You may guess i'm trying to correct CD subcodes R-W in software. Symbols are 6 bits each. I've seen the code here: http://www.eccpage.com/rs.c and a lovely explaination here: http://www.4i2i.com/reed_solomon_codes.htm my problem is, with s=6 (mm in the aforementioned code) that means my data n is 63 symbols long. but it's not, it's explicitly 4 symbols long, with 2 parity symbols (t = 1, k = 2). the other solution i need deals with 24 symbols with t=2 (4 symbols of parity, 20 of data) I heard something about just rounding up to the next table size and throwing out the unneded extras. Is that the way to go? What am I missing? how can you have n=4 when N must be 2**s-1 which always yields an odd number? Confused in CD+G land david my real email is quote me at davecotter dot com unquote
Help: need Reed-Solomon C++ code for RS(4, 2) and RS(24, 20) on 6 bit symbols
Started by ●August 20, 2004
Reply by ●August 23, 20042004-08-23
"Lazarus I. Long" <me@lazilong.com> wrote in message news:68a2ec1b.0408201038.6f3c34ab@posting.google.com...> my problem is, with s=6 (mm in the aforementioned code) that means my > data n is 63 symbols long. but it's not, it's explicitly 4 symbols > long, with 2 parity symbols (t = 1, k = 2). > > the other solution i need deals with 24 symbols with t=2 (4 symbols of > parity, 20 of data) > > I heard something about just rounding up to the next table size and > throwing out the unneded extras. Is that the way to go? What am I > missing? how can you have n=4 when N must be 2**s-1 which always > yields an odd number?You are dealing with *shortened* codes. A (4,2) RS with 6-bit symbols is just a (63, 61) RS code in which the first 59 data symbols are set to 0 (that is, each of these 59 six-bit symbols is 000000). If you have a program to encode/decode the (63, 61) code, it will encode/decode the (4,2) code as well if you set the first 59 data/received symbols to 0. If you delve into the details of the software, you will find that the program spins its wheels while it is processing the first 59 zeroes. In short, some re-programming (having some for-loops run for 4 instead of 61 iterations) will save a lot of time. Hope this helps.
