FFT & averaging
Started by Rolf Keller May 10, 2005
Mark Borgerding wrote:
> Andor wrote: > >>>In simpler words, since the DFT is unitary, the euclidian length
of
> >>>vector is invariant under the DFT.
> Ah, yes. Much simpler. *POP* *(struggles to extract tongue from
cheek)* Well, if you are familiar with the definitions, then my point was that one can state Parseval's relation in simple words (see above).
> Sorry Andor, I just couldn't resist.
No problem. Sometimes, I get carried away by my affinity for linear algebra ... :-)
> I view Parseval's equality in terms of what it means to the > practitioner, not the mathematical properties that make it so. > > I'm sure both viewpoints are needed at various times. >
There is another nice property that follows from Parseval. Let's say, you have some linear transform U, and you have verified Parseval's relation (ie.(x, x) = (U x, U x), for all x). Then this already suffices to show that U is unitary: We need to show (U x, U y) = (x, y) for all vectors x, y. So let x and y be any non-zero vectors (otherwise the statement is trivial). Write y = y_1 + y_2, where y_1 is parallel to x, and y_2 is perpendicular to x (in any Hilbert space, this decomposition is unique), ie. y_1 = x (x,y)/(x,x), and y_2 = y - y_1. Then you have (U x, U y) = (U x, U (y_1 + y_2)) = (U x, U y_1) = (x, y)/(x, x) (U x, U x) = (x, y) where the last equation follows because of Parseval's relation. So there you have it, U is unitary. This implies again, for example, that U maps sets of orthonormal vectors to orthonormal vectors (ie. the angle between the vectors is also invariant under U) - something not immediately obvious from Parseval's relation! Neat, no? This of course is the reason why fast correlation works (as the angle between two vectors is the same in both domains, thanks to unitarity of the DFT).
> From a practitioner's standpoint, it allows one to make a sliding
power
> detecter by squaring each sample and boxcar filtering that sequence
> both operations have minimal cpu requirements independent of the
length
> of the window. Pretty nifty.
Yup. The whole of DSP is basically about being nifty :-).
> > -- Mark
Andor
"Andor" <an2or@mailcircuit.com> wrote in message
news:1115973864.786042.142780@g43g2000cwa.googlegroups.com...
> Bhaskar Thiagarajan wrote: > > > > In simpler words, since the DFT is unitary, the euclidian length of > a > > > vector is invariant under the DFT. > > > > Andor, > > Perhaps the words are shorter (or the sentence is) but by no means > are they > > 'simpler' :-) > > It took me a while to digest what you said and I'm still not very > sure if I > > truly understand it's implication. > > Allow me in this case to elaborate by giving the definitions: Let V be > some n-dimensional (wher n < infinity) complex vector space with an > inner product. Write the inner product for vectors x and y as (x,y), > meaning > > (x,y) := x^H y = sum_{k=1}^n x_k* y_k, > > where x^H is the adjoint of x (write x as a column vector and x^H as > the complex conjugate row vector). Let F: V->V be a linear map, and F^H > be its adjoint (complex conjugate transpose). By definition, if > > F^H F = 1 (where "1" denotes the identity map on V) > > then F is called unitary. The simple consequence of this definition is > that > > (F x, F y) = (F x)^H (F y) = x^H F^H F y = x^H y = (x, y). > > Now if you let F be the DFT, and X = F x, then Parseval's relation is a > simple consequence of the unitarity of F: > > (x, x) = (X, X). > > Note that for the DFT to be unitary, you need to scale the matrices F > and F^H by a factor 1/sqrt(n). This is usual in physics but not so in > ee, but I find it makes notation a lot more compact.
Given that I made a C in Linear Algebra when I was supposed to study it, this was primarily a translation of short phrases of difficult words to long phrases (of difficult words) :-)) Seriously though - I actually tried to understand this (despite my poor grasp of this space of math...well, who am I kidding...math in general). I should say, it actually made *some* sense to me. Enough to appreciate this alternate view of explaining Parseval's theorem - certainly 'nifty'!! I only wish I'd paid more attention in my linear algebra class instead of trying to peak at bras (forgive my play on words)... Cheers Bhaskar
> Regards, > Andor
Andor wrote:
> Mark Borgerding wrote: > > Andor wrote: > > >>>In simpler words, since the DFT is unitary, the euclidian length > of > > >>>vector is invariant under the DFT. > ... > > Ah, yes. Much simpler. *POP* *(struggles to extract tongue from > cheek)* > > Well, if you are familiar with the definitions, then my point was
that
> one can state Parseval's relation in simple words (see above). > > > Sorry Andor, I just couldn't resist. > > No problem. Sometimes, I get carried away by my affinity for linear > algebra ... :-)
I have to side with Andor here. DSP is the art of making use of linear algebra for solving practical problems. Lots of people find that to be a contradiciction in terms, but that's how I view the world.
> > I view Parseval's equality in terms of what it means to the > > practitioner, not the mathematical properties that make it so. > > > > I'm sure both viewpoints are needed at various times.
The mathemathical properties of unitary transforms are what make Parseval's theorem useful to the practitioner.
> There is another nice property that follows from Parseval. Let's say, > you have some linear transform U, and you have verified Parseval's > relation (ie.(x, x) = (U x, U x), for all x). Then this already > suffices to show that U is unitary: > > We need to show (U x, U y) = (x, y) for all vectors x, y. So let x
and
y
x
> (in any Hilbert space, this decomposition is unique), ie. y_1 = x > (x,y)/(x,x), and y_2 = y - y_1. Then you have > > (U x, U y) > = (U x, U (y_1 + y_2)) > = (U x, U y_1) > = (x, y)/(x, x) (U x, U x) > = (x, y) > > where the last equation follows because of Parseval's relation. So > there you have it, U is unitary. This implies again, for example,
that
> U maps sets of orthonormal vectors to orthonormal vectors (ie. the > angle between the vectors is also invariant under U) - something not > immediately obvious from Parseval's relation! Neat, no? This of
course
> is the reason why fast correlation works (as the angle between two > vectors is the same in both domains, thanks to unitarity of the DFT).
This is, incidentially, the types of arguments that form the basis (no pun intended) for subspace methods. Such DSP techniques are basically (eh...) a study of linear transforms.
> > From a practitioner's standpoint, it allows one to make a sliding > power > > detecter by squaring each sample and boxcar filtering that sequence > -- > > both operations have minimal cpu requirements independent of the > length > > of the window. Pretty nifty. > > Yup. The whole of DSP is basically about being nifty :-).
Agreed. Rune
"Rune Allnor" <allnor@tele.ntnu.no> wrote in message
news:1116009121.392786.87770@o13g2000cwo.googlegroups.com...
> Andor wrote:
> > This implies again, for example, > that > > U maps sets of orthonormal vectors to orthonormal vectors (ie. the > > angle between the vectors is also invariant under U) - something not > > immediately obvious from Parseval's relation! Neat, no? This of > course > > is the reason why fast correlation works (as the angle between two > > vectors is the same in both domains, thanks to unitarity of the DFT).
> This is, incidentially, the types of arguments that form the > basis (no pun intended) for subspace methods. Such DSP techniques > are basically (eh...) a study of linear transforms.
Since the two of you seem to be able to relate unitarity to correlation, maybe one of you can make the connection for us mere mortals. I mean, unitarity seems to relate to how a linear transformation transforms inner products, but the product you do after transformation in the case of correlation is an elemental product that yields another vector rather than an inner product that yields a scalar. And the unitarity of the DFT is not really necessary for fast correlation to work -- the methods that lead to minimum arithmetic operation counts don't directly use transformations that are strictly unitary. Also the successful proof should demonstrate the well-known fact that autocorrelation requires only about 3/4 the arithmetic operations that correlation with a known constant vector does whereas the opcounts for convolution and the convolution-square are identical. -- write(*,*) transfer((/17.392111325966148d0,6.5794487871554595D-85, & 6.0134700243160014d-154/),(/'x'/)); end
ya know, James, i think i agree with you.  this whole thing is getting very
thick.  i think i know what the DFT is, what Parseval's Theorem is, what
unitary transforms are, what an inner product is, what fast convolution is,
but as i was watching this thread i was beginning to wonder similarly what
all this was about.  at least what this is becoming.  (so fill me in, too,
guys.)
i have no advice for the OP, so i'll just continue to watch.
r b-j
in article 6M6dnbPah-8chhjfRVn-gQ@comcast.com, James Van Buskirk at
not_valid@comcast.net wrote on 05/13/2005 17:26:
> "Rune Allnor" <allnor@tele.ntnu.no> wrote in message > news:1116009121.392786.87770@o13g2000cwo.googlegroups.com... > >> Andor wrote: > >>> This implies again, for example, that >>> U maps sets of orthonormal vectors to orthonormal vectors (ie. the >>> angle between the vectors is also invariant under U) - something not >>> immediately obvious from Parseval's relation! Neat, no? This of course >>> is the reason why fast correlation works (as the angle between two >>> vectors is the same in both domains, thanks to unitarity of the DFT). > >> This is, incidentially, the types of arguments that form the >> basis (no pun intended) for subspace methods. Such DSP techniques >> are basically (eh...) a study of linear transforms. > > Since the two of you seem to be able to relate unitarity to > correlation, maybe one of you can make the connection for us > mere mortals. I mean, unitarity seems to relate to how a > linear transformation transforms inner products, but the product > you do after transformation in the case of correlation is an > elemental product that yields another vector rather than an > inner product that yields a scalar. And the unitarity of the > DFT is not really necessary for fast correlation to work -- > the methods that lead to minimum arithmetic operation counts > don't directly use transformations that are strictly unitary. > Also the successful proof should demonstrate the well-known > fact that autocorrelation requires only about 3/4 the arithmetic > operations that correlation with a known constant vector does > whereas the opcounts for convolution and the convolution-square > are identical.
-- r b-j rbj@audioimagination.com "Imagination is more important than knowledge."
(Circular) Convolution is just correlation with one of the sequences inverted in time. The result is a vector with each coordinate the inner product between two vectors, where one of them gets cyclically shifted. Fast correlation is basically the same as fast convolution (modulo some negative indexing and complex conjugate operation). Numerical Recipes Chpt. 13.2 can fill in the details: http://www.library.cornell.edu/nr/bookcpdf/c13-2.pdf
> And the unitarity of the DFT is not really necessary for fast > correlation to work --
Unitarity is necessary. Correlation is the inner product between two vectors. Unitarity implies that the inner product is invariant under the transform -- that is why you can compute the inner product between two vectors in both time and frequency domain and get the same result.
The FFT is the algorithm that speeds up fast correlation (I know you know that). It computes a unitary transform. Regards, Andor
> "Rune Allnor" <allnor@tele.ntnu.no> wrote in message > news:1116009121.392786.87770@o13g2000cwo.googlegroups.com... > > > Andor wrote: > > > > This implies again, for example, > > that > > > U maps sets of orthonormal vectors to orthonormal vectors (ie.
the
not
> > > immediately obvious from Parseval's relation! Neat, no? This of > > course > > > is the reason why fast correlation works (as the angle between
two
DFT).
> > > This is, incidentially, the types of arguments that form the > > basis (no pun intended) for subspace methods. Such DSP techniques > > are basically (eh...) a study of linear transforms. > > Since the two of you seem to be able to relate unitarity to > correlation, maybe one of you can make the connection for us > mere mortals. I mean, unitarity seems to relate to how a > linear transformation transforms inner products,
A "unitary tranform" is a "linear transform" that "preserves the norm". That might sound like gobbledigook at first, but let's define the terms and see if things might make some sense. First, a "linear transform" is a general matrix-vector product on the form Ax = b [1] where a is a matrix and x and b are column vectors. Now, there are two ways of viewing an expression like [1]. The first is to see it as some system of equations, the other is to view it as a geometrical operation on vectors. If x is a 2D vector [x1, x2]^T, it can be plotted in a 2D coordinate system. If A is of dimension 2x2, b will also be a 2x1 vector that can be plotted in 2D. Let's see an example: If x = [1 1]^T [2] A = | cos(t) -sin(t) | [3] | sin(t) cos(t) | then b = [cos(t)-sin(t) sin(t)+cos(t)]^T [4] and multiplication with A corresponds to rotating the vector x an angle t around origo in the anticlockwise direction. Det(A) = cos^(t)+sin^2(t) = 1 [5] and so |x| = |b|, and multiplication with A does not change the length of the vector. The matrix A "preserves the norm". Undoing the effect of A (multiplying with inv(A)) amounts to rotating an angle -t, and inv(A) = | cos(t) sin(t) | = A^T. [6] |-sin(t) cos(t) | A mathrix that preserves the norm and where inv(A) = conj(A^T) [7] is "unitary".
Correlation is a sequence of inner products. To see this, define a data matrix as X = | x(0) 0 0 ... 0 | [8] | x(1) x(0) 0 ... 0 | | x(2) x(1) x(0) | | | | x(N) .... x(0)| | 0 x(N) ... x(1)| | | | 0 0 x(N)| and the data vector x = [x(0) x(1) ... x(N) 0 ... 0]^T [9] The autocorrelation sequence becomes r = [r(0) r(1) ... r(N)]^T = conj(X^T)x. [10] So each coefficient in the correlation sequence r(k) corresponds to the inner product between column k in the matrix X and the vector x. Convolution can be defined in a similar way.
This is a different question. The arithemtic algorithm that yeilds the FFT has more to do with symmetries in the coefficients than the DFT being unitary. In fact, in lots of implementations one saves a number of arithmetic operations by skipping an 1/sqrt(N) normalization factor. This is the reason for quite a few "why doesn't Parseval's identity hold" questions here on comp.dsp and comp.soft-sys.matlab.
Again, this has nothing to do with correlations being sequences of inner products, but rather with properties of the vectors in question. Rune
news:1116059723.682422.139790@o13g2000cwo.googlegroups.com...
> > And the unitarity of the DFT is not really necessary for fast > > correlation to work --
> Unitarity is necessary. Correlation is the inner product between two > vectors. Unitarity implies that the inner product is invariant under > the transform -- that is why you can compute the inner product between > two vectors in both time and frequency domain and get the same result.
Well, in at least the lowest operation count fast correlation algorithms I know of, the linear transformation applied to the inputs isn't even square, much less unitary.
> > the methods that lead to minimum arithmetic operation counts > > don't directly use transformations that are strictly unitary.
> The FFT is the algorithm that speeds up fast correlation (I know you > know that). It computes a unitary transform.
Well, the FFT is the algorithm most responsible for reducing the operation count for large input vectors, but the sequence of operations as described in NR is not going to reduce the operation count to a minimum. Fast correlation is the same as fast convolution (except for autocorrelation, which is fundamentally different) and the algorithms I have right at the tips of my fingers compute convolution rather than correlation, so let me present an example of fast cyclic convolution on vectors of length 8. For this length the algorithm generated is the same as Nussbaumer, but hopefully you can see that the NR sequence isn't going to get the operation count this low: ! File: const8.i90 ! Generated by conv2b.f90 05/14/2005 08:58:04.123 subroutine const8(h,a) implicit real(wp) (x,y) real(wp), intent(in) :: h(0:7) real(wp), intent(out) :: a(0:9) real(wp), parameter :: d1 = 0.2500000000000000000000000000000000_wp real(wp), parameter :: d2 = 0.5000000000000000000000000000000000_wp real(wp), parameter :: d3 = 0.7071067811865475244008443621048491_wp xr1_0 = h(0)+h(4) xr1_1 = h(1)+h(5) xr1_2 = h(2)+h(6) xr1_3 = h(3)+h(7) a(0) = d1*(xr1_0+xr1_2) a(1) = d1*(xr1_1+xr1_3) a(2) = d1*(xr1_0-xr1_2) a(3) = d1*(xr1_1-xr1_3) xr1_4 = h(0)-h(4) xr1_5 = h(1)-h(5) xr1_6 = h(2)-h(6) xr1_7 = h(3)-h(7) xr2_4 = d2*xr1_4 xr2_5 = d2*xr1_5 xr2_6 = d2*xr1_6 xr2_7 = d2*xr1_7 a(4) = xr2_4 a(5) = xr2_5-xr2_4 a(6) = xr2_7+xr2_4 a(7) = xr2_6 a(8) = xr2_7-xr2_6 a(9) = xr2_5-xr2_6 end subroutine const8 ! File: eval8.i90 ! Generated by conv2b.f90 05/14/2005 08:58:04.139 subroutine eval8(h,a) ! 40 adds, 20 muls implicit real(wp) (x,y) real(wp), intent(inout) :: h(0:7) real(wp), intent(in) :: a(0:9) real(wp), parameter :: d1 = 0.7071067811865475244008443621048491_wp xr1_0 = h(0)+h(4) xr1_1 = h(1)+h(5) xr1_2 = h(2)+h(6) xr1_3 = h(3)+h(7) xr2_0 = xr1_0+xr1_2 xr2_1 = xr1_1+xr1_3 xr2_2 = xr1_0-xr1_2 xr2_3 = xr1_1-xr1_3 xr3_0 = a(0)*xr2_0+a(1)*xr2_1 xr3_1 = a(1)*xr2_0+a(0)*xr2_1 xr3_2 = a(2)*xr2_2-a(3)*xr2_3 xr3_3 = a(3)*xr2_2+a(2)*xr2_3 xr4_0 = xr3_0+xr3_2 xr4_1 = xr3_1+xr3_3 xr4_2 = xr3_0-xr3_2 xr4_3 = xr3_1-xr3_3 xr1_4 = h(0)-h(4) xr1_5 = h(1)-h(5) xr1_6 = h(2)-h(6) xr1_7 = h(3)-h(7) xr2_4 = xr1_4+xr1_5 xr2_5 = xr1_6+xr1_7 xr3_6 = a(4)*xr2_4-a(7)*xr2_5 xr3_7 = a(7)*xr2_4+a(4)*xr2_5 xr4_4 = xr3_6-a(6)*xr1_5-a(9)*xr1_7 xr4_5 = xr3_6+a(5)*xr1_4-a(8)*xr1_6 xr4_6 = xr3_7+a(9)*xr1_5-a(6)*xr1_7 xr4_7 = xr3_7+a(8)*xr1_4+a(5)*xr1_6 h(0) = xr4_0+xr4_4 h(1) = xr4_1+xr4_5 h(2) = xr4_2+xr4_6 h(3) = xr4_3+xr4_7 h(4) = xr4_0-xr4_4 h(5) = xr4_1-xr4_5 h(6) = xr4_2-xr4_6 h(7) = xr4_3-xr4_7 end subroutine eval8 ! File: eval8.i90 ! Generated by conv2b.f90 05/14/2005 08:58:04.139 module mykinds implicit none integer, parameter :: dp = selected_real_kind(15,300) end module mykinds module test use mykinds, only: wp => dp implicit none private wp contains include 'const8.i90' include 'eval8.i90' end module test program conv_test use mykinds use test implicit none integer, parameter :: k = 3 integer, parameter :: n = 2**k integer, parameter :: nta = n+(1+sign(1,n-4))/2*(n/2-2) real(dp) ta(0:nta-1) integer i integer j real(dp) h0(0:n-1) real(dp) h1(0:n-1) real(dp) error real(dp) max_error max_error = 0 do i = 0, n-1 h0 = 0 h0(i) = 1 call const8(h0,ta) error = 0 do j = 0, n-1 h0 = 0 h0(j) = 1 call eval8(h0,ta) h1 = 0 h1(modulo(i+j,n)) = 1 error = max(error,maxval(abs(h0-h1))) end do write(*,*) i,error max_error = max(error,max_error) end do write(*,*) write(*,*) 'max_error = ',max_error end program conv_test I was kind of surprised when I saw the generated code because my generator http://home.comcast.net/~kmbtib/conv2b.f90 was generating constants for an order-n DFT when it only needs the constants for an order-n/2 DFT. Well, if you pay no attention to the little man in that particular booth, hopefully you will be able to see some of the points I am trying to make in this thread. -- write(*,*) transfer((/17.392111325966148d0,6.5794487871554595D-85, & 6.0134700243160014d-154/),(/'x'/)); end
James Van Buskirk schrieb:
> "Andor" <an2or@mailcircuit.com> wrote in message > news:1116059723.682422.139790@o13g2000cwo.googlegroups.com... > > > James Van Buskirk wrote: > > > > And the unitarity of the DFT is not really necessary for fast > > > correlation to work -- > > > Unitarity is necessary. Correlation is the inner product between
two
under
between
result.
> > Well, in at least the lowest operation count fast correlation > algorithms I know of, the linear transformation applied to > the inputs isn't even square, much less unitary. > > > > the methods that lead to minimum arithmetic operation counts > > > don't directly use transformations that are strictly unitary. > > > The FFT is the algorithm that speeds up fast correlation (I know
you
> > know that). It computes a unitary transform. > > Well, the FFT is the algorithm most responsible for reducing > the operation count for large input vectors, but the sequence > of operations as described in NR is not going to reduce the > operation count to a minimum. Fast correlation is the same > as fast convolution (except for autocorrelation, which is > fundamentally different) and the algorithms I have right at > the tips of my fingers compute convolution rather than > correlation, so let me present an example of fast cyclic > convolution on vectors of length 8. For this length the > algorithm generated is the same as Nussbaumer, but hopefully > you can see that the NR sequence isn't going to get the > operation count this low:
James, if I am to believe Steven G. Johnson (and I have no reason no to), then you are responsible for the current minimum FLOP count FFT algorithm record, as described in http://www.fftw.org/newsplit.p=ADdf. Congratulations! I just wished you stop posting code and start talking a language I understand (=3D maths). I have to invest a large amount of time just to decipher you indices, never mind the rest of the code. Can't you describe the general idea which makes your convolution (or FFT) faster than everybody else's? Then we can discuss the (non-) unitarity of these transforms. Furthermore, while perhaps theoretically interesting, certain reductions in FLOP have absolutley no impact on instruction counts on specific hardwares (ie DSPs). An easy example is the symmetric FIR. Theoretically, a N tap symmetric FIR can be computed with N/2 multiplies and N adds, making a total of 3/2 N FLOP (let's forget about fast convolution for a moment). However, DSPs have a built in MAC instruction that executes one multiply, one add and the necessary memory transfers in one instruction, thus any N tap FIR can be computed in N instructions. Therefore, this theoretical improvement gains you exactly nothing on most DSP hardwares (in fact, a naive implementation actually takes more instruction cycles). Now I don't know if you or Steven have implemented your FFT codes on machines where you explicitly take advantage of parallel computation units. It would be really interesting to see the improvement in number of execution cycles (which can be quite independent on the FLOPs count of an algorithm) with respect to the standard DIT FFT (for example).
> ! File: const8.i90
What is that, Fortran? Regards, Andor
Andor wrote:
> Unitarity is necessary. Correlation is the inner product between two > vectors. Unitarity implies that the inner product is invariant under > the transform -- that is why you can compute the inner product > between two vectors in both time and frequency domain and get > the same result.
Andor, I think you've made a fundamental mistake here (besides the fact that correlation is more than just a single inner product). In order for a fast convolution (or correlation) algorithm to work, you just have to get the correct answer in time domain. You do *not* have to get the same answer in frequency domain (or whatever "domain" your intermediate results correspond to, if anything), and thus unitarity (or similar) is unnecessary. Trivial counter-example: the unitary FFT would have a 1/sqrt(N) scale factor, but this is actually the *wrong* normalization for a fast convolution/correlation algorithm...you will end up with an extra factor of 1/sqrt(N) at the end. You need to use a non-unitary normalization where you have 1/N only once (typically, for the inverse FFT, as in Matlab). (There are a very large number of fast convolution algorithms out there...I haven't checked this explicitly, but I suspect that many of them, not just James', correspond to non-unitary transforms.) Cordially, Steven G. Johnson
