels down a wire, each instant and place is characterized by > a single voltage which can be expressed by a real number. To me, > that's what's actual."I agree.> I get the impression that you reject that view, but the possibility > remains that we haven't been communicating well enough for me to know > that. Can we use that paragraph as a starting point for future > discussion?Yes, sure Jerry. This is what I meant by simply stating that "a real quantity [voltage, potato count, whatever] can be represented by a real number." That point is obvious and maddeningly trivial. What I instead hear you saying at a deeper level is this: "Even when there ARE complex quantites, they're complexness isn't really required but is just a convenient way of dealing with two real quantities." It is THAT perspective that I disagree with and I think is deeply errant. Tag, you're it. -- % Randy Yates % "Ticket to the moon, flight leaves here today %% Fuquay-Varina, NC % from Satellite 2" %%% 919-577-9882 % 'Ticket To The Moon' %%%% <yates@ieee.org> % *Time*, Electric Light Orchestra http://home.earthlink.net/~yatescr
Reply by ●May 10, 20052005-05-10
Jerry, of course I don't expect you to host the photo album of my family :-). I don't have my own webpage currently, so I can't host it neither. I intended to update you with some new pics, unfortunately I still didn't get around to doing that. OTH, perhaps it's a bit silly to post these here (only comp.dspers know that link), so if you feel it is taking up too much space of your webpage, feel free to delete it. Thanks anycase, Andor PS: Did you notice how Mark hasn't been around since his son Matthew was born? Been there, done that ... :-)
Randy Yates wrote: ...> What I instead hear you saying at a deeper level is this: "Even when > there ARE complex quantites, they're complexness isn't really required > but is just a convenient way of dealing with two real quantities." It > is THAT perspective that I disagree with and I think is deeply errant. > > Tag, you're it.Good work! That lays out our different views very clearly. I will cite an example of that led me to my view. If experience is a guide, you might see then as an attack. I hope not. It seems inconceivable today to describe electro-magnetic propagation in space entirely in terms of real numbers. It would be derelict to teach it that way. Yet in J. C. Maxwell's "A Treatise on Electricity and Magnetism". no use is made of complex numbers. Although quaternions were available to Maxwell, he didn't use them. "Maxwell's equations" consist of several pages of triplets of integral equations. We have already agreed that a voltage on a single wire can be (even if with unnecessary obscurity) be described by a real number. Maxwell's astonishing synthesis shows that waves in space can likewise be described by sets of real numbers, each of which characterizes a real quantity. That's why I believe what I do. If you feel that my reasons are invalid, I'd like to know why. Jerry P.S. I won't be able to continue this discussion until next week. -- Engineering is the art of making what you want from things you can get. �����������������������������������������������������������������������
