"Andor" <an2or@mailcircuit.com> wrote in message news:1116087851.369053.99840@g43g2000cwa.googlegroups.com...> I just wished you stop posting code and start talking a language I > understand (= maths). I have to invest a large amount of time just to > decipher you indices, never mind the rest of the code. Can't you > describe the general idea which makes your convolution (or FFT) faster > than everybody else's? Then we can discuss the (non-) unitarity of > these transforms.I'm so sick of trying to explain this. I even sat down with my best friend and wrote a paper about it, but the writing of it was such a horrible task that I don't relly have any friends any more. You will just have to take my word for it, or look it up in Nussbaumer as I suggested. It doesn't look like the paper is going to get published, so maybe I'll put it on my website if my former friend can ever manage to send it to me in one piece, that is if he will ever return my calls... -- write(*,*) transfer((/17.392111325966148d0,6.5794487871554595D-85, & 6.0134700243160014d-154/),(/'x'/)); end
FFT & averaging
Started by ●May 10, 2005
Reply by ●May 15, 20052005-05-15
Andor wrote:> So > there you have it, U is unitary. This implies again, for example, that > U maps sets of orthonormal vectors to orthonormal vectors (ie. the > angle between the vectors is also invariant under U)Thanks! I've been trying, from context, to figure out what "unitary" means to no avail for some time. :-) Bob -- "Things should be described as simply as possible, but no simpler." A. Einstein
Reply by ●May 16, 20052005-05-16
Steven wrote:> Andor wrote: > > Unitarity is necessary. Correlation is the inner product betweentwo> > vectors. Unitarity implies that the inner product is invariantunder> > the transform -- that is why you can compute the inner product > > between two vectors in both time and frequency domain and get > > the same result. > > Andor, I think you've made a fundamental mistake here (besides thefact> that correlation is more than just a single inner product). In order > for a fast convolution (or correlation) algorithm to work, you just > have to get the correct answer in time domain. You do *not* have to > get the same answer in frequency domain (or whatever "domain" your > intermediate results correspond to, if anything), and thus unitarity > (or similar) is unnecessary.Ok Steven, let's review some definitions: If V is a N-dimensional complex vector space, then the following defines an inner product: For x=(x_0, x_1, ..., x_{N-1}) and y=(y_0,y_1,...,y_{N-1}) in V, define (x,y) := x^H y = sum_{k=0}^{N-1} x_k* y_k (x^H is the adjoint of x, a row vector with conjugate complex coordinates). For further notation, I will be using S to denote the cyclic left-shift operator, ie. S x = (x_1, x_2, ... , x_{N-1}, x_0), and d_S to denote the diagonalization of S, ie. d_S = diag(1, w, w^2, ..., w^{N-1} ), where w := e^{i 2 pi /N}. F denotes the DFT matrix (scaled such that F^H F = 1). Now we can derive the fundamental equations that drives fast convolution and fast correlation. The correlation rxy between x and y is another element of V defined by rxy_k = (S^k x,y), k=0,1,...,N-1. The k-th coordinate is the inner product between x shifted k times to the left, and y. Write X = F x, Y = F y and define v = F^H (X* Y) as the inverse Fourier transform of the point-wise product of the two vectors X* (conjugate of X) and Y. Now use the unitarity of the DFT: (S^k x, y) = (F S^k x, F y) (1) We know that F S^k = d_S^k F (the columns of F are the eigenvectors of S), therefore we can write (F S^k x, F y) = (d_S^k X, Y) (2) If you look at the right hand side of (2), you'll notice that this is, by definition, v_k. Add (1) and (2) together to get rxy_k = v_k. (3) (3) is the equation that is the basis for fast correlation (and similarly, fast convolution). Of course, you can define the DFT with another scale factor, and include that in the above equations. However, any derivation of equation (3) uses the unitarity of F (as I have defined it), or something equivalent. Without unitarity, no fast correlation.> Trivial counter-example: the unitary FFT would have a 1/sqrt(N) scale > factor, but this is actually the *wrong* normalization for a fast > convolution/correlation algorithm...Whatever scale factor you choose doesn't change the fact that F is unitary, and that this is a necessary requirement to derive equation (3).> (There are a very large number of fast convolution algorithms out > there...I haven't checked this explicitly, but I suspect that many of > them, not just James', correspond to non-unitary transforms.)Again, that is totally irrelevant. One can scale the convolution or correlation arbitrarily.> > Cordially, > Steven G. JohnsonRegards, Andor
1) Your derivation is incorrect because (d_S^k X, Y) is not the same thing as v_k -- it is v_k times sqrt(N). Thus, as I said, you get an extra factor of sqrt(N) if you use the unitary definition of the DFT for convolution/correlation. 2) Showing that the DFT's properties give the convolution theorem is obvious (or at least, well known) and besides the point. The converse does not follow - it does not prove that any O(N log N) convolution algorithm requires a unitary transform. 3) A unitary matrix multiplied by a scale factor is not unitary. Please notice that I was not claiming that this is necessarily the *only* counter-example, just the simplest one. Steven
Reply by ●May 17, 20052005-05-17
stev...@alum.mit.edu wrote:> 1) Your derivation is incorrect because (d_S^k X, Y) is not the same > thing as v_k -- it is v_k times sqrt(N).You are right. Furthermore, for my derivation to hold, one has to change the defintion of the inner product by swapping the role of the two vectors. It was late yesterday evening.> Thus, as I said, you get an > extra factor of sqrt(N) if you use the unitary definition of the DFT > for convolution/correlation.As I said, the final scaling is irrelevant.> > 2) Showing that the DFT's properties give the convolution theorem is > obvious (or at least, well known) and besides the point. Theconverse> does not follow - it does not prove that any O(N log N) convolution > algorithm requires a unitary transform.Show me a O(N log N) correlation / convolution algorithm that does not make use of my equation (3), or something equivalent, then I'll retract my claim. Until then, unitarity of the matrix F is essential to show that the fast algorithms work.> > 3) A unitary matrix multiplied by a scale factor is not unitary. > Please notice that I was not claiming that this is necessarily the > *only* counter-example, just the simplest one.Again, you can scale the results of convolution and correlation, as well as the matrix F, all you want. It doesn't affect my claim.> > StevenWhat happened to the cordially - you're not getting angry at me, are you :-)? Regards, Andor
Andor, Let me step back a bit and ask you to clarify what, precisely you are claiming. If you were claiming that every O(N log N) convolution algorithm is *exactly* a transform that computes a unitary matrix, pointwise multiplication, and the inverse transform, then this claim is disproved by the ability (indeed, the requirement) to scale the transform. If you allow this to be modified by any multiplications by a diagonal matrix (e.g. a scale factor), then I believe I can still give a trivial counter-example. If you say merely that it has to be "related" or "equivalent" to a unitary transformation, then it's impossible to disprove because you haven't specified what "related" means. Everything in mathematics is related in *some* way, and everything that computes a convolution is equivalent in the sense that it is computing the same end result. Steven PS. It's kind of odd to make a claim without proof or reference and then demand that others disprove it. PPS. I tend to use a formal signature only on the first message in a thread or in response to someone I haven't corresponded with previously; don't think anything of the change.
Reply by ●May 18, 20052005-05-18
Steven wrote: ...> PS. It's kind of odd to make a claim without proof or reference and > then demand that others disprove it.Funny that you should mention that. After all, the only one who did any proving after being challenged to his statement was I. Regards, Andor
"Andor" <an2or@mailcircuit.com> wrote in message news:1116405891.146469.325640@o13g2000cwo.googlegroups.com...> Funny that you should mention that. After all, the only one who did any > proving after being challenged to his statement was I.Being the original challenger and having offered proof and reference to proofs that you have refused to read, I demand that you retract the above statement. -- write(*,*) transfer((/17.392111325966148d0,6.5794487871554595D-85, & 6.0134700243160014d-154/),(/'x'/)); end
Reply by ●August 3, 20052005-08-03
Um, except the thing that you proved (that the properties of the DFT give the convolution theorem) wasn't what you claimed (the converse, that any O(N log N) convolution algorithm employs a unitary transformation, for some unspecified definition of "employs").
If you look at what started the argument, I claimed that " Unitarity is necessary [for fast correlation to work]. Correlation is the inner product between two vectors. Unitarity implies that the inner product is invariant under the transform -- that is why you can compute the inner product between two vectors in both time and frequency domain and get the same result " In the same post (in a part that you snipped), I described that the correlation of two vectors is another vector that results from taking the inner product of the two vectors, where one gets cyclically shifted for each new coordinate. I went on to show that to derive the convolution theorem one requires the unitarity of F (the DFT matrix), and how the convolution theorem is actually just about taking inner products in both domains und using the unitarity to see that they are equal. This is what I mean when I say that unitarity (of F) is necessary for fast convolution / correlation to work. Clearly, you can set G = 1/sqrt(N) F, and write down the same proof, using the appropriate factors everywhere, and so derive the convolution theorem with G and say that unitarity is not necessary for fast convolution / correlation. Now instead of needing F unitary, you need the fact that G scales the norm by a constant factor. I don't know any short name for such a matrix, it seems simpler to just use F and using its unitarity to describe the maths behind fast convolution. When I say that every O(N log N) algorithm is based on the unitarity of F, I meant that the unitarity of F is necessary to derive the convolution theorem which is what fast convolution / correlation algorithms are based on. As above, set G = 1/sqrt(N) F, call G the Fourier Transform, and go ahead and say that fast convolution / correlation does not require unitarity, just norm-invariance. I don't care about that, as any norm-invariant matrix G can be made unitary (by multiplication with a factor). This is why I say that multplication with a factor doesn't change the fact that unitarity is needed. I don't think I can express my views any clearer than this. Regards, Andor
