Relation between dynamic range and bandwidth?
Started by Unknown ●May 19, 2005
Consider a sampled a signal taking values in a certain range.
In the case of an image for, instance, the samples are always positive,
being related to light intensity, their values are bounded by dynamic
range of the sensor, etc...
Let's consider, for instance, a 1-D signal sampled with 8 bits. The
values will be in the [0,255] interval.
Now let's generate random values of this signal x_i, i=0,...,N-1
according to some ditribution, and let's consider these values as
samples of an unknow continuous signal x(t) that we want to
reconstruct. If I use sinc interpolation on this data set to
reconstruct the values of x(t) between the samples, I see values that
fall outside the [0,255] interval. This is telling me that I have in
some way "undersampled" x(t), or, in other words, that by generating
random values I have created a signal whose bandwidth is too high for
the sampling rate.
Now things gets confusing, since the sampling rate has not really been
defined...
In summary, it seems that there should be a relationship between the
dynamic range range of a signal and its bandwidht, so that by filtering
the sequence of random values I should be able to obtain values in the
[0-255] by sinc interpolation.
Any ideas?
-Arrigo
dudesinmexico@gmail.com wrote:
> Consider a sampled a signal taking values in a certain range. > In the case of an image for, instance, the samples are always positive, > being related to light intensity, their values are bounded by dynamic > range of the sensor, etc... > Let's consider, for instance, a 1-D signal sampled with 8 bits. The > values will be in the [0,255] interval. > Now let's generate random values of this signal x_i, i=0,...,N-1 > according to some ditribution, and let's consider these values as > samples of an unknow continuous signal x(t) that we want to > reconstruct. If I use sinc interpolation on this data set to > reconstruct the values of x(t) between the samples, I see values that > fall outside the [0,255] interval. This is telling me that I have in > some way "undersampled" x(t), or, in other words, that by generating > random values I have created a signal whose bandwidth is too high for > the sampling rate. > Now things gets confusing, since the sampling rate has not really been > defined... > In summary, it seems that there should be a relationship between the > dynamic range range of a signal and its bandwidht, so that by filtering > the sequence of random values I should be able to obtain values in the > [0-255] by sinc interpolation. > > Any ideas? > > -Arrigo
It seems to me that you are mixing several ideas together, but there is one overriding difficulty. You have no assurance that randomly generated samples will represent a band-limited signal; one that can be validly sampled. By assuming the validity of the samples, you have adopted a false premise from which anything -- even the moon's being made of cheese -- can be established by thenceforward valid logic. Jerry -- Engineering is the art of making what you want from things you can get. �����������������������������������������������������������������������
Jerry Avins wrote:
> It seems to me that you are mixing several ideas together, but there is > one overriding difficulty. You have no assurance that randomly generated > samples will represent a band-limited signal; one that can be validly > sampled. By assuming the validity of the samples, you have adopted a > false premise from which anything -- even the moon's being made of > cheese -- can be established by thenceforward valid logic.
Scratch that. There's always some weird (and not necessarily everywhere finite) signal that is both bandlimited and represented by an arbitrary set of samples. Assume that our ADC's input range is +/-1 and that it is never overloaded. The sequence +1 +1 +1 +1 +1 -1 -1 -1 -1 -1 ... doesn't represent a square wave -- that wouldn't be bandlimited -- but something very different. However, the sequence +1 +1 0 -1 -1 0 is bandlimited; it represents a single sinusoid at Fs/3 with amplitude of 2/sqrt(3). Even with well defined sample trains, it's wrong to assume that the signal amplitude doesn't exceed the magnitude of the largest sample. Jerry -- Engineering is the art of making what you want from things you can get. �����������������������������������������������������������������������
So let me restate this problem in a different way. How can I generate a
random, discrete, periodic signal taking values in a certain range so
that by sinc interpolating the samples I always obtain values in the
same range?
-Arrigo
> So let me restate this problem in a different way. How can I generate a > random, discrete, periodic signal taking values in a certain range so > that by sinc interpolating the samples I always obtain values in the > same range? > > -Arrigo
As far as I know, you can't. Didn't I just provide a counterexample? Jerry -- Engineering is the art of making what you want from things you can get. �����������������������������������������������������������������������
dudesinmexico@gmail.com writes:
Hi Arrigo, How can a signal be random and periodic at the same time? Did you mean an *arbitrary* periodic signal? When you say you want to obtain values in the same range, I'm assuming that you mean you don't want to exceed the maximum or minimum of that range. Here's perhaps some insight that may help answer your question. When you sinc-interpolate a signal x[n], you perform the following operation: x(t) = \sum_{n=-\infty}^{+\infty} x[n] * sinc(tau - nT) This is at a maximum when x[n] = A*sgn(sinc(tau - nT)). It can be shown that this maximum is unbounded, i.e., lim_{N\approaches\infty} \sum_{n=-N}^{+N} x[n] * sinc(tau - nT) does not exist. Does that help? -- Randy Yates Sony Ericsson Mobile Communications Research Triangle Park, NC, USA randy.yates@sonyericsson.com, 919-472-1124
Randy, first of all I want to thank you for spending some time on this
problem.
Yes, by random I mean random for t=0,...,N-1 then these values are
repeated periodically for t=-\infty...+\infty.
This is consistent with the fact that I use the FFT to do the sinc
interpolation (I FFT the data, multiply by e^{-j*2*pi/N*dx}, then
inverse FFT).
The original problem that I have is the following:
1. I generate N random samples x_t \in [0,A], t=0,...,N
2. I compute the FFT X_k=FFT{x_t}
3. Now I apply a phase shift in the frequency domain:
Y_k=X_k*e^{-j*2*pi/N*dx}
4. I inverse transform X_k: y_t=IFFT{Y_k}
Now I notice that some of the y_t are <0, some are > A.
So the question is: what kind of filtering/transformation should I
apply to the x_t between steps 1. and 2. to ensure that all the y_t \in
[0,A]?
Now that I think more about it, it seems that y_t should have *more*
harmonics, so maybe filtering x_t does not solve the problem.
Now you are wondering what this is all about, huh?
I want to generate some synthetic images as ground truth to test an
image registration algorithm. By doing this in the frequency domain I
can enforce these images to be "perfectly" aligned, if the images are
also bandlimited. This brings us back to the original question: like
you pointed out, one cannot generate random samples and expect them to
be samples of a bandlimited function.
Is this more clear now?
-Arrigo
<dudesinmexico@gmail.com> wrote in message
news:1116617006.771789.155470@g14g2000cwa.googlegroups.com...
> Randy, first of all I want to thank you for spending some time on this > problem. > Yes, by random I mean random for t=0,...,N-1 then these values are > repeated periodically for t=-\infty...+\infty. > This is consistent with the fact that I use the FFT to do the sinc > interpolation (I FFT the data, multiply by e^{-j*2*pi/N*dx}, then > inverse FFT). > The original problem that I have is the following: > > 1. I generate N random samples x_t \in [0,A], t=0,...,N > 2. I compute the FFT X_k=FFT{x_t} > 3. Now I apply a phase shift in the frequency domain: > Y_k=X_k*e^{-j*2*pi/N*dx} > 4. I inverse transform X_k: y_t=IFFT{Y_k} > > Now I notice that some of the y_t are <0, some are > A. > So the question is: what kind of filtering/transformation should I > apply to the x_t between steps 1. and 2. to ensure that all the y_t \in > [0,A]? > Now that I think more about it, it seems that y_t should have *more* > harmonics, so maybe filtering x_t does not solve the problem. > Now you are wondering what this is all about, huh? > I want to generate some synthetic images as ground truth to test an > image registration algorithm. By doing this in the frequency domain I > can enforce these images to be "perfectly" aligned, if the images are > also bandlimited. This brings us back to the original question: like > you pointed out, one cannot generate random samples and expect them to > be samples of a bandlimited function. > Is this more clear now? > > -Arrigo
Arrigo, I'm not sure that I agree with some of the responses you've received. Well, maybe not to disagree completely but perhaps in a practical sense. Here are some questions: Q: If you create a sequence of random numbers, what is the bandwidth? Q: Better stated: if you create a sequence of random numbers and assume a sample interval T, what is the bandwidth? A: I think you will find that the bandwidth is 1/(2T) for all practical purposes. Q: Can a sequence of random numbers be "reconstructed"? A: Most probably yes. Q: If so, what does that mean? A: I think it means: 1) Start with a sequence of random numbers on an assumed regular grid in time or space 2) Interpolate them with a suitably large family of shifted sincs of suitable duration. 3) Sample the result at the same points as before. Do the samples match? If yes, the sequence was faithfully reconstructed. If no, then it wasn't. Q: How might one do this such that the resampling of the reconstruction is different? A: If there is temporal aliasing allowed to occur in the interpolation. Q: How can temporal aliasing be caused by interpolating? A: If interpolation is done by multiplication in the frequency domain and the array size in frequency is too short for the resulting temporal cicular convolution results. Or, equivalently, if the interpolation is done by temporal convolution using circular convolution and the array sizes are too short - causing overlap / aliasing. A: If the interpolation is done in the frequency domain by appending zeros around fs/2 and if there is substantial energy at fs/2. If there is substantial energy at fs/2, there will be a sharp discontinuity at fs/2 when the zeros are added. This will cause higher "quefrencies" to occur in the time domain - thus aliasing in time. Q: How can one guarantee the use of dynamic range in reconstruction of an arbitrary set of samples? A: You can't. So, you are perhaps stuck with doing some scaling. Q1: What happens if one generates a sequence of random numbers at 100fs, perfectly lowpass filters them to fs/2 and decimates the result to a sequence sampled at fs - i.e. by a factor of 100? Q2: Why is that different than simply generating the samples at fs in the first place? Q3: Why is that different than the result obtained from the lowpassed case above? Q4: Why is that different than selecting every 100th sample from the sequence generated at 100fs? Q5: What happens if you take any of the sequences from Q2, Q3 or Q4 and reconstruct them using a sample rate of 100fs? Using reasonable assumptions about how you go about this, do you get the sequence generated in Q1? Consider this: You started with a random sequence that has a limited dynamic range. So, it's not Gaussian. If it were, it would have some probability of having very large values. If you were to generate two independent sequences with the same limited dynamic range and were to add them together, the new dyamic range limit would be 2x the original. Three would be 3x and so on. If we examine the probability distribution of amplitudes of the output, we see that the distribution becomes more and more like Gaussian. The probability of hitting the theoretical maximum values gets lower and lower as more sequences are added. See the Central Limit Theorem. Similarly, an interpolating filter adds the values of multiple samples. The only difference from above is that they are weighted by the filter coefficients. Accordingly, the new dynamic range will be the original multiplied by the length of the filter (assuming it is a FIR filter) and multiplied by the sum of the magnitudes of the filter coefficients. Take some examples: - All of the inputs are at the maximum of the dynamic range. ..The output is the sum of the filter coefficients multiplied by the maximum of the dynamic range. - All of the inputs are at the maximum of the dynamic range and have the same sign as the coefficients of the filter ..The output is the sum of the magnitudes of the filter coefficients multiplied by the maximum of the dynamic range .... and, is larger than the first example. Obviously, selecting the relative magnitudes of the coefficients of the filter will impact the result. This is just one method of scaling. You will notice that I stayed away from the theoretical treatements and tried to build from practical situations. It bothers me when a practical solution exists in the midst of a proof that says it might not - without some mention of the probability of failure or the conditions necessary to fail, etc. Fred
> ... This brings us back to the original question: like > you pointed out, one cannot generate random samples and expect them to > be samples of a bandlimited function. > Is this more clear now?
It was I who wrote that, but I realized it was wrong and retracted it. It is simple to find a band-limited continuous function that when samples, yields the sample set in question. It may have isolated infinities and will have a non-intuitive shape, but it exists. It is your amplitude criterion that can't be met. Jerry -- Engineering is the art of making what you want from things you can get. &#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;
Jerry Avins wrote:
(snip)
> Scratch that. There's always some weird (and not necessarily everywhere > finite) signal that is both bandlimited and represented by an arbitrary > set of samples. Assume that our ADC's input range is +/-1 and that it is > never overloaded. The sequence +1 +1 +1 +1 +1 -1 -1 -1 -1 -1 ... doesn't > represent a square wave -- that wouldn't be bandlimited -- but something > very different. However, the sequence +1 +1 0 -1 -1 0 is bandlimited; it > represents a single sinusoid at Fs/3 with amplitude of 2/sqrt(3). Even > with well defined sample trains, it's wrong to assume that the signal > amplitude doesn't exceed the magnitude of the largest sample.
That would seem to mean that an amplitude limited analog signal can't use the full range of the digitized signal. That is, that such sampled signals should be at least slightly compressible. -- glen
