Hello Where can I find a data base containing both Music and Speech samples ? Thanks Haim
Music and Speech Database
Started by ●August 24, 2004
Reply by ●August 24, 20042004-08-24
Hi. HaimG> Hello Where can I find a data base containing both Music and HaimG> Speech samples ? Thanks Haim SQAM contains both and is available online: http://www.ebu.ch/en/technical/publications/Tech_3000_series/tech3253/index.php Whether it is sufficient, depends on what you want to do :-) -- /Mads (http://kom.auc.dk/~mgc)
Reply by ●April 6, 20052005-04-06
>Hi. > >HaimG> Hello Where can I find a data base containing both Music and >HaimG> Speech samples ? Thanks Haim > >SQAM contains both and is available online: > >http://www.ebu.ch/en/technical/publications/Tech_3000_series/tech3253/index.php > >Whether it is sufficient, depends on what you want to do :-) > >-- >/Mads (http://kom.auc.dk/~mgc) >Just to let you now this URL has changed into: http://www.ebu.ch/en/technical/publications/tech3000_series/tech3253/index.php Best regards, Frans EBU This message was sent using the Comp.DSP web interface on www.DSPRelated.com
