glen herrmannsfeldt wrote:> robert bristow-johnson wrote: > >> in article nd2v819hjk68l1ng06mqm0k5aof3hars7o@4ax.com, Greg Berchin at >> 76145.2455@compuswerve.com wrote on 05/21/2005 15:24: > > >>> I have a digital filter implementation for each of these, at 192 kHz >>> sampling rate, that matches the ideal analog filter �0.025 dB amplitude >>> and �0.25� phase from DC to over 75 kHz. >> > >> gee, Greg, i just don't think that's good enough. i think you need to >> tighten those specs a bit. > > > Maybe he has some CD4 albums. Didn't they go pretty high with a > subcarrier in each channel? > > Otherwise, it is a little high for a phono cartridge. > > -- glen >Wow. CD4 takes me back. Next someone will be digging up Teledec video disks. Those definitely need sampling faster than 192kHz :-) Regards, Steve
Phono EQ
Started by ●May 21, 2005
Reply by ●May 22, 20052005-05-22
Reply by ●May 23, 20052005-05-23
Greg Berchin wrote:> On Mon, 02 May 2005 12:54:33 -0500, Greg Berchin > <76145.2455@compuswerve.com> wrote: > >>>I am looking for every bit of information that I can find >>>about EQ curves used before RIAA EQ was adopted. > > A followup to my previous message: > > I have been able to identify the following EQ curves. If anyone knows > of additional curves, or finds any errors, please post. (See > http://www.rfwilmut.clara.net/repro78/repro.html for definitions of > "Turnover" and "Tip" frequencies.) [..]Do you know this page? http://www.shellac.org/wams/wequal.html It was linked from heree: http://www.hagtech.com/bugle.html> Bass Tip/Bass Turnover/Treble Turnover combinations > --------------------------------------------------- > / 150/ 3.4k Decca > / 150/ 5.8k early Decca > > / 200/ flat Westrex > / 200/ 5.8k Columbia 1925 > 40/ 200/ 6.36k American 1025, Victor 1925 (some) > > 50/ 250/ flat Blumlein, HMV > / 250/ flat Columbia (Eng.), EMI 1931 > 40/ 250/ 6.36k London FFRR 1949, FFRR 78 > > / 300/ 1.6k Columbia 1938 > / 300/ 2k FFRR 1951 > > 50/ 353/ 3.18k BSI > > / 375/ 2.5k Decca 1934 > / 375/ 5.8k Decca FFRR 1949, EMI > / 375/ 6.36k Decca FFRR 1949, EMI, Victor 1925 (some) > > 70/ 400/ flat early 78 (mid-'30s), US mid 30 > / 400/ 2.5k old AES, Decca 1934, Mercury > > 100/ 450/ 3k FFRR 1953 > > / 500/ flat early 78, Brunswick, Parlophone > 100/ 500/ 1590 Columbia LP > / 500/ 1590 early LP > / 500/ 1.6k early LP, NAB, NARTB > 70/ 500/ 2.5k EMI > / 500/ 2.5k Capitol 1942, MGM, Victor 1947-1952 > 100/ 500/ 3k FFRR > 50/ 500/ 3.18k CCIR > / 500/ 3.18k London FFRR > / 500/ 3.4k Concert Hall until 1952, Oiseau-Lyre until 1954 > / 500/ 5.8k Victor 1938-1947 > > 50.05/500.5/2.122k RIAA > > / 629/ flat "629" > > / 800/ 2.5k early RCAThese are the data that I have found a few years ago: 50.05/500.5/2122 RIAA/CCIR 100/450/3000 London ffrr LP 1953 70/500/2500 EMI LP flat/500/1600 NAB Don't ask me where I found them, I surely don't remember. bye Andreas -- Andreas H�nnebeck | email: ah@despammed.com ----- privat ---- | www : http://www.huennebeck-online.de Fax/Anrufbeantworter: 0721/151-284301 GPG-Key: http://www.huennebeck-online.de/public_keys/andreas.asc
On Mon, 23 May 2005 10:09:16 +0200, Andreas Huennebeck <ah@despammed.com> wrote:>>Do you know this page? http://www.shellac.org/wams/wequal.htmlYes, thank you. Much of my info came from there. There are some disagreements between various sources. It is difficult to sort out.>>These are the data that I have found a few years ago: >> >> 50.05/500.5/2122 RIAA/CCIR >> 100/450/3000 London ffrr LP 1953 >> 70/500/2500 EMI LP >> flat/500/1600 NABYes, they are all in my original chart. Thanks, Greg
glen herrmannsfeldt wrote:> Greg Berchin wrote: > >> I am taking the liberty of crossposting from rec.antiques.radio+phono, >> in case there are any collectors who monitor comp.dsp: > > >> On Mon, 02 May 2005 12:54:33 -0500, Greg Berchin >> <76145.2455@compuswerve.com> wrote: > > >>>> I am looking for every bit of information that I can find >>>> about EQ curves used before RIAA EQ was adopted. > > >> A followup to my previous message: > > >> I have been able to identify the following EQ curves. If anyone knows >> of additional curves, or finds any errors, please post. (See >> http://www.rfwilmut.clara.net/repro78/repro.html for definitions of >> "Turnover" and "Tip" frequencies.) > > > When I was younger, my father had a preamp with knobs to select the > various frequencies. It might be that turnover sounds familiar. > At some age I would turn the knobs, not knowing what they did.I built one of them around 1952. (Somewhere, I still have the schematic and a set of components to make another.) RIAA was so similar to RCA's that the same served for both. (RIAA was only being talked about when I built it.) Columbia had its own, which it used for the pressings it did for small labels like Haydn Society. London's was FFRR (full frequency-range recording.) There was also NAB and AES, both available in the respective archives, I'm sure. Other settings were for old 78s: 500-flat, 250-flat, and more that I forget. Record grooves are cut with a magnetic cutter and spec'ed to be played with a magnetic pickup. Music has very little high-frequency energy, while recording media tend to have increasing high-frequency noise. To maintain SNR, signals above the "turnover frequency" are boosted on record and cut on playback. Groove excursions become excessive at low frequencies if recorded with flat frequency response, so signals below the "rolloff frequency" are cut on record and boosted on playback. The choice of rolloff and turnover points are a matter of engineering judgment and NIH mentality. Magnetic cartridges are velocity-sensitive transducers. The general effect of low-end boost and high-end cut in the preamplifier made its output the rough equivalent of a displacement-sensitive device. The small relative flat mid-frequency region amounts to a high-end shelf boost between 3 and 6 dB. Crystal cartridges produced directly the voltage level expected from a mag cartridge's preamp. Being displacement devices, they had built-in compensation. The high-end boost was achieved by not damping the high-end resonances. Simple, crude, cheap, and effective, even with a fairly decent 8" speaker.> When I was a little older, I knew to always keep them in the RIAA > position, though I did wonder what the others were for. I believe > it was a Heathkit from about 1958, just before I was born.Jerry -- Engineering is the art of making what you want from things you can get. �����������������������������������������������������������������������
Jerry Avins wrote: (I wrote)>> When I was younger, my father had a preamp with knobs to select the >> various frequencies. It might be that turnover sounds familiar. >> At some age I would turn the knobs, not knowing what they did.> I built one of them around 1952. (Somewhere, I still have the schematic > and a set of components to make another.) RIAA was so similar to RCA's > that the same served for both. (RIAA was only being talked about when I > built it.) Columbia had its own, which it used for the pressings it did > for small labels like Haydn Society. London's was FFRR (full > frequency-range recording.) There was also NAB and AES, both available > in the respective archives, I'm sure. Other settings were for old 78s: > 500-flat, 250-flat, and more that I forget.I am not sure by now that the labels were RIAA, but I believe they were the only one that was the same between the two switches. It would have been between 1954 and 1958.> Record grooves are cut with a magnetic cutter and spec'ed to be played > with a magnetic pickup. Music has very little high-frequency energy, > while recording media tend to have increasing high-frequency noise. To > maintain SNR, signals above the "turnover frequency" are boosted on > record and cut on playback. Groove excursions become excessive at low > frequencies if recorded with flat frequency response, so signals below > the "rolloff frequency" are cut on record and boosted on playback. The > choice of rolloff and turnover points are a matter of engineering > judgment and NIH mentality.> Magnetic cartridges are velocity-sensitive transducers. The general > effect of low-end boost and high-end cut in the preamplifier made its > output the rough equivalent of a displacement-sensitive device. The > small relative flat mid-frequency region amounts to a high-end shelf > boost between 3 and 6 dB.The first stereo system that was actually mine had a magnetic cartridge, but the receiver wasn't designed for one. Turn the volume up and the treble down and it works pretty well, though. -- glen
glen herrmannsfeldt wrote: ...> The first stereo system that was actually mine had a magnetic cartridge, > but the receiver wasn't designed for one. Turn the volume up and the > treble down and it works pretty well, though.There have always been separate phono preamps around. I recently resurrected one of the first stereo phono preamps sold by Radio Shack (PNP transistors, I think) because my new receiver doesn't have any phono input; I go into AUX. Plugging a crystal cartridge into a magnetic input works almost perfectly. Crystals are designed to look into a megohm, and typical inputs for magnetics are about 50K. The crystal has an internal that is nearly a pure capacitance, and the resulting R-C rolloff converts it to velocity sensitivity. The built-in high-end boost is modest enough to not be very bothersome. Jerry -- Engineering is the art of making what you want from things you can get. �����������������������������������������������������������������������
Reply by ●May 24, 20052005-05-24
Jerry Avins wrote:> There have always been separate phono preamps around. I recently > resurrected one of the first stereo phono preamps sold by Radio Shack > (PNP transistors, I think) because my new receiver doesn't have any > phono input; I go into AUX. Plugging a crystal cartridge into a magnetic > input works almost perfectly. Crystals are designed to look into a > megohm, and typical inputs for magnetics are about 50K. The crystal has > an internal that is nearly a pure capacitance, and the resulting R-C > rolloff converts it to velocity sensitivity. The built-in high-end boost > is modest enough to not be very bothersome.Now so long before I bought a nice big stereo amp that I still have, I built a phono preamp. A dual op amp, I believe 387, but I could be wrong, a few resistors and capacitors, and a power supply. I think I still have that, too. So now I have a nice amplifier with phono inputs that I don't use. (My turntable has been in a box since we last moved.) -- glen
glen herrmannsfeldt <gah@ugcs.caltech.edu> wrote in news:nrudnezaJfAbLw_fRVn-gw@comcast.com:> Jerry Avins wrote: > >> There have always been separate phono preamps around. I recently >> resurrected one of the first stereo phono preamps sold by Radio Shack >> (PNP transistors, I think) because my new receiver doesn't have any >> phono input; I go into AUX. Plugging a crystal cartridge into a >> magnetic input works almost perfectly. Crystals are designed to look >> into a megohm, and typical inputs for magnetics are about 50K. The >> crystal has an internal that is nearly a pure capacitance, and the >> resulting R-C rolloff converts it to velocity sensitivity. The >> built-in high-end boost is modest enough to not be very bothersome. > > Now so long before I bought a nice big stereo amp that I still > have, I built a phono preamp. A dual op amp, I believe 387, but > I could be wrong, a few resistors and capacitors, and a power > supply. I think I still have that, too. > > So now I have a nice amplifier with phono inputs that I don't use. > (My turntable has been in a box since we last moved.) > > -- glen > >I can't believe you guys are talking about phono preamps in this group. I started my career building high end audio preamps and power amplifiers. I even have a patent on a phono preamp design that I did when I was a Jr in EE. I think my old McIntosh preamp had alternate EQ but I'm not really sure anymore. I fairly certain one of my old preamps did. I used to own McIntosh's, Marantz's & lots of Dynaco stuff in the 1970s. -- Al Clark Danville Signal Processing, Inc. -------------------------------------------------------------------- Purveyors of Fine DSP Hardware and other Cool Stuff Available at http://www.danvillesignal.com
