I am completely new to the field of DSP -- so this question may be elementry I was wondering about the worst case performance of a butterworth bandpass filter. I know that the FFT algorithm has a worst case performance of O(N log N). Does a second order bandpass filter have a similar computational cost? How does this cost vary as a function of the order of the filter? Any insight would be grately appreciated. Thanks, Arctan
Run time estimate of a butterworth filter
Started by ●May 10, 2005
Reply by ●May 10, 20052005-05-10
<arctan.spam.mail@gmail.com> wrote in message news:1115747323.151598.31410@o13g2000cwo.googlegroups.com...> I am completely new to the field of DSP -- so this question may be > elementry > > I was wondering about the worst case performance of a butterworth > bandpass filter. I know that the FFT algorithm has a worst case > performance of O(N log N). Does a second order bandpass filter have a > similar computational cost? How does this cost vary as a function of > the order of the filter?With an FFT, you have a block of data of N samples. So assuming you want to run a Butterworth bandpass filter on the same block of N samples, the cost would be O(N). If the filter is higher order, it is still an O(N) algorithm, though the actual cost is increased linearly (i.e. the constant multiplier is higher for higher orders). Now if you assume that N is the order of the filter rather than the length of the block of samples to filter, then when you filter a fixed block, the filter cost is O(N) again, i.e. cost increases linearly with increasing filter order.
arctan.spam.mail@gmail.com wrote:> I am completely new to the field of DSP -- so this question may be > elementry > > I was wondering about the worst case performance of a butterworth > bandpass filter. I know that the FFT algorithm has a worst case > performance of O(N log N). Does a second order bandpass filter have a > similar computational cost? How does this cost vary as a function of > the order of the filter? > > Any insight would be grately appreciated. > > Thanks, > > Arctan >A second-order filter will require, at most, 5 multiplies, a first-order 3. For an N-order filter you'll want to break it down into as many first-order filters as you can, with only the resonant pole-pairs being second order (an N-order butterworth filter has zero or one first-order sections, and floor(N/2) 2nd-order sections). ------------------------------------------- Tim Wescott Wescott Design Services http://www.wescottdesign.com
Reply by ●May 11, 20052005-05-11
Arctan wrote (by the way, did you know that Lem names his humanoid robots in "The Invincible" Arctan?):>I was wondering about the worst case performance of a butterworth >bandpass filter. I know that the FFT algorithm has a worst case >performance of O(N log N). Does a second order bandpass filter have a >similar computational cost? How does this cost vary as a function of >the order of the filter? > >Any insight would be grately appreciated.You're not comparing apples to apples. Fast convolution (FFT) filtering uses O( (N+M) (log (N+M) + 1) ) time to run M samples through an FIR of order N, as compared to time domain convolution which uses O( N M ) for the same process. If you want to run M samples through a IIR butterworth filter of order N, then this also takes O( N M ) time. However, depending on the filter requirement, the N for a FIR and the N for an IIR implementation will vary strongly. Also, depending on your programming capabilities and the hardware platform, the constants that we have ignored so far can make a big difference. Furthermore, the computation time of the fast convolution filter algorithm can be tuned in a streaming application (by selecting M appropriatly) such that the constants become small (this again depends on the hardware available, cache, memory, etc.). And lastly, there is no "worst case" for computing filters. It's a deterministic process. Regards, Andor
