Hi all, I have never implemented blind demodulation of QAM, and seen all the problems first hand. However, the material I have seen on the subject is all based on despinning the constellation by looking for the corners of a square (or squarish) array sticking out. In schemes like V.34 where the constellation has been completely rounded, to avoid high energy states, are there any practical schemes what will let you latch on to the constellation, and track the carrier? I can see some non-practical ones, based on masses of trial and error, but what about something you could put in a product? Regards, Steve
Blind demodulation of things like V.34
Started by ●May 18, 2005
Reply by ●May 19, 20052005-05-19
Steve Underwood wrote:> I have never implemented blind demodulation of QAM, and seen all the > problems first hand. However, the material I have seen on the subject is > all based on despinning the constellation by looking for the corners of > a square (or squarish) array sticking out.(snip) My understanding of QAM, mostly from the early days, was the you square the signal which allows you to find the transitions, assuming a sufficient density of transitions. Scramblers are used to generate transitions in low entropy input data. (Like many zeros in a row.) -- glen
Reply by ●May 20, 20052005-05-20
glen herrmannsfeldt wrote:> Steve Underwood wrote: > >> I have never implemented blind demodulation of QAM, and seen all the >> problems first hand. However, the material I have seen on the subject >> is all based on despinning the constellation by looking for the >> corners of a square (or squarish) array sticking out. > > > (snip) > > My understanding of QAM, mostly from the early days, was the you square > the signal which allows you to find the transitions, assuming a > sufficient density of transitions. Scramblers are used to generate > transitions in low entropy input data. (Like many zeros in a row.)In the early days of QAM it was thought that blind demodulation was impractical. Regards, Steve
