Hi All, Excuse me if this is the wrong place to post but.. I have written an app in java that reads from an input from my soundcard. I want to take that input and detect the note that is playing, so I can write a GUI guitar tuner plug in. Assuming I have the input ( I can determing the audio format and generate a waveform from that, which I am displaying in a real time graph), could some one point me to the algorithms I should be using to compute the frequency of the note being played? Cheers, Steve
Guitar tuning algorithms..
Started by ●May 15, 2005
Reply by ●May 15, 20052005-05-15
in article R8Rhe.32632$G8.10976@text.news.blueyonder.co.uk, SPG at steve.goodsell@nopoo.blueyonder.co.uk wrote on 05/15/2005 19:43:> Excuse me if this is the wrong place to post but..not the wrong place. also try the music-dsp mailing list.> I have written an app in java that reads from an input from my soundcard. > I want to take that input and detect the note that is playing, so I can > write a GUI guitar tuner plug in.so, i'm assuming that your java program has a buffer of the most current N samples (say N is 2048 or 2096 if your sampling rate is 44100 Hz). you have those sample words and can barf them back out or draw them or do whatever maths your heart desires (and brain conceives), right?> Assuming I have the input ( I can determing the audio format and generate a > waveform from that, which I am displaying in a real time graph), could some > one point me to the algorithms I should be using to compute the frequency of > the note being played?this falls in the general category of "pitch detection". you want the *fundamental frequency* of the waveform, i believe. it's the reciprocal of the period. computing the latter can be done with something called the Average Magnitude Difference Function (AMDF) or a variant sometimes called the Average Squared Difference Function (ASDF). it's pretty easy conceptually and computationally expensive. is that a problem? -- r b-j rbj@audioimagination.com "Imagination is more important than knowledge."
Reply by ●May 16, 20052005-05-16
On Sun, 15 May 2005 23:43:45 GMT, "SPG" <steve.goodsell@nopoo.blueyonder.co.uk> wrote:>Hi All, > >Excuse me if this is the wrong place to post but..This is so the right place to post this, that we've already discussed it several times before.>I have written an app in java that reads from an input from my soundcard. >I want to take that input and detect the note that is playing, so I can >write a GUI guitar tuner plug in.I presume you want to write this for the joy of learning how to do this, because it's already been done very well. I won't give you a link here, but I'm sure I mention it in one of the threads below.>Assuming I have the input ( I can determing the audio format and generate a >waveform from that, which I am displaying in a real time graph), could some >one point me to the algorithms I should be using to compute the frequency of >the note being played?There's been a recent thread on pitch detection of musical instruments. Actually, TWO recent threads: http://groups-beta.google.com/group/sci.electronics.design/browse_frm/thread/785ee9c7e7ab391f http://groups-beta.google.com/group/comp.dsp/browse_frm/thread/625e85a8394d7011>Cheers, > >Steve----- http://mindspring.com/~benbradley
"robert bristow-johnson" <rbj@audioimagination.com> wrote in message news:BEAD7507.7500%rbj@audioimagination.com...> in article R8Rhe.32632$G8.10976@text.news.blueyonder.co.uk, SPG at > steve.goodsell@nopoo.blueyonder.co.uk wrote on 05/15/2005 19:43: > >> Excuse me if this is the wrong place to post but.. > > not the wrong place. also try the music-dsp mailing list. > >> I have written an app in java that reads from an input from my soundcard. >> I want to take that input and detect the note that is playing, so I can >> write a GUI guitar tuner plug in. > > so, i'm assuming that your java program has a buffer of the most current N > samples (say N is 2048 or 2096 if your sampling rate is 44100 Hz). you > have > those sample words and can barf them back out or draw them or do whatever > maths your heart desires (and brain conceives), right? > >> Assuming I have the input ( I can determing the audio format and generate >> a >> waveform from that, which I am displaying in a real time graph), could >> some >> one point me to the algorithms I should be using to compute the frequency >> of >> the note being played? > > this falls in the general category of "pitch detection". > > you want the *fundamental frequency* of the waveform, i believe. it's the > reciprocal of the period. computing the latter can be done with > something > called the Average Magnitude Difference Function (AMDF) or a variant > sometimes called the Average Squared Difference Function (ASDF). it's > pretty easy conceptually and computationally expensive. is that a > problem? > > -- > > r b-j rbj@audioimagination.com > > "Imagination is more important than knowledge." > >Hi, Thanks for the response.. Yes, I have a buffer that I can play with at my lesiure... Therefore I can pass the data to whateverroutines I need to create in order to handle the pitch detection you suggested. I'll google a bit more on AMDF to see what I can come up with... Cheers, Steve
"Ben Bradley" <ben_nospam_bradley@frontiernet.net> wrote in message news:943g8115injo5dcqdv8ator5hadb1128aq@4ax.com...> On Sun, 15 May 2005 23:43:45 GMT, "SPG" > <steve.goodsell@nopoo.blueyonder.co.uk> wrote: > >>Hi All, >> >>Excuse me if this is the wrong place to post but.. > > This is so the right place to post this, that we've already > discussed it several times before. > >>I have written an app in java that reads from an input from my soundcard. >>I want to take that input and detect the note that is playing, so I can >>write a GUI guitar tuner plug in. > > I presume you want to write this for the joy of learning how to do > this, because it's already been done very well. I won't give you a > link here, but I'm sure I mention it in one of the threads below. > >>Assuming I have the input ( I can determing the audio format and generate >>a >>waveform from that, which I am displaying in a real time graph), could >>some >>one point me to the algorithms I should be using to compute the frequency >>of >>the note being played? > > There's been a recent thread on pitch detection of musical > instruments. Actually, TWO recent threads: > > http://groups-beta.google.com/group/sci.electronics.design/browse_frm/thread/785ee9c7e7ab391f > > http://groups-beta.google.com/group/comp.dsp/browse_frm/thread/625e85a8394d7011 > >>Cheers, >> >>Steve > > ----- > http://mindspring.com/~benbradleyHi Ben, I guessed there'd be more posts on this - I'll trawl a bit more and see what I come up with. You are correct, It is a personal project that I am working on for pure *fun*. I don't want to steal/copy anyone's code, just after the rules for performing this type of feature. I'll have a read of your threads and see what I can muster up and if I fail I'll come begging again! Steve
SPG wrote: ...> I'll have a read of your threads and see what I can muster up and if I fail > I'll come begging again!If you come up with an interesting twist, patent it or let us know. The Hidden Line Problem was a thorn in the side of the computer graphics world until an amateur programmer solved it and asked that his "clumsy" approach be excused as something he had just thrown together. Jerry -- Engineering is the art of making what you want from things you can get. �����������������������������������������������������������������������
in article VsGdnX1dmYzhORXfRVn-1g@rcn.net, Jerry Avins at jya@ieee.org wrote on 05/16/2005 09:47:> The Hidden Line Problem was a thorn in the side of the computer > graphics world until an amateur programmer solved it ...what's the trick to the Hidden Line Problem? i would think that if you ordered all of the vertices in order of distance from the observer, then drew the lines and planes with the furthest vertices first, the closer surfaces would be drawn last and cover the further surfaces (and lines or ridges that extend behind the visible surfaces) which is what we want. no? just a dumb question from someone who as never done anything like that except in drawing a family of curves. -- r b-j rbj@audioimagination.com "Imagination is more important than knowledge."
robert bristow-johnson wrote:> in article VsGdnX1dmYzhORXfRVn-1g@rcn.net, Jerry Avins at jya@ieee.org wrote > on 05/16/2005 09:47: > > >>The Hidden Line Problem was a thorn in the side of the computer >>graphics world until an amateur programmer solved it ... > > > what's the trick to the Hidden Line Problem? i would think that if you > ordered all of the vertices in order of distance from the observer, then > drew the lines and planes with the furthest vertices first, the closer > surfaces would be drawn last and cover the further surfaces (and lines or > ridges that extend behind the visible surfaces) which is what we want. no? > > just a dumb question from someone who as never done anything like that > except in drawing a family of curves.In the beginning was the vector. Do you remember the enormous vector graphic terminals that only DOD could afford? An early use for high-speed DACs was generating X and Y deflection. Lines were specified by their beginning and ending points, and ordered in the display list with an empirical traveling salesman algorithm. With too many lines, the display would flicker. When RAM became dense and cheap enough to support it, we got raster graphics. There were standard ways to convert the output of vector algorithms to display bits, and lots of lines didn't slow the refresh. The fancy line ordering wasn't needed, but the complex work of determining which parts of which lines were hidden by implied planes was done the tried-and-true way before all was projected onto the display plane. Our overworked engineer was programming a presentation of his work. He knew nothing about computer graphics, including where to look anything up, so he innovated. He drew the entire rear-most plane into display RAM, then moved forward a cell and overwrote it with the next one, moving forward a cell at a time till he reached the front. The only lines or parts that remained were those that had nothing in front of them. Instead of a vector solution transformed to raster -- not one of those algorithms that I knew of was entirely bug free -- he devised the first (henceforth known as "brute force") way based on raster that used raster as a starting point. Jerry -- Engineering is the art of making what you want from things you can get. �����������������������������������������������������������������������
Reply by ●May 17, 20052005-05-17
in article vo-dnRDyKb1MmhTfRVn-sw@rcn.net, Jerry Avins at jya@ieee.org wrote on 05/16/2005 16:51:> robert bristow-johnson wrote: >> in article VsGdnX1dmYzhORXfRVn-1g@rcn.net, Jerry Avins at jya@ieee.org wrote >> on 05/16/2005 09:47: >> >> >>> The Hidden Line Problem was a thorn in the side of the computer >>> graphics world until an amateur programmer solved it ... >> >> >> what's the trick to the Hidden Line Problem? i would think that if you >> ordered all of the vertices in order of distance from the observer, then >> drew the lines and planes with the furthest vertices first, the closer >> surfaces would be drawn last and cover the further surfaces (and lines or >> ridges that extend behind the visible surfaces) which is what we want. no? >> >> just a dumb question from someone who as never done anything like that >> except in drawing a family of curves. > > In the beginning was the vector. Do you remember the enormous vector > graphic terminals that only DOD could afford?never saw one of them. but i *did* see a graphics printer with pens (that needed pen-down and pen-up commands, as well as move commands).> The fancy line ordering wasn't needed, but the complex work of > determining which parts of which lines were hidden by implied planes was > done the tried-and-true way before all was projected onto the display plane.i understand except what is the "tried-and-true way".> Our overworked engineer was programming a presentation of his work. He > knew nothing about computer graphics,like me.> including where to look anything up, so he innovated.sounds like wheels i had to re-invent.> He drew the entire rear-most plane into display > RAM, then moved forward a cell and overwrote it with the next one, > moving forward a cell at a time till he reached the front.okay, what precisely, is a "cell"? is it a corner of a finite plane? is it a pixel that possibly lies on a line? is it a pixel of a plane? how is this different from what i described? how is this *not* "fancy line ordering"? since the coordinates of the rear-most plane are not all the same distance from the observer, what defines the rear-most plane? the rear-most corner of a plane? what if planes intersect (and pass through each other)? must that not be determined first? or is that simply prohibited in this practical 3-D graphics scheme (i.e. planes end where they are joined)?> The only lines or parts that remained were those that had nothing in front > of them. Instead of a vector solution transformed to raster -- not one of > those algorithms that I knew of was entirely bug free -- he devised the > first (henceforth known as "brute force") way based on raster that used > raster as a starting point.sounds like the wheel i was reinventing. i dunno how i would extend it to surfaces that were not planes. like parts of spheres or ellipsoids. and what about solids? -- r b-j rbj@audioimagination.com "Imagination is more important than knowledge."
robert bristow-johnson wrote:> in article vo-dnRDyKb1MmhTfRVn-sw@rcn.net, Jerry Avins at jya@ieee.org wrote > on 05/16/2005 16:51: > > >>robert bristow-johnson wrote: >> >>>in article VsGdnX1dmYzhORXfRVn-1g@rcn.net, Jerry Avins at jya@ieee.org wrote >>>on 05/16/2005 09:47: >>> >>> >>> >>>>The Hidden Line Problem was a thorn in the side of the computer >>>>graphics world until an amateur programmer solved it ... >>> >>> >>>what's the trick to the Hidden Line Problem? i would think that if you >>>ordered all of the vertices in order of distance from the observer, then >>>drew the lines and planes with the furthest vertices first, the closer >>>surfaces would be drawn last and cover the further surfaces (and lines or >>>ridges that extend behind the visible surfaces) which is what we want. no? >>> >>>just a dumb question from someone who as never done anything like that >>>except in drawing a family of curves. >> >>In the beginning was the vector. Do you remember the enormous vector >>graphic terminals that only DOD could afford? > > > never saw one of them. but i *did* see a graphics printer with pens (that > needed pen-down and pen-up commands, as well as move commands).I have two. They run off HPIB; there's a parallel-port adapter cable for one. Do you want one?>>The fancy line ordering wasn't needed, but the complex work of >>determining which parts of which lines were hidden by implied planes was >>done the tried-and-true way before all was projected onto the display plane. > > > i understand except what is the "tried-and-true way".Project lines from the viewplane to each pixel on the line. If the projected line intersects anything, don't display that pixel. Is it any wonder that refresh was slow with more than a few lines and the planes they defined?>>Our overworked engineer was programming a presentation of his work. He >>knew nothing about computer graphics, > > > like me. > > >>including where to look anything up, so he innovated. > > > sounds like wheels i had to re-invent. > > >>He drew the entire rear-most plane into display >>RAM, then moved forward a cell and overwrote it with the next one, >>moving forward a cell at a time till he reached the front. > > > okay, what precisely, is a "cell"? is it a corner of a finite plane? is it > a pixel that possibly lies on a line? is it a pixel of a plane? how is > this different from what i described? how is this *not* "fancy line > ordering"?A cell is a cube. Its sides are x, y, and z. "Picture cell" slid into "pixel" Instead of writing "moved forward a cell", I would better have written "moved forward to the next z plane." About fancy line ordering: imagine one of those pen plotters were drawing the pictures, and the aim is to minimize total pen motion. There is a drawing order that does that. To show yourself that the ordering is fancy, try to program it. Include optimization when some lines have their middles obscured. This matters even with DACs, because large jumps in yoke current need more settling time than small ones.> since the coordinates of the rear-most plane are not all the same distance > from the observer, what defines the rear-most plane? the rear-most corner > of a plane? what if planes intersect (and pass through each other)? must > that not be determined first? or is that simply prohibited in this > practical 3-D graphics scheme (i.e. planes end where they are joined)?For the most part, we're considering orthographic projection. Perspective is usually derived from an orthographic view by warping it. That doesn't have the precision of ray tracing, but few notice. Leaving the hidden lines in makes a "wire frame model", much simpler both in vector and raster graphics.>>The only lines or parts that remained were those that had nothing in front >>of them. Instead of a vector solution transformed to raster -- not one of >>those algorithms that I knew of was entirely bug free -- he devised the >>first (henceforth known as "brute force") way based on raster that used >>raster as a starting point. > > > sounds like the wheel i was reinventing. i dunno how i would extend it to > surfaces that were not planes. like parts of spheres or ellipsoids. and > what about solids?Surfaces are often defined by a web of triangles, as in finite-element modeling. Shading depends on orientation; one way to make the joining lines disappear is specifying the brightness at the centroids of the triangles and use a 2-D low-pass filter to find the brightness at intermediate points. Many graphics guys don't know it's a 2-D LPF. They think its Somebody's Algorithm. Graphics, like DSP, is science, art, and accumulated wisdom. When a graphics guy asks me about DSP, I can explain a little. I can actually do that a little better than explaining graphics to a DSP guy. Unless there's something I wrote that's still unclear, I haven't much more to offer. Jerry -- Engineering is the art of making what you want from things you can get. �����������������������������������������������������������������������
