jerome wrote:> > I'm sorry but i can't see how you can reset VCOUNT thanks to SAV/EAV codes > if these codes aren't included during the vertical blanking period?! Maybe > you found a way to add them ? Could you explain how you do it ? Thanks.I can't explain it I'm afraid, because it just worked! I have made no modifications to the decoder part of the driver at all, apart from to make some changes to the AGC settings and input selection registers. Cheers mark-r -- "Let's meet the panel. You couldn't ask for four finer comedians - so that answers your next question..." -- Humphrey Lyttleton
DM642 Video capture issue
Started by ●May 3, 2005
Reply by ●May 13, 20052005-05-13
Reply by ●May 16, 20052005-05-16
Hi,>I can't explain it I'm afraid, because it just worked! I have made no >modifications to the decoder part of the driver at all, apart from to >make some changes to the AGC settings and input selection registers.Thank you Mark anyway. Is there anybody else who could help us ? Thanks in advance. Jerome This message was sent using the Comp.DSP web interface on www.DSPRelated.com
