Hi guys, I'm newbie in those groups. I tried to make a CW demodulator (Telegraphy). I would like to make this because it's the simplest signal. I have somes algorithms about USB/LSB/AM/FM demodulators, with theis I/Q signals, but what do I have to use to try it? or are there any simple solution?. In tha analog world, it's only IF-LO= CW Audio, but in the digital world, is is simpler than analog?. Can anybody help me? Maybe it's a simple firmware, so I think I'll do it on a dsPIC30F2010(4K/20MIPS) to start experiments. Thanks This message was sent using the Comp.DSP web interface on www.DSPRelated.com
Newbie: CW demodulation
Started by ●May 10, 2005
Reply by ●May 10, 20052005-05-10
A USB or LSB demodulator should work for CW as well for starters. After that we can work on reducing the bandwidth. Mark
EA7FNJ wrote:> Hi guys, I'm newbie in those groups. I tried to make a CW demodulator > (Telegraphy). I would like to make this because it's the simplest signal. > I have somes algorithms about USB/LSB/AM/FM demodulators, with theis I/Q > signals, but what do I have to use to try it? or are there any simple > solution?. In tha analog world, it's only IF-LO= CW Audio, but in the > digital world, is is simpler than analog?. > > Can anybody help me? Maybe it's a simple firmware, so I think I'll do it > on a dsPIC30F2010(4K/20MIPS) to start experiments. > > Thanks >Are you trying to emulate a CW radio receiver? If so, then Mark's suggestion is exactly correct -- a CW radio receiver intended to be used by a human is just an SSB receiver with a narrow filter. If, on the other hand, you are trying to get CW into a computer to be demodulated into text then the problem can range from the simple to the complex, with a wide range of performance points. Are you starting from RF, intending to sample directly into the DSP and get audio or data out? If not, what conversion scheme do you want to use to get from RF down to something slow enough for the DSP? With the right front-end processing the dsPIC should be a fine processor, but with the wrong front-end processing you won't get there from here. So what are you trying to do? ------------------------------------------- Tim Wescott Wescott Design Services http://www.wescottdesign.com
> >Are you trying to emulate a CW radio receiver? If so, then Mark's >suggestion is exactly correct -- a CW radio receiver intended to be used>by a human is just an SSB receiver with a narrow filter. > >If, on the other hand, you are trying to get CW into a computer to be >demodulated into text then the problem can range from the simple to the >complex, with a wide range of performance points. > >Are you starting from RF, intending to sample directly into the DSP and >get audio or data out? If not, what conversion scheme do you want to >use to get from RF down to something slow enough for the DSP? > >With the right front-end processing the dsPIC should be a fine >processor, but with the wrong front-end processing you won't get there >from here. > >So what are you trying to do? > >-------------------------------------------The main idea is to make a IF-DSP, put a 10KHz IF to a DSP system and demodulate the CW. So, first sampling tha IF, filter and after... does it demodulate as a LSB or USB?. The CW is easier than others kind of modulations, it's only open and close a unmodulate carrier to make dot or dash. This message was sent using the Comp.DSP web interface on www.DSPRelated.com
EA7FNJ wrote:>>Are you trying to emulate a CW radio receiver? If so, then Mark's >>suggestion is exactly correct -- a CW radio receiver intended to be used > > >>by a human is just an SSB receiver with a narrow filter. >> >>If, on the other hand, you are trying to get CW into a computer to be >>demodulated into text then the problem can range from the simple to the >>complex, with a wide range of performance points. >> >>Are you starting from RF, intending to sample directly into the DSP and >>get audio or data out? If not, what conversion scheme do you want to >>use to get from RF down to something slow enough for the DSP? >> >>With the right front-end processing the dsPIC should be a fine >>processor, but with the wrong front-end processing you won't get there > >>from here. > >>So what are you trying to do? >> >>------------------------------------------- > > > The main idea is to make a IF-DSP, put a 10KHz IF to a DSP system and > demodulate the CW. So, first sampling tha IF, filter and after... does it > demodulate as a LSB or USB?. The CW is easier than others kind of > modulations, it's only open and close a unmodulate carrier to make dot or > dash. >OK, you still haven't clarified. You've fallen in with a bunch of folks who have had salespeople demand that they implement things that you have never even heard of. Do you want a receiver that does CW reception just like my Kenwood TS520, i.e. when the other guy transmits you hear "beep", the frequency of the beep depends on tuning and you hear all the static, over-the-horizon radar, and all that fun stuff? Or do you want a _demodulator_ that you hook to an antenna and you see text start silently scrolling on your computer screen? If it's the former then you want to implement a single-sideband demodulator. Either LSB or USB will work, the only difference is the direction the CW note will change with changes in relative frequency between you and the transmitter. Frankly it's probably marginally easier to implement a SSB receiver, if only because the filters are wider -- and a SSB receiver works pretty good for CW. In either case I think you'll find that a 10kHz IF is pretty low -- if you can get down to 10kHz cleanly why not just go all the way down to audio? ------------------------------------------- Tim Wescott Wescott Design Services http://www.wescottdesign.com
> >OK, you still haven't clarified. You've fallen in with a bunch of folks>who have had salespeople demand that they implement things that you have>never even heard of. > >Do you want a receiver that does CW reception just like my Kenwood >TS520, i.e. when the other guy transmits you hear "beep", the frequency >of the beep depends on tuning and you hear all the static, >over-the-horizon radar, and all that fun stuff? Or do you want a >_demodulator_ that you hook to an antenna and you see text start >silently scrolling on your computer screen? > >If it's the former then you want to implement a single-sideband >demodulator. Either LSB or USB will work, the only difference is the >direction the CW note will change with changes in relative frequency >between you and the transmitter. Frankly it's probably marginally >easier to implement a SSB receiver, if only because the filters are >wider -- and a SSB receiver works pretty good for CW. > >In either case I think you'll find that a 10kHz IF is pretty low -- if >you can get down to 10kHz cleanly why not just go all the way down toaudio?>Weel, I only need to heard the dot or dash, my ear can decode the MORSE code. I put a IF about 10KHz but maybe I use 100KHz, and not on AF because I can to demodulate with a good filter or with a noise reduction on IF better than on AF. In the IF I can clear the desire signal better than on the AF. There are some transceiver that use IF-DSP: Kenwood TS870, TS2000 and the new ICOM IC7000 (not yet on sale). Some receivers, like YAESU VR5000, have a IF output behind them. It's a good idea to practise hte IF-DSP with it. Also it can use to demodulate APT signals from weather satellites like NOAA that it needs a badwith about 50KHz. But this is a future project, first, demodulate CW and step by step to others kind of modulation. This message was sent using the Comp.DSP web interface on www.DSPRelated.com
Reply by ●May 11, 20052005-05-11
>> >>OK, you still haven't clarified. You've fallen in with a bunch offolks> >>who have had salespeople demand that they implement things that youhave> >>never even heard of. >> >>Do you want a receiver that does CW reception just like my Kenwood >>TS520, i.e. when the other guy transmits you hear "beep", the frequency>>of the beep depends on tuning and you hear all the static, >>over-the-horizon radar, and all that fun stuff? Or do you want a >>_demodulator_ that you hook to an antenna and you see text start >>silently scrolling on your computer screen? >> >>If it's the former then you want to implement a single-sideband >>demodulator. Either LSB or USB will work, the only difference is the >>direction the CW note will change with changes in relative frequency >>between you and the transmitter. Frankly it's probably marginally >>easier to implement a SSB receiver, if only because the filters are >>wider -- and a SSB receiver works pretty good for CW. >> >>In either case I think you'll find that a 10kHz IF is pretty low -- if >>you can get down to 10kHz cleanly why not just go all the way down to >audio? >> > >Weel, I only need to heard the dot or dash, my ear can decode the MORSE >code. I put a IF about 10KHz but maybe I use 100KHz, and not on AFbecause>I can to demodulate with a good filter or with a noise reduction on IF >better than on AF. In the IF I can clear the desire signal better thanon>the AF. There are some transceiver that use IF-DSP: Kenwood TS870,TS2000>and the new ICOM IC7000 (not yet on sale). Some receivers, like YAESU >VR5000, have a IF output behind them. It's a good idea to practise hte >IF-DSP with it. Also it can use to demodulate APT signals from weather >satellites like NOAA that it needs a badwith about 50KHz. But this is a >future project, first, demodulate CW and step by step to others kind of >modulation. > > > >This message was sent using the Comp.DSP web interface on >www.DSPRelated.com >And, if I use FFT to get the carrier? in this case, I don't have to use the SSB demodulator, do I? but, I do the FFT to th IF directly or to the IQ signals? This message was sent using the Comp.DSP web interface on www.DSPRelated.com
An FFT can be used to create a spectrum display that can display the various signals in the passband on a screen. What you need is a BFO to change the on/off IF carrier into an on/off audio tone. Think about a BFO, it's an oscillator that beats against the carrier to create an audio tone. That is (part of) what a SSB demodulator does. Mark
Reply by ●May 12, 20052005-05-12
I guess the very simplest starting point would be to just chop (switch on and off) the IF with a frequency which is away by 1 kHz (or what you want to hear as audio). Low-pass the result and put to the speaker. Mark wrote:> An FFT can be used to create a spectrum display that can display the > various signals in the passband on a screen. What you need is a BFO > to change the on/off IF carrier into an on/off audio tone. Think > about a BFO, it's an oscillator that beats against the carrier to > create an audio tone. That is (part of) what a SSB demodulator does. > > > Mark >-- Please change no_spam to a.lodwig when replying via email!
