Hi. Phase noise and spurious noise are impairments of PLL. The difference between phase noise and spurious noise is the latter is a pure tone while the former is a 'collection' of tones. Phase noise, as the name implies, changes the phase of a signal while preserving the magnitude. I am unable to visualize how this is so. Can anyone point out useful links or explain the concept behind it? So how about spurious noise? Does it only change the phase of a signal or the magnitude as well? Thanks! -- Regards, kc
Effect of Phase Noise & Spurious Noise on a Signal
Started by ●May 4, 2005
Reply by ●May 4, 20052005-05-04
ckiancho wrote:> Hi. > > Phase noise and spurious noise are impairments of PLL. The difference> between phase noise and spurious noise is the latter is a pure tonewhile> the former is a 'collection' of tones. > > Phase noise, as the name implies, changes the phase of a signal while> preserving the magnitude. I am unable to visualize how this is so.Can> anyone point out useful links or explain the concept behind it?You have to consider time and frequency domain separately. You can (theoretically) change the phase and keep the magnitude in frequency domain, but that's effectively a PM modulation in time domain. Which means there will be some ripple introduced to the signal envelope in time doamin. I guess a more precise description would be that "Phase noise changes the phase considerably while the effects on the signal envelope in time domain are neglible".> So how about spurious noise? Does it only change the phase of asignal or> the magnitude as well?Well, I don't really know how to answer this... The effects of spurious noise would be to mess up the signal in time domain. Check out the "Additive White Gaussian Noise" (AWGN) model. The useful signal is modeled as a sinusoidal, which has a narrow- band energy spectrum. The AWGN noise is broad-band in nature. So the effects of AWGN noise is not so much that it messes with the magnitude and phase of the useful signal (it does, to some extent), as it is to introduce "amplitudes and phases" at frequency components that have vanishing magnitudes in the noise-free signal. Rune
"ckiancho" <northlandstarz-newsgroup@yahoo.com.sg> wrote in message news:d59lpu$1j5$1@nobel.pacific.net.sg...> Hi. > > Phase noise and spurious noise are impairments of PLL. The difference > between phase noise and spurious noise is the latter is a pure tone while > the former is a 'collection' of tones. > > Phase noise, as the name implies, changes the phase of a signal while > preserving the magnitude. I am unable to visualize how this is so. Can > anyone point out useful links or explain the concept behind it? > > So how about spurious noise? Does it only change the phase of a signal or > the magnitude as well? > > Thanks! > > -- > Regards, > kcHi kc : http://rfdesign.com/mag/radio_managing_noise_spurious/ is not bad. If you take just about any constant envelope signal , add unwanted 'spurious' signals to it and then pass the whole thing through a hard-limiter you will have added spurious components which are , at least in theory, only modulating your signals phase. In practice, if you filter out some of your mixing products in a channel filter or some other narrow band processing after the hard limiter then you will find both phase and amplitude modulation of your wanted signal. Best of Luck - Mike http://www.es.oersted.dtu.dk/~pa/31636/pdf/plls.pdf#search='mixing%20products%20multiplier' might be useful.
