Hi, I've a FFT problem. This is the situation: 1.I'm working with a DSP56824 (Motorola). 2.I need to do a FFT (maybe 512 or 1024 points). 3.I'm working with a C compiler (Codewarrior, but I DON'T HAVE SDK). 4.I was trying to do a FFT with standart FFT C library. Here I have problems, because, the algorithm calls to sin or cos function, but the compiler doesn't support it, I think thta I need to work with data tables. The question is: Someone has a FFT library or algorithm, that doesn't uses sin or cos (it would have a data table)? Or if someone knows where I can download SKD for motorola dsp56824 FREE? Or if you have another solution or another probed algorithm, PLEASE send me it. Thank you. Diego. P.S. Excuse my english. Thank you again.
I need a FFT algorithm that doesn't use SIN, COS, EXP function.
Started by ●May 11, 2005
Reply by ●May 11, 20052005-05-11
For FFT usually people do not use SIN and COS function in practice. They use simple table look-up. First you create a table with either half cycle or 1/4 of cycle, then you look up the table with an index to an array. You can find the algorithm from many DSP tutorials talking about this implementation.
dfalvarado@utpl.edu.ec wrote:> Hi, > > I've a FFT problem. This is the situation: > 1.I'm working with a DSP56824 (Motorola). > 2.I need to do a FFT (maybe 512 or 1024 points). > 3.I'm working with a C compiler (Codewarrior, but I DON'T HAVE SDK). > 4.I was trying to do a FFT with standart FFT C library. Here I have > problems, because, the algorithm calls to sin or cos function, but the > compiler doesn't support it, I think thta I need to work with data > tables. The question is: > > Someone has a FFT library or algorithm, that doesn't uses sin or cos > (it would have a data table)? > > Or if someone knows where I can download SKD for motorola dsp56824 > FREE? > > Or if you have another solution or another probed algorithm, PLEASE > send me it. > > Thank you. > > Diego. > > P.S. Excuse my english. Thank you again. >Are you using the compiler right? I'm pretty sure sin/cos/exp are defined in the standard C math library, but you may have to explicity link to it via a build parameter (e.g. -lm) If that is still no help, you can avoid the math functions by making a hard coded fft structure using kissfft. Precompute what the structure values would be, and then compile them into a header file. http://www.sourceforge.net/projects/kiss_fft -- Mark
Mark Borgerding wrote:> http://www.sourceforge.net/projects/kiss_fftThat should be http://www.sourceforge.net/projects/kissfft
Reply by ●May 12, 20052005-05-12
<dfalvarado@utpl.edu.ec> wrote in message news:1115853350.319429.148020@o13g2000cwo.googlegroups.com...> Hi, > > I've a FFT problem. This is the situation: > 1.I'm working with a DSP56824 (Motorola). > 2.I need to do a FFT (maybe 512 or 1024 points). > 3.I'm working with a C compiler (Codewarrior, but I DON'T HAVE SDK). > 4.I was trying to do a FFT with standart FFT C library. Here I have > problems, because, the algorithm calls to sin or cos function, but the > compiler doesn't support it, I think thta I need to work with data > tables. The question is: > > Someone has a FFT library or algorithm, that doesn't uses sin or cos > (it would have a data table)?I'm fairly sure that Motorola has a canned FFT routine written in assembly for you in one of it's libraries. You can call it directly from C or write a wrapper to be more C friendly and call it.> Or if someone knows where I can download SKD for motorola dsp56824 > FREE? > > Or if you have another solution or another probed algorithm, PLEASE > send me it. > > Thank you. > > Diego. > > P.S. Excuse my english. Thank you again. >
Reply by ●May 13, 20052005-05-13
dfalvarado@utpl.edu.ec wrote:> I've a FFT problem. This is the situation: > 1.I'm working with a DSP56824 (Motorola). > 2.I need to do a FFT (maybe 512 or 1024 points). > 3.I'm working with a C compiler (Codewarrior, but I DON'T HAVE SDK). > 4.I was trying to do a FFT with standart FFT C library. Here I have > problems, because, the algorithm calls to sin or cos function, but the > compiler doesn't support it, I think thta I need to work with data > tables. The question is:> Someone has a FFT library or algorithm, that doesn't uses sin or cos > (it would have a data table)?I believe that most FFT routines derive them through the half angle formula, which uses sqrt() and some simple arithmetic. Otherwise, you can supply a table. -- glen
On Fri, 13 May 2005 13:15:50 -0700, glen herrmannsfeldt <gah@ugcs.caltech.edu> wrote:> dfalvarado@utpl.edu.ec wrote: > >> I've a FFT problem. This is the situation: >> 1.I'm working with a DSP56824 (Motorola). >> 2.I need to do a FFT (maybe 512 or 1024 points). >> 3.I'm working with a C compiler (Codewarrior, but I DON'T HAVE SDK). >> 4.I was trying to do a FFT with standart FFT C library. Here I have >> problems, because, the algorithm calls to sin or cos function, but the >> compiler doesn't support it, I think thta I need to work with data >> tables. The question is: > >> Someone has a FFT library or algorithm, that doesn't uses sin or cos >> (it would have a data table)? > > I believe that most FFT routines derive them through the half angle > formula, which uses sqrt() and some simple arithmetic. Otherwise, > you can supply a table. > > -- glen >Motorola probably publishes such a table. TI publishes one for every DSP they make (two for the 'c6x generation with selectable endianism)
Reply by ●May 16, 20052005-05-16
> Or if you have another solution or another probed algorithm, PLEASE > send me it. > Diego.Here is another one that is even simpler than kissfft. Not necessarily the fastest fft in town, but it does the job and doesn't need any sine or cosine tables other than the constants that are inside the program. ------------------------------------------------------------------------------ /* dft.c Paul Mennen paul@mennen.org fftc(*blk,sz) Complex-Complex DFT sz = # of complex inputs/outputs iftc(*blk,sz) Complex-Complex IFT sz = # of complex inputs/outputs fftr(*blk,sz) Real-Complex DFT sz = # of real inputs iftr(*blk,sz) Complex-Real IFT sz = # of real outputs */ #include "stdio.h" #include "math.h" struct blk {float r; float i;}; #define RMS 1.414213562 /* adjust FFT results to read rms */ float tcos[] = {-1.0,0.0,0.7071068, /* cos(pi), cos(pi/2), cos(pi/4) */ 0.9238795,0.9807853,0.9951847, /* cos(pi/8), ... cos(pi/32) */ 0.9987955,0.9996988,0.9999247, /* cos(pi/64), ... cos(pi/256) */ 0.9999812,0.9999952938,0.9999988234, /* cos(pi/512), ... cos(pi/2048) */ 0.9999997055,0.9999999264 }; /* cos(pi/4096), cos(pi/8192) */ float tsin[] = {0.0,1.0,0.7071068, /* sin(pi), sin(pi/2), sin(pi/4) */ 0.3826834,0.1950903,0.0980171, /* sin(pi/8), ... sin(pi/32) */ 4.9067674e-2,2.4541228e-2,1.2271538e-2, /* sin(pi/64), ... sin(pi/256) */ 6.1358846e-3,3.067956691e-3,1.533980094e-3, /* sin(pi/512), ... sin(pi/2048) */ 7.669902711e-4, 3.834950931e-4 }; /* sin(pi/4096), sin(pi/8192) */ void fft(struct blk *x, int sz, int dir) /* In-place complex to complex transform. From Oppenheim & Schafer, pg 332 */ /* dir=-1/1 DFT/IFT, sz = Number of complex elements, must be a power of 2 */ { float Wr,Wi,Ur,Ui,Tr,Ti,Vr,Vi; int k,mm,le,le1,j,i,ii,nv2,m; m=0; le=j=sz; while (j >>= 1) m++; /* m = number of folds = log2(sz) */ for (mm=1; mm<=m; mm++) /* do m folds */ { le1 = le >> 1; /* le1 = le/2 */ Ur = 1.0; Ui = 0.0; /* initial phasor */ Wr = tcos[m-mm]; /* Wr=cos(PI/le1); (phasor increment) */ Wi = dir*tsin[m-mm]; /* Wi=dir*sin(PI/le1); (phasor increment) */ for (j=0; j<le1; j++) /* do sz/2 butterflys in le/2 groups */ { i = j; /* i points to one butterfly leg */ while (i < sz) /* do sz/le butterflys */ { ii = i + le1; /* ii points to the other butterfly leg */ Tr = x[i].r + x[ii].r; Ti = x[i].i + x[ii].i; Vr = x[i].r - x[ii].r; Vi = x[i].i - x[ii].i; if (mm == m) { x[ii].r = Vr; x[ii].i = Vi; } /* last fold */ else { x[ii].r = Vr*Ur - Vi*Ui; x[ii].i = Vr*Ui + Vi*Ur; } x[i].r = Tr; x[i].i = Ti; i += le; } Tr = Ur; Ur = Ur*Wr - Ui*Wi; Ui = Ui*Wr + Tr*Wi; /* update phasor */ } /* end for (j=0; j<le1; j++) */ le = le1; } /* end for (mm=1; mm<=m; mm++) */ /* bit reversal */ m = sz >> 1; j = 0; for (i=0; i<sz-1; i++) { if (i < j) { Tr = x[j].r; Ti = x[j].i; /* swap i & j */ x[j].r = x[i].r; x[j].i = x[i].i; x[i].r = Tr; x[i].i = Ti; } k = m; while (k <= j) { j -= k; k >>= 1; } j += k; } } void hfold(struct blk *x, int n, int dir) /* dir=-1/1 for DFT/IFT */ { float Wr,Wi,Ur,Ui,ang,Zr,Zi,Xr,Xi,Yr,Yi; int k,n2,nk; k = 0; n2 = n; while (n2 >>= 1) k++; /* k = number of folds */ /* Initial phasor (Ur,Ui) Phasor increment (Wr,Wi) */ /* DFT: -cos(PI/n) - i*sin(PI/n) cos(PI/n) + i*sin(PI/n) */ /* IFT: cos(PI/n) - i*sin(PI/n) cos(PI/n) - i*sin(PI/n) */ Ur = dir * (Wr = tcos[k]); Wi = dir * (Ui = -tsin[k]); n2 = n >> 1; for (k=1; k<=n2; k++) { Zr = x[k].r + x[nk=n-k].r; Zi = x[k].i - x[nk].i; Xr = x[k].r - x[nk].r; Xi = x[k].i + x[nk].i; Yr = Ui*Xr - Ur*Xi; Yi = Ui*Xi + Ur*Xr; x[k].r = Zr + Yr; x[k].i = Zi + Yi; x[nk].r = Zr - Yr; x[nk].i = Yi - Zi; Zr = Ur; Ur = Ur*Wr - Ui*Wi; Ui = Ui*Wr + Zr*Wi; /* update phasor */ } } /* fftc(*blk,sz) Complex-Complex DFT sz = # of complex inputs/outputs */ void fftc(struct blk *x, int sz) { float sc; fft(x,sz,-1); sc = 1.0/sz; while (--sz >= 0) { x[sz].r *= sc; x[sz].i *= sc; } } /* iftc(*blk,sz) Complex-Complex IFT sz = # of complex inputs/outputs */ void iftc(struct blk *x, int sz) { fft(x,sz,1); } /* fftr(*blk,sz) Real-Complex DFT sz = # of real inputs */ void fftr(struct blk *x, int sz) { float sc; sc = (0.5*RMS)/sz; /* scale fft results (as rms single sided spectrum) */ fft(x,sz>>=1,-1); hfold(x,sz,-1); /* hermitian fold */ x[0].r = RMS * (x[0].r + x[0].i); x[0].i = 0.0; /* don't compute fmax term */ while (--sz>=0) { x[sz].r *= sc; x[sz].i *= sc; } } /* iftr(*blk,sz) Complex-Real IFT sz = # of real outputs */ void iftr(struct blk *x, int sz) { float sc; hfold(x,sz>>=1,1); /* hermitian fold */ x[0].i = x[0].r; fft(x,sz,1); sc = 1.0/RMS; /* scale result (assume rms single sided spectrum) */ while (--sz>=0) { x[sz].r *= sc; x[sz].i *= sc; } /* scale result */ }
Reply by ●May 18, 20052005-05-18
Thank you for your answers. I have another problem. I can't use the math.h library, for this reason I can't use the sin cos function. Diego
Reply by ●May 27, 20052005-05-27
In article <1115853350.319429.148020@o13g2000cwo.googlegroups.com>, dfalvarado@utpl.edu.ec wrote:> 4.I was trying to do a FFT with standart FFT C library. Here I have > problems, because, the algorithm calls to sin or cos function, but the > compiler doesn't support it, I think thta I need to work with data > tables. The question is:Use CORDIC to generate sin and cos in fixed-point: http://www.worldserver.com/turk/opensource/index.html#CORDIC
