On 15/06/2016 21:12, Eric Jacobsen wrote: (snip)> That's good for non-flat or interference channels, but I thought the > OP was looking at flat AWGN, which is a bit harder to treat with side > information. >Eric, thanks, but it really was not a practical question. Just one morning I had a crazy idea that was driving me insane, so I shared it with the rest of the comp.dsp. ;-) Gene
signal transmission with cheats
Started by ●June 9, 2016
Reply by ●June 15, 20162016-06-15
On 15/06/2016 21:22, Evgeny Filatov wrote:> On 15/06/2016 21:12, Eric Jacobsen wrote: > (snip) > >> That's good for non-flat or interference channels, but I thought the >> OP was looking at flat AWGN, which is a bit harder to treat with side >> information. >> > > Eric, thanks, but it really was not a practical question. Just one > morning I had a crazy idea that was driving me insane, so I shared it > with the rest of the comp.dsp. ;-) > > Gene >My Usenet policy is that if I ask a question directly related to my work I specify that. I think that happened a couple times by now ;-). Most of the time I just enjoy a discussion and occasionally gain some knowledge I might (or might not) have a chance to use someday. Gene
On Wed, 15 Jun 2016 21:37:47 +0300, Evgeny Filatov <filatov.ev@mipt.ru> wrote:>On 15/06/2016 21:22, Evgeny Filatov wrote: >> On 15/06/2016 21:12, Eric Jacobsen wrote: >> (snip) >> >>> That's good for non-flat or interference channels, but I thought the >>> OP was looking at flat AWGN, which is a bit harder to treat with side >>> information. >>> >> >> Eric, thanks, but it really was not a practical question. Just one >> morning I had a crazy idea that was driving me insane, so I shared it >> with the rest of the comp.dsp. ;-) >> >> Gene >> > >My Usenet policy is that if I ask a question directly related to my work >I specify that. I think that happened a couple times by now ;-). >Most of the time I just enjoy a discussion and occasionally gain some >knowledge I might (or might not) have a chance to use someday. > >Gene >Totally understood. Conceptual experiments like that are often useful, or at a minimum sometimes just fun, so either way it's all good. ;)
Reply by ●June 16, 20162016-06-16
On Thursday, June 9, 2016 at 2:48:07 AM UTC-7, Evgeny Filatov wrote:> There's a rather bizarre thought experiment, that's hopefully > interesting to discuss.> Suppose I'm a transmitter which is about to transmit a frame of data. > According to all textbooks, when the frame of data arrives to the > receiver, the data will be superimposed by noise. In the simplest case, > AWG noise.> Now, suppose I (the transmitter) have managed to acquire support of a > supernatural being, which has provided me with the information about > future noise samples to originate at the receiver side. (That is, > there's an Universe which enables cheating.)> Now the question is, is it possible to use that information to transmit > less power while keeping the same SNR (or improving it) at the receiver > side?Reminds me of the case of the phase conjugate mirror and dispersion in optical fibers. If you send a signal down an optical fiber, dispersion will affect the pulses. That isn't AWG noise, but the result is that the signal can be decoded wrong. If you put a phase conjugate mirror in the middle, then the dispersion of the second half of the cable undoes the dispersion of the first half, such that the original signal (plus thermal noise) comes out the other end. This solution is interesting, as it is possible to do phase conjugation with optical signals, but otherwise it is a very specific type of noise.
